Drives: 2013 Subaru BRZ
So, I'm having a weird starting issue. I just rebuilt the motor, and everything was going smoothly, until I went to press the start button. I was getting a "pop" from the starter, but it doesn't turn. Even weirder, I get this whine while it seems to be trying to get the starter motor going. I pulled the starter, and pressed the button, and the solenoid popped out, but didn't turn. I checked for codes with none showing, got a brand new battery, as I did need one, checked the fuses and relays, even took the transmission back off to check the CPS plate was aligned properly, then went ahead and got another starter, but the issues still persist. I haven't driven my car in over a year and a half... long story about a hit and run driver hitting me, leading to a blown engine, with denied warranty claims, long story short, it's taken me a while to rebuild the motor, and get back to this point. Any help would be extremely grateful!
![]() Engine view: Dash view: |
#2 |
Drives: Track preped NA FRS
If you are sure your engine is in good shape and have a manual car, you could try pushing it to start it, that will allow you to discard a problem with the engine itself and you can focus on electrical connections to and from the starter, since it seems to try and send current thru it, yet it doesnt spin (that noise is not the spinning noise it makes when trying to start, either on car, or when not connected to the engine). Other than that, I have no suggestions.
#3 | |
#4 |
Are you sure the engine will turn over (not frozen) ..?? manually turn it over with the crank pulley ..??
Are you sure the "other starter" you got is good ....... bench test it ...?? humfrz |
#5 |
Have you checked the new battery? Those clicks sound a lot like a low amp situation.
| The Following User Says Thank You to Tcoat For This Useful Post: | strat61caster (04-22-2018) |
#6 |
I'm for sure the engine spins freely. As for the starter situation, I had the old one tested multiple times at different places, and it came out good, but I still decided on getting another one, after discussing my situation with many people. I haven't had the second starter tested, but I might as well go ahead and do so. Tcoat, after scouring the forums, and seeing the issues a low battery can cause, I have thought maybe the new battery doesn't have sufficient charge from trying multiple times now, as when I checked the battery when I was finished yesterday it was at 12.3V. I'll get some buddy's together to push the car out of the shop, so we can jump it from another car to see what that does. I'll try this again first, before I take the starter out to be tested. Thanks for the suggestions
#7 | |
#8 |
Okay, so I was finally able get a friend to run out and do some tests with me. What I found was the starter making the click noise is because of low amperage, like you suggested Tcoat, but when I would hook it up to the truck the starter would make the whining noise like in the first video. I took the starter off, and plugged everything back up to see what it's doing, and the solenoid is pushing the gear out, but not spinning. This is the same with both starters I have, but I'm leaning towards getting a new starter, as the one I bought was off a wrecked FRS. I took some video below to show how the starter is sticking and not turning. Before I took the video, the stater did exactly what is shown in the video below, but also made the whining noise when it wouldn't turn. That's when I pulled the camera out to try and get it on video, but it wouldn't make the noise again, and I stopped when I noticed that battery cables to the starter started smoking. I took that harness apart, and found an exposed area on the negative cable to the starter, then further down on the cable the plastic around the cable had started to melt. I've got a new set of battery cables on the way, but I want to find out why it did what it did, so I don't melt the new cables, unless it was from the first exposed section of wire I found, where there is no evidence of the plastic melting? Tried uploading pics of the exposed cables, but I need to resize them to the appropriate size to upload them. So, anyone got any idea what may be going on?
#9 | |
#10 |
Well, could the exposed area in the middle of the negative cable I found be the cause of said resistance? I've got new OEM battery cables on the way.
#11 |
Sarcastic SOB
Fuses>relays>wiring/connectors.
Did you hook up a battery directly to the starter to test it? Sadly, on short notice I learned all about fixing a starter. This due to $188 tow from my driveway to dealer 4 miles away and then charged just under $900 to replace starter since I had already checked fuses etc. Initially they quoted me $1300 and I told him to get the starter from Subaru which accounted for the $500 drop. In the future and when my DD is not blocked into the garage I will swap my own starter for less than $400. And the dealer had the nerve to charge me 3x hours labour (@$130/hr) for the job. I asked the service writer what the mechanic will do for the extra 2.5 hours to keep busy. LoL
#12 |
Okay, sorry it's taken me a bit to get to where I could get out to work on my car. I hooked strait up to the battery, bypassing the car, and the starter is doing the same exact same thing. When I engage the solenoid the voltage drops to 4.50V. I've got brand new OEM battery cables, went and bought some good little wire brushes, and found this plumbers tool in my shop that's perfect for cleaning inside the battery terminal ends, and it cleaned out the terminal ends till they were nice and shiny copper. I went and had both starters I have tested, for the third time, and I watched both of them spin good, again. I charged the new battery back up to 12.97V, as it was down at 12.22 when I got done experimenting the other day, but with all of that the result is the same; solenoid sticks and voltage drops from basically 13V down to 4.5V when I engage the solenoid.
The only thing I haven't replaced are the terminal ends that connect from the battery to the cable. Lol I guess I can go to Subaru or Toyota and order some.
#13 | |
#14 |
I'm pretty sure they're hooked up correctly. I had the same thought, and tried to hook them up the other way around, but the cables won't really allow for it, so I never did hook it up the other way. I guess I can try though.
| The Following User Says Thank You to Passion86 For This Useful Post: | Tcoat (05-06-2018) |
| Tags |
| starting issue |
| Whining noise when pressing clutch? | cupcake917 | Issues | Warranty | Recalls / TSB | 14 | 03-12-2019 01:49 PM |
| RPM goes up to 1.5k when pressing the clutch while slowing down | pcuerpo | Issues | Warranty | Recalls / TSB | 13 | 02-28-2018 01:37 AM |
| Weird whine type sound during pulls | CSkap21 | Engine, Exhaust, Transmission | 9 | 11-29-2017 11:44 PM |
| How much should pressing the brakes impact fuel trims? | armstrom | Software Tuning | 2 | 09-05-2017 10:04 AM |
| Pressing on the back seat behind passenger | Mikeez | Issues | Warranty | Recalls / TSB | 6 | 02-06-2015 04:11 PM |
