Old 11-29-2017, 04:21 PM   #1
CSkap21
Reckless5.86
CSkap21's Avatar
Drives: 2013 Scion FRS
Weird whine type sound during pulls
So today I noticed when driving my FR-S in 2nd and 3rd gear doing pulls from around 3-5k there is a slight whine sound, kind of like a whistle sound, is that normal or is that something i should be concerned about and have looked at. Thanks.
CSkap21 is offline   Reply With Quote
Old 11-29-2017, 04:24 PM   #2
ermax
ermax's Avatar
If I had to guess you are referring to tranny whine. If so, this is normal.
Old 11-29-2017, 04:28 PM   #3
StraightOuttaCanadaEh
Wes
Mine whines when it's cold. Is it cold where you're at?
Old 11-29-2017, 04:31 PM   #4
CSkap21
Reckless5.86
CSkap21's Avatar
I'm in Michigan so it's mid 40s right now
Old 11-29-2017, 04:33 PM   #5
Wes
Yeah about the same here. It whines for the first 5-10 minutes and then it's fine after it's warmed through. Does yours persist throughout the entire drive?
Old 11-29-2017, 04:35 PM   #6
CSkap21
Reckless5.86
CSkap21's Avatar
no its usually when its a little under normal temps
Old 11-29-2017, 05:10 PM   #7
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
How are your LTFT and STFT at idle and at 2500 RPM? AFR? It could be a vacuum or exhaust leak too.
What mods do you have?
Old 11-29-2017, 10:45 PM   #8
ermax
ermax's Avatar
5th is 1:1 so if it is gear whine then it should completely go away in 5th (it does in mine). If you hear whine in 5th then it’s got to be something else.
My IS300 whines like mad too. Except in 4th which is 1:1. The IS300 also has an Aisin transmission. It’s as if the gears are less helical than other transmissions.
Old 11-29-2017, 11:44 PM   #9
CSkap21
Reckless5.86
CSkap21's Avatar
i have no way of monitoring those at the moment since i just recently purchased this car used. And from what i know the only thing is an invidia cat back exhaust
Old 11-29-2017, 11:44 PM   #10
CSkap21
Reckless5.86
CSkap21's Avatar
Yea it usually only happens in 2nd and 3rd gear, never in 4th or 5th
Stage 2 pulls and sound - 2015 Subaru BRZ WhenzLunch FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 31 02-18-2016 09:33 AM
weird engine sound Stratoside Issues | Warranty | Recalls / TSB 52 01-13-2016 03:05 PM
High pitched whine from sound tube and idle jumping Nourdmrolnmt1 Issues | Warranty | Recalls / TSB 0 04-17-2013 11:00 PM
This might sound weird mrha BRZ First-Gen (2012+) — General Topics 10 10-06-2012 06:06 AM
Handling a little weird? Pulls/slips while on freeway. kuma Scion FR-S / Toyota 86 GT86 General Forum 29 07-10-2012 05:18 PM
