Old 04-19-2018, 07:48 PM   #1
NordicGT86
Drives: GT86
Exclamation Engine oil 20W-50; Tranmission API GL-5
Hi
Give a look to this Maintenance Schedule from Toyota Europe
https://www.toyota-tech.eu/MS/PDFS/7...05e8669332.pdf
What do you think?
NordicGT86 is offline   Reply With Quote
Old 04-19-2018, 08:23 PM   #2
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
That's not a schedule specifically for the FRS/BRZ/GT86, but just Subarus in general since there's reference to engine oils for turbo motors, front differentials, etc.. As such, the transmission oils cover both transaxle (GL5 rating to cover hypoid gears), as well as our transmissions (LV Gear oil API GL-4)
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 04-19-2018, 08:29 PM   #3
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
I'm using 0w40 mobil one euro spec. The car makes more noise at cold starts, and seems to take a bit longer to bring the oil temps up. However, the oil and water temps stay right around 192 F during normal driving. For spirited driving oil temps are between 220-240 F, but come back down a lot quicker when cruising.
20w50 seems really thick, so unless you live in an area with a really warm climate or humidity, you probably don't want to run something that thick unless the motor is running a turbo or supercharger.
REALMS BRZ Build Thread
HKS|Parts Shop MAX|Battle Version|ADVAN|Beatrush
JeremyR is offline   Reply With Quote
Old 04-19-2018, 08:33 PM   #4
NordicGT86
Drives: GT86
The form seems general, but the last column on the right is the FA20 engine, right?
Old 04-19-2018, 08:39 PM   #5
venturaII
venturaII's Avatar
I see what you mean, but that would be a huge contradiction to the North American literature, as well as what Toyota USA themselves claim is the appropriate oil to use when replacing the factory fill. It's far more than just the difference between 10W-30 versus 10W-40; going from GL3/4 to GL5 is closer to gas versus diesel. GL3/4 is compatible with yellow metals; GL5 is NOT.
Old 04-19-2018, 09:09 PM   #6
NordicGT86
Drives: GT86
I am fully agree!
Anyway, the owner's manual says the same thing in Europe 0w-20 and API GL-3. It was amazing for me that's why I shared it.
The Following User Says Thank You to NordicGT86 For This Useful Post:
venturaII (04-19-2018)
Shifting Clunk/Pop - AT Tranmission Issue TofuJoe Issues | Warranty | Recalls / TSB 5 05-29-2017 01:29 PM
Tranmission Bolts gl2filmerguy Engine, Exhaust, Transmission 2 06-05-2016 01:31 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 07:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 07:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 07:50 AM
