Old 04-11-2018, 11:43 AM   #1
Harey
Drives: 2013 Toyota 86
Increased front negative camber now oversteering what next
Hi All,
I still have all oem suspension except for some camber bolts and increased front camber.
My wheel alignment settings are:
Front Camber -2
Front Toe +0.5
Caster 6 degrees 12 minutes
SAI 17 degrees 18 minutes
Rear Camber -1.3
Rear Toe +1.0
I am running Bridgestone Potenza RE003 tyres (215/45/17) on 33psi.
The turn in is fantastic but the rear struggles to keep up. With my driving style I found it slightly oversteered before I increased front camber and now it oversteers quite a bit. I find the traction/stability control kicking in quite a lot (when driving pretty quick around tight turns).
I tried increasing the front tyre pressure to 36-38psi and while it did stop oversteering, I lost all my beautiful turn in. I have since gone back to 33psi all round and just manage the rear with my driving.
What would be the next thing to balance the car but also make it faster? I track the car 3-4 times a year. Increase rear camber, front sway bar?
Harey is offline   Reply With Quote
Old 04-11-2018, 12:00 PM   #2
Code Monkey
Drives: Subaru BRZ
Is this toe out in the rear? What toe did you run before (front and rear)?
Code Monkey is offline   Reply With Quote
Old 04-11-2018, 12:19 PM   #3
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Try dropping rear pressure first. Next steps would be to add a little toe in at the rear, as your number seems a little high (I like to shoot for zero toe in back for a car used on the street and autox/track). Next would be to add a larger swaybar up front, or add adjustable lower control arms at the rear and dial up a bit more rear camber.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following User Says Thank You to venturaII For This Useful Post:
why? (04-11-2018)
Old 04-11-2018, 12:28 PM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
+ is toe in
- is toe out
https://en.wikipedia.org/wiki/Toe_(automotive)
ineedyourdiddly
Old 04-11-2018, 12:36 PM   #5
venturaII
venturaII's Avatar
Correct. My bad. That said, I'd still shoot for zero, and regain rear stability with more camber and/or front stiffness.
Old 04-11-2018, 01:15 PM   #6
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
are the tires new? Are the rears worn more than the fronts?
Definitely need more rear camber.
why? is offline   Reply With Quote
The Following User Says Thank You to why? For This Useful Post:
norcalpb (04-11-2018)
Old 04-11-2018, 02:03 PM   #7
wparsons
wparsons's Avatar
The balance of camber front to rear is actually decent. IMO, it's probably how you're driving that's causing it.
Does it happen if you're off the throttle, or does the rear kick out under power? Are you adding throttle without reducing steering input?
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
fika84 (04-11-2018), strat61caster (04-11-2018)
Old 04-11-2018, 02:11 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
It oversteered slightly with stock alignment, and oversteered more with one you posted in OP? I'd rather check how you drive/what driving inputs you do. Alignment seems rather good to me. Of course it's less understeer biased then stock due increased grip from more negative camber in front, but then again that is what usually most of others wished to change in stock alignment. In your place i'd rather work on driving style on track. Have you tried getting some HPDE instructions? What you usually do with steering/brakes/throttle entering curve/mid curve/exiting?
Given your alignment numbers, which look ok, i'd think more on getting driving right, not extra mods/changes to car/suspension/alignment/tires, if even stock aligment was not fitting how you drive.
The Following 3 Users Say Thank You to churchx For This Useful Post:
strat61caster (04-11-2018), Ultramaroon (04-13-2018), wparsons (04-12-2018)
Old 04-11-2018, 02:19 PM   #9
Barefootdan
Barefootdan's Avatar
Drives: 2017 BRZ
Could you soften up the rear suspension a bit to help with this? Or is that counterintuitive
Barefootdan is offline   Reply With Quote
Old 04-11-2018, 02:30 PM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
Add more camber, soften rear suspension rates, reduce rear tire pressure, change to softer rollbar or even take it out, increase toe-in, add that MCA anti-squat traction mod, reduce front grip in one of multiple ways .. there are lot of ways to skin a cat (get less oversteer), but question being is that right thing to do and if that is needed at all?
Imho better learn throttle/brakes/steering affects mass transfer/grip and different phases of curve, grip management, learn quick countersteering inputs, and drive-drive-drive more to get theory in reflexes, as nothing beats more seat time. Good instructions reduce learning time and lets make less mistakes to be found/corrected by many repetitions of trying out everything, but one still needs to get all that into reflexes.
The Following 4 Users Say Thank You to churchx For This Useful Post:
Harey (04-11-2018), strat61caster (04-11-2018), Ultramaroon (04-13-2018), wparsons (04-12-2018)
Old 04-11-2018, 02:35 PM   #11
ls1ac
ls1ac's Avatar
I just thought I might mention one other possibility, sometimes at the track we would adjust the front for more bite and the driver would swear we had ruined the back. When in fact he would be turning in faster lap times. The front improved and the back did not ,but with the higher speeds the back was loose. The seat of the pants are not necessarily the best measuring device.
The Following 5 Users Say Thank You to ls1ac For This Useful Post:
Harey (04-11-2018), Jonsey (04-18-2018), strat61caster (04-11-2018), Ultramaroon (04-13-2018), wparsons (04-12-2018)
Old 04-11-2018, 02:58 PM   #12
norcalpb
norcalpb's Avatar
20mm front sway bar, and control arms to even out the camber.
Old 04-11-2018, 04:09 PM   #13
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Or, you could reset front camber to 0.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 04-11-2018, 04:14 PM   #14
venturaII
venturaII's Avatar
Put 205s on the front...
Question About Negative Camber: More Negative Camber == More Grip at Corner? Figo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 03-10-2019 02:08 PM
Negative Camber! victorchav Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-08-2016 12:51 PM
Negative front camber? Estey Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-23-2014 06:33 PM
What are your opinions on negative camber, from a looks perspective? 86-tundra Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 12-26-2013 01:29 PM
Excessive negative camber? MTeator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-22-2012 10:30 AM
