Old 06-07-2016, 08:45 PM   #1
victorchav
Drives: Asphalt Scion frs
Negative Camber!
New to this. I just recently got new tires for my 2016 Frs i have 225 on the front tires and 245 on the back tires and got an allignment. They recommended me to go from 0.7 to -1 camber on the front for better performance and i already had -2.6 on the back tires. How long before they go bald?
victorchav is offline   Reply With Quote
Old 06-07-2016, 08:59 PM   #2
djliquidsteele
Drives: Scion FR-S
You need to reverse the front and rear numbers. I'm running 2.0 in the front and 1.5 in the rear. 0 toe al around. So much grip.
djliquidsteele is offline   Reply With Quote
Old 06-07-2016, 09:03 PM   #3
swarb
Over 9000!
http://www.tirerack.com/tires/tirete....jsp?techid=48
Not all tires are made the same.
No one drives the same.
Old 06-07-2016, 09:29 PM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
djliquidsteele: you missed that he runs staggered tire setup. Probable reason why he has to workaround grip bias being out of whack in other ways. Your suggestion would be normal for sane normal square setup. As for the OP, i guess it's better to evaluate on the track yourself what you don't like and how you wish to change. Or go to some very competent suspension shop that would know how to compensate changes induced by your wheel/tire choice in best way. Or ignore, as you probably went for staggered due looks, so why would you care about performance/handling?
Not getting bald tires question bit. Depends on what tire type, how your drive. Only thing that was specified, was tire width & camber spec. Well, for what it's worth, often camber is not called as affecting wear much, it's toe that wears 'em noticeably quicker.
Old 06-08-2016, 12:22 PM   #5
kch
Senior Misanthrope
kch's Avatar
camber doesn't kill tires; toe kills tires.
that being said, your camber numbers are pretty mild.
Old 06-08-2016, 12:36 PM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
I'm guessing you are lowered to have -2.6 rear?
And how are they recommending adding camber to the front? Stock height I got -1.5 out of the stock camber bolt. Strange they are recommend 0.7 to 1? Please explain
Old 06-08-2016, 12:51 PM   #7
Bowen
Powered by Crickets
Bowen's Avatar
Drives: 14' SWP MT Limited BRZ
I run -1.5 on the front and -2.5 in the back. Like KCH said, camber doesn't ruin tires. You should be fine at -1 in the front.
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Bowen is offline   Reply With Quote
Question About Negative Camber: More Negative Camber == More Grip at Corner? Figo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 03-10-2019 02:08 PM
Rear negative camber and adjustable arm Chase1996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-07-2016 12:36 AM
Negative front camber? Estey Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-23-2014 06:33 PM
What are your opinions on negative camber, from a looks perspective? 86-tundra Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 12-26-2013 01:29 PM
Excessive negative camber? MTeator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-22-2012 10:30 AM
