View Poll Results: What are you opinions on negative camber, from a looks perspective?
Looks great 23 52.27%
Looks ugly 21 47.73%
Voters: 44. You may not vote on this poll
Old 12-25-2013, 05:35 PM   #1
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
What are your opinions on negative camber, from a looks perspective?
I'm curious to see what everyone's thoughts are on excessive negative camber. I know it has functional benefits, but aesthetically, do you like the look?
Personally, I find it disgusting. I would never lower my car so low that I need negative camber to prevent fender rub. I also think it looks pretty trashy and am not a fan of seeing these cars with high negative camber.
For purposes of the poll, significantly more cambered than stock
86-tundra is offline   Reply With Quote
Old 12-25-2013, 05:40 PM   #2
s2d4
s2d4's Avatar
What do you consider high?
Old 12-25-2013, 05:46 PM   #3
86-tundra
Troll Hunter
86-tundra's Avatar
Good point. I updated the OP. Anything more than stock.
Old 12-25-2013, 05:54 PM   #4
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Stock wheels with lots of neg camber ugly. Nice fat wheels with lots of camber sexy.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 12-25-2013, 06:46 PM   #5
s2d4
s2d4's Avatar
Here is the dilemma, stock rear is ~-1.7, front is ~0.
Does that mean that the front can be ~1.7 as well?
Old 12-25-2013, 08:33 PM   #6
mango
mango's Avatar
Drives: na
I prefer function over hard parking, especially on a car like the FR-S
mango is offline   Reply With Quote
Old 12-25-2013, 09:24 PM   #7
Ocean-Grown 86
It was fun
Ocean-Grown 86's Avatar
Drives: Dirty FR-S
Functional negative camber looks aggressive. I like a good stance too, but I hate hellaflush camber.
Ocean-Grown 86 is offline   Reply With Quote
Old 12-25-2013, 09:30 PM   #8
mfbmike
Drives: 2013 FRS, 2008 R32
265/35 tires and -2 degrees of camber.
mfbmike is offline   Reply With Quote
Old 12-25-2013, 09:31 PM   #9
MeFryRice
Drives: '13 SWP BRZ
I hate high-cambered cars that are driven on the street for the purpose of trying to fit an improper fitting wheel. If its for a car that is tracked then yes, I like it because the car is actually putting the camber use.
MeFryRice is offline   Reply With Quote
Old 12-25-2013, 10:43 PM   #10
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
you should have just named this thread, hella flush is hella retarded Y/N
bkblitzed is offline   Reply With Quote
Old 12-25-2013, 11:15 PM   #11
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
"For purposes of the poll, anything more negative than stock" is a little vague. Allowable factory camber spec is -1.3 front and -2.4 rear (per http://www.ft86club.com/forums/showthread.php?t=7918). Being at the limits of factory camber is visually noticeable compared to typical factory camber (0 front and -0.5 rear) but still factory spec. So are you referring to anything more negative than -1.3 front and -2.4 rear or anything more negative than typical (0 front and -0.5 rear)?
The following TRD 86es have their camber plates maxed out likely beyond factory spec but are still visually tasteful.
Old 12-26-2013, 12:08 AM   #12
86-tundra
Troll Hunter
86-tundra's Avatar
Do we really have to get into the technicals? The question I'm asking is pretty obvious
Old 12-26-2013, 12:16 AM   #13
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
^Not really
There's more to camber than just running it so wheels don't rub.
TylerLieberman is offline   Reply With Quote
Old 12-26-2013, 02:25 AM   #14
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Too high=what? As others have said
Stance no I don't care for that, but that is one persons desire so that is fine?
Too many variables really. Stock ft camber sucks in comparison to having even -1.5 for example you don't need to be a track star to notice the improvement in simple spirited driving. -1 to -2 degrees ft or rear IMO looks perfectly fine "looks wise" past that well then I need to evaluate if it for function, if so that's good on them.
All I can say is that with this platform having a good alignment and having "some" negative camber up front is heaps better then stock function wise so that will over run what I think a tad of negative looks like.
For my own personal needs I will not exceed -2 ft or rear and that is a very functional range for "me". Guys who are tracking regularly will and do use -3 to -4 range up front and that is perfectly understandable. IMO (0) up front is not right for a sports car to begin with. Conclusion, straight up and down on this car looks "not good" mostly cause I know the benefits of having camber on "this car"
Question About Negative Camber: More Negative Camber == More Grip at Corner? Figo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 03-10-2019 02:08 PM
Advice on negative rear camber Thongpocket Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 09-27-2013 10:38 PM
86 vs. 2013 STI - a DD perspective. Jar FR-S / BRZ vs.... 22 07-10-2013 02:04 PM
Excessive negative camber? MTeator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-22-2012 10:30 AM
A different perspective on price. Hanzo BRZ First-Gen (2012+) — General Topics 19 06-11-2012 09:07 PM
