Old 03-15-2018, 02:08 PM   #1
smudge
Drives: Supercharged GT86
Cable throttle
Anyone fitted an engine which uses a cable throttle rather than FBW?
What are the options when it comes to this? Change the pedal to a cable connection? Convert the OEM pedal to a cable connection? Replace the TB for a FBW alternative?
Cheers
smudge is offline   Reply With Quote
Old 03-15-2018, 02:09 PM   #2
all4spl
FBW is the easiest.
all4spl is offline   Reply With Quote
The Following User Says Thank You to all4spl For This Useful Post:
Sportsguy83 (03-15-2018)
Old 03-15-2018, 02:11 PM   #3
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Cars don't work like that anymore. You can't just wire up a throttle wire. There's a whole lot of stuff going on when you hit the gas pedal and the days of directly opertaing the throttle are long gone
guybo is offline   Reply With Quote
The Following 2 Users Say Thank You to guybo For This Useful Post:
Ingen (03-17-2018), Tcoat (03-15-2018)
Old 03-15-2018, 05:38 PM   #4
toast
Drives: 14 BSP Edelbrock BRZ
How big of a pilot valve are you running?
toast is offline   Reply With Quote
Old 03-15-2018, 06:58 PM   #5
smudge
Originally Posted by all4spl View Post
FBW is the easiest.
I'd say it's the best, not always the easiest. Just need to make sure it definitely is the easiest option
Hoping we can wire a FBW TB into the engine loom and the Motec we're using will pick it up
Old 03-15-2018, 06:59 PM   #6
smudge
I have no idea what a pilot valve is?
Old 03-15-2018, 07:01 PM   #7
smudge
Seeing as the engine we're using is a cable driven TB, it was worth asking to see if changing to a cable setup was worth it
As above, hoping we can use the Motec ECU to keep a FBW setup and just stick a new TB on the intake and incorporate it into the engine loom we're making
Old 03-15-2018, 07:03 PM   #8
toast
I meant pilot jet. If you are going to go to a wire throttle I assumed you were into retro chic or steampunk and you would be using a carburetor.
I'm going to go out on a pretty substantial limb and say the motec is expecting to be controlling the throttle FBW...
The Following User Says Thank You to toast For This Useful Post:
smudge (03-15-2018)
Old 03-15-2018, 08:12 PM   #9
smudge
So in theory we just stick on a new TB (maybe something off an LS?) and wire it into the FBW inputs for the Motec
Thanks for confirming
Old 03-16-2018, 10:56 AM   #10
all4spl
Yes that will work.
Old 03-18-2018, 05:06 AM   #11
Kodename47
Kodename47's Avatar
Drives: UK GT86
When setting up DBW (not FBW - it's not a plane) you need the ECU to be able to operate the motor of the throttle body which will include the sensors of the plate range. The pedal just outputs a voltage range so is a sensor input as per anything else. I would assume that any decent Motec is capable of this. A cable setup is much harder to implement.
https://www.google.co.uk/search?q=se...hrome&ie=UTF-8
You could use any electronic throttle body that's the right size, the wiring is different depending on make but if you're custom wiring it anyway then it makes it easy to pick based on requirements and budget. This also gives you a better selection than cabled systems.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-30-2018, 11:34 AM   #12
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
Reviving this thread.
I'm currently starting the parts gathering to swap my LS from my 1971 240z over to my FRS.
Its a cable driven throttle body with stand alone harness megasquirt ECU.
Looking at the firewall around the throttle pedal, it seems cramped.
Has anyone done this? I've seen photos of some element tuning car with a cable throttle in it. But I cant seem to find much info or parts necessary.
spitsnaugle is offline   Reply With Quote
Old 04-30-2018, 11:38 AM   #13
gtpvette
Drives: 2015 FRS - FFR GTM
What will become of the 240z??
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
Old 04-30-2018, 12:14 PM   #14
spitsnaugle
Selling it http://forums.hybridz.org/topic/1288...ing-car-parts/
I've got about six or seven people interested in it right now, next person is looking at it this upcoming tuesday. Hoping it sells soon, it'll be funding the parts for the FRS LS swap.
The Following User Says Thank You to spitsnaugle For This Useful Post:
gtpvette (04-30-2018)
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 01:20 PM
Throttle by cable FA20? MicahG6 BRZ First-Gen (2012+) — General Topics 21 10-09-2017 01:46 PM
Gauge install, dash cluster light cable, Tach RPM cable help... Sportsguy83 Electronics | Audio | NAV | Infotainment 99 08-07-2016 11:36 PM
AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok? tracerit Engine, Exhaust, Transmission 11 02-15-2014 01:44 PM
