Old 03-12-2018, 03:57 AM   #1
stlgrym3
need advise to get rear LCA or not
i'm lowered about 1.5 inches front and rear on Apexi N1 coilovers. front cambers are within factory specs (-1 degree) after alignment. however, rear are at -2.3 degrees, but toe settings are within factory specs. alignment shop told me i'd need a rear LCA to adjust the rear negative cambers. this is my weekend canyon run car, i don't track it (at least not yet). do i absolutely need to spend $500 or so for a set of LCA? i've heard both side of the arguments in other similar thread.
stlgrym3 is offline   Reply With Quote
Old 03-12-2018, 05:06 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
If current rear camber is somewhat even on both sides and you are happy with current value of it, you don't need it of course.
IF you want different camber setting rear, yes, you have to get aftermarket rear LCAs (well, actually there are other means to adjust camber too, but more expensive or PITA to adjust). Cheapest LCAs are far from $500. SPC ones are like $230. For front camber adjustment there are cheaper alternatives available, such as camberbolts. With stock suspension camber on twins is not adjustable both front and rear, only toe is.
Old 03-12-2018, 06:52 AM   #3
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Depends on if you want to adjust your rear camber. I would say yes, you need them with coilovers.
Old 03-12-2018, 09:30 AM   #4
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Grab the SPC LCA's, do the toe bushings as well, dial back the camber a bit, and add OEM 14mm crash bolts to the front so you have more front camber than rear. Get a good alignment and you'll love the changes. If you go -1.5f, -1 rear and add as you see fit from there with zero toe, you'll really like the balance.
JazzleSAURUS is offline   Reply With Quote
Old 03-12-2018, 02:03 PM   #5
stlgrym3
Currently my front are both -0.6. Rear are -2.4 and -2.2 to be exact. I think I’m getting SPC rear LCA.
Old 03-12-2018, 02:28 PM   #6
cjd
cjd's Avatar
Drives: 2017 BRZ
-2.3 is a nice amount of rear camber with -3 up front...
The Following User Says Thank You to cjd For This Useful Post:
strat61caster (03-12-2018)
Old 03-12-2018, 02:33 PM   #7
Leonardo
Country Boy 4 Life
Leonardo's Avatar
It is not absolutely necessary. Though you still may want to, depending on how many more mods are in your plan.
I just have 7/8" Eibach prokit springs. My rear has -1.8 and -2.2 of natural camber. I have 65,000 miles this way. my tires wear even.
I LIKE TIRES!
Old 03-12-2018, 04:07 PM   #8
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Drive it the way it is, come back if you're not happy with how it handles and quite a few people will be able to figure out based on your description how to improve it. There's nothing wrong with that alignment, there are repercussions but nobody online can read your mind and understand what will happen.
If you're happy with it as-is you saved $500
It will all depend on how you drive it.
ineedyourdiddly
Advise Please ricky rod Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 06-19-2015 04:10 PM
Please advise: FRS rear bumper damage Mbaker Scion FR-S / Toyota 86 GT86 General Forum 9 05-24-2015 12:32 PM
Removed "scion" rear bumper protector of 2015. Need Advise! kwest.papajohns Cosmetic Modification (Interior/Exterior/Lighting) 14 04-22-2015 01:09 PM
New to rim fitment; someone please advise REAV3R Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 03-02-2015 08:02 PM
FT86 advise please eddiev116 Scion FR-S / Toyota 86 GT86 General Forum 7 02-01-2015 03:13 PM
