Old 04-21-2015, 03:45 PM   #1
kwest.papajohns
Drives: red frs
Removed "scion" rear bumper protector of 2015. Need Advise!
I removed the clear "scion" rear bumper protector off a 2015 frs. It left some serious adhesive on the paint. I have tried goo gone, plastic razor blaze and the hairdryer trick and still no progress. Does anyone have any advise!? The car only has 400 miles
kwest.papajohns is offline   Reply With Quote
Old 04-21-2015, 04:01 PM   #2
8R6
8R6's Avatar
Drives: FRS
plastic razor blade?!
8R6 is offline   Reply With Quote
Old 04-21-2015, 04:03 PM   #3
kwest.papajohns
Drives: red frs
Plastic razor blade to gently try and remove the adhesive with goo gone? Is that crazy logic? No damage...yet
Old 04-21-2015, 04:05 PM   #4
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Dumb question: Why did you remove it?
Stang70Fastback is offline   Reply With Quote
Old 04-21-2015, 04:05 PM   #5
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
Elbow greese and time.. it took me about 30-45 mins to clean it all off. I just used goo gone and my fingernails and the Vegas sun in the summer.
Plastic razor blades.. exactly what it sounds like, a razor blade but plastic, so you can scrap off stuff like this with out marking the paint to bad. Unless you just got confused from his spelling? We used them all the time in the body shop i worked at, the rubber disc to remove pin stripes took longer then most times just using the sun and a plastic blade.
-Thomas
86SPEED is offline   Reply With Quote
Old 04-21-2015, 04:06 PM   #6
86SPEED
86SPEED's Avatar
I removed mine because i didnt want "Scion" anywhere on the car after rebadging
The Following User Says Thank You to 86SPEED For This Useful Post:
continuecrushing (04-21-2015)
Old 04-21-2015, 04:12 PM   #7
Lorico
Drives: 2015 FRS
Lorico is offline   Reply With Quote
The Following User Says Thank You to Lorico For This Useful Post:
Choco (04-28-2015)
Old 04-21-2015, 04:19 PM   #8
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
pretty sure I used a hair dryer on mine, and it didn't leave much.
Goo gone and elbow grease would be my attempt.
Old 04-21-2015, 04:32 PM   #9
stevesnj
stevesnj's Avatar
From 3M's site http://solutions.3m.com.au/wps/porta...esources/FAQs/
Q.After Scotchgard™ Paint Protection Film has been removed, how do I get any excess adhesive off my vehicle?
A.If any adhesive remains on the vehicle after removal of the film, it can be removed by using 3M™ 700 Adhesive Cleaner, according to the package directions.
[ame="https://www.youtube.com/watch?v=AnMQ48udWYE"]How To Remove Scotchgard Paint Protection Film by Car Protection Pro - YouTube[/ame]
My 2016 Build thread
Old 04-21-2015, 04:45 PM   #10
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
As you should've. I wouldn't want that evil logo on my car, either.
Instagram: stimson
Old 04-21-2015, 04:51 PM   #11
8R6
8R6's Avatar
Drives: FRS
-Thomas
oh. never heard of it before or seen one. learn something new everyday
Old 04-22-2015, 11:25 AM   #12
kwest.papajohns
Drives: red frs
3M Adhesive remover is amazing. Sprayed it right on and it wiped right off! Took about 10 minutes!
The Following User Says Thank You to kwest.papajohns For This Useful Post:
Dadhawk (04-22-2015)
Old 04-22-2015, 11:48 AM   #13
cnk
Drives: '13 DGM BRZ Limited
Make sure you re-wax that area as the 3M adhesive remover also strips the wax off the paint.
cnk is offline   Reply With Quote
The Following User Says Thank You to cnk For This Useful Post:
86SPEED (04-22-2015)
Old 04-22-2015, 12:37 PM   #14
Snowblind
Because the car was waxed from the factory underneath the stupid decal.
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
WTB: Black "Raven" FR-S/BRZ rear bumper sw20kosh Want-To-Buy Requests 1 11-05-2013 10:30 PM
Rear bumper protector denkigrve Cosmetic Modification (Interior/Exterior/Lighting) 52 10-30-2013 01:13 PM
Rear Bumper "diffuser" Removal sw20kosh DIY (Do-It-Yourself) Guides 6 07-31-2013 03:24 PM
Long "Scion" sticker on back bumper CaptainSlow Cosmetic Modification (Interior/Exterior/Lighting) 7 04-12-2013 10:31 AM
