Old 02-21-2018, 01:01 AM   #15
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
It seems like they just did a toe and go on you, common procedure to make more $$... but didn't even bother to try zeroing the toe in the rear.
tyler_win_photo is offline   Reply With Quote
Old 02-21-2018, 07:50 AM   #16
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by Alfrz91 View Post
I'm very far from being an expert but I've seen alignment reports before and this just seems like such a waste of money/ time for an incredibly small gain... if any. I've no problem going back and having them take another crack at it/refund (if it does in fact seem like they shouldn't have done it/known better/done more/etc), as in my experiences any place that works on a car will always try to make it right if they can.
It's not a bad idea to have the alignment checked every once in a while, and while tires being changed doesn't affect alignment or necessitate adjustment it's as good a time as any to have it checked.
The shop did nothing wrong. Technically the alignment is within spec and if you weren't aware of the rear asymmetry you probably wouldn't notice it.
Do you have an idea of what you *want*? Personally, I'm a fan of running minimal toe all around and my generic alignment advice to non-expert non-track people is to run toe at both ends as close to zero as the spec allows and also run the most negative camber the spec allows (not applicable here).
For this car I'd say zero front, zero rear toe. But it's not reasonable or necessary to ask for 0.00°. You might ask for 0 +/-0.05°, which would mean they'd only have to tweak the right rear. But if they don't want to do it for free I wouldn't necessarily hold it against them, depending on what they charged you in the first place.
New wheels/tires=alignment X Factor Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-14-2015 08:20 PM
Oddities: new alignment, tires and wheels rainmonkey Tracking / Autocross / HPDE / Drifting 12 10-25-2013 08:29 PM
FS (south florida)- 4 wheels + tires, TPMS included $300 OBO sieeegel Wheels and Tires 6 08-23-2013 04:12 PM
FS: factory FRS wheels and tires (TPMS sensors included!) cb7tuner Wheels and Tires 1 08-16-2013 12:26 AM
FEELER: 18x8 +35 5x100 Ace Vertex - tires included ayetothejay Wheels and Tires 1 02-17-2013 07:07 PM
