#15 | |
Drives: 2013 scion frs , 1999 subaru legacy
#16 | ||
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Here is what I ordered for my install... 90311-38070 pinion seal $8.71 - the one included in the Toyota kit I used will not fit our housing... 90366-35133 pinion bearing $87.06 - not strictly necessary, but can can be damaged during removal from your old pinion shaft... 12157-10010 drain bolt gasket $1.08 SU003-00122 fill bolt gasket $1.79 90311-43009 quantity 2 differential axle seal($15.60 each) Most differential shops stock the shims and oil - I was not picky on the oil since I changed it out after 500 mile break in. The toyota kit includes crush sleeve, new bolts, lock tabs... Not trying to sell you on a Toyota kit; just adding info to the thread. I have heard nothing but good about the Weir stuff.
![]() ![]() Last edited by nextcar; 12-01-2020 at 06:27 PM. |
#17 | |
#18 | |
#19 |
you guys are awsome and a great help, so sick of build forums for this that just say oh 4.88 or 4.55 lol i need the parts lol easy to build but sourcing the parts is a pain in the butter
#20 | |
Drives: frs
#21 |
#22 |
Drives: 2013 Scion FR-S 10 Series
Spence Weir can be hard to reach, but he knows his stuff and sells a great product. He was very fair with me and took a lot of time to give me guidance, and I was so impressed with his knowledge that I actually shipped my differential from Illinois to him so he could install my OS Giken LSD and a Weir Performance 4.56:1 ring and pinion gear set. It’s a great set up and I don’t think you’ll be disappointed if you go that route.
#23 | |
I paid $300 to have the third member set up since I did not have the tools to do this. Note that I brought the third member to the differential shop so the $300 is just to clean, disassemble, install the gears and bearings, shim for proper wear pattern, set crush sleeve and preload, etc. Local rates will vary; this should be a good ballpark figure.
I removed/installed the third member myself, but I imagine a shop would charge another $200-$300 to do that.
| The Following User Says Thank You to nextcar For This Useful Post: | Teseo (02-16-2018) |
#24 | |
#25 | ||
My guess is that he was selling Yukon Gears, US Standard Gears, Richmond Gears, or possibly US Gears... Does anyone who bought just gears from him remember what brand was on the box?
#26 | |
"Final Drive Gears We sell only high quality ring and pinion gear sets. All sets are CNC machined and lapped for quiet operation. Be aware of cheaper gear sets, they will not run as quiet or last as long as these gear sets will when properly installed." |
#27 | ||
#28 | |
Heads up! I have no connection and make no claims/recommendations on this...
Ebay has a listing for a New Weir Performance 4.56 gear set for FRS with bearings, seals, and solid spacer. Ends tomorrow and has a reserve; don't have any idea what it will sell for. If interested go to ebay and search "weir performance" I was just trying to find a picture of a weir gear set to see if there were any identifying marks on it and ran across this.
| The Following User Says Thank You to nextcar For This Useful Post: | NoHaveMSG (02-16-2018) |
| Tags |
| frs differential |
| Which is better? Reaplcing rear diff bushings? or installing rear diff brace? | Frs30 | Engine, Exhaust, Transmission | 22 | 04-13-2020 10:23 AM |
| Diff Mount Inserts install - Diff won't lower??? | ChRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 07-17-2017 12:07 AM |
| Swap AT Diff with MT Diff | sydious | Engine, Exhaust, Transmission | 2 | 03-17-2016 02:59 PM |
| Engine Builds-Reviews | tg_1981 | Forced Induction | 17 | 01-13-2014 05:19 PM |
| FBM BRZ/FRS Shop Builds/Projects | FullBlown | Forced Induction | 50 | 10-21-2013 02:10 PM |
