Old 02-15-2018, 02:14 PM   #1
clay217
Drives: 2013 scion frs , 1999 subaru legacy
4.56/4.67/4.88 diff builds
Hi I am new here but not new to cars or the fr-s. I have done cheap mods to get the most bang for the $ and now it is time to do the diff build. I am having a hard time parting with $ for the brand name final gears as there's no reason for the price gouge. Which is better? who has done one and what one did you pick and like? I work at Toyota so I am going to cross reference different options but I see online 4.88 for $300-600 but cant find info if the final drive gear is a 7.5" or 8"? will the 4 runner 4.88 work? thanks for any help.
clay217 is offline   Reply With Quote
Old 02-15-2018, 02:31 PM   #2
TorontoNat
Drives: 2013 Scion FR-S Asphalt [Gray]
I don't know what the ultimate purpose of your car is. Maybe a drift build? so I'm mostly just curious here on how these diffs you speak of are superior to the stock one? Do you have more power and the stock diff can't handle it? (Is that even possible)? From what I understand the diff is one of the best parts of these cars no?
TorontoNat is offline   Reply With Quote
Old 02-15-2018, 02:36 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
http://weirperformance.com/
Weir can set you up for a good price. I believe the R&P matches up with one of the early Supra's.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
coxxoc (07-31-2018), fika84 (02-15-2018), jcw99 (03-01-2021)
Old 02-15-2018, 02:37 PM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The only reason to replace the stock diff is for better gearing, shorter or longer gearing when compared to the stock 4.10. Unless you're making over 600ish TQ then you need a stronger one but that's a whole nother story.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
TorontoNat (02-15-2018)
Old 02-15-2018, 02:47 PM   #5
clay217
yeah would be great if they ever replied, the have lost my business due to no returned calls or emails so i want other avenues. Mainly need info on final gears i suppose, are all cut the same? like if its an 8" can i use any 8"?
The Following User Says Thank You to clay217 For This Useful Post:
FT86Z (09-23-2018)
Old 02-15-2018, 02:49 PM   #6
clay217
I dont have the $ for a turbo kit so this is a cheap way of making the na faster as its shortening the gear ratios for more torque to simply put it
Old 02-15-2018, 03:39 PM   #7
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Toyota ring and pinion part numbers compatible with the FRS. Not all can be ordered in North America; I had to order mine from Japan. The only real problem with some of the third party gears is a bit of whine due to not all being helical cut.
3.58:1 - 41201-80125
3.73:1 - 41201-80050
3.91:1 - 41201-80052
4.10:1 - 41201-19605
4.30:1 - 41201-29606 (Included pinion seal will not fit)
4.56:1 - 41201-19557 (Included pinion seal will not fit)
4.88:1 - 41201-80183 (Included pinion seal will likely not fit) <= warning: fitment problems reported
5.13:1 - 41201-80300 (Included pinion seal will likely not fit)
Good luck.
...I went 4.56 with a MT, but sometimes I think I should have gone 4.88
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
The Following 5 Users Say Thank You to nextcar For This Useful Post:
Bu-Tang (02-23-2018), Spankopotomous (12-21-2020), Stonehorsw (11-24-2020), Tanstin (11-24-2020), Teseo (02-15-2018)
Old 02-15-2018, 03:49 PM   #8
Teseo
Drives: frs
Good luck.
Problem would be adding an installation kit + labor will affect the budget
Old 02-15-2018, 04:21 PM   #9
clay217
Good luck.
toyota ones are pricey, wonder can you use any 4.88 and are they a 7.5" or a 8" and if i do use a toyota one as long as its the same diameter teeth cound should be same? i know weir offers 2 choices in supra so which is it of the supra that works? th 1986.5 + or prior years, thanks guys this is a help
Old 02-15-2018, 04:22 PM   #10
mkivsoopra
Sorry to hear that.. I have the their 5.29 and it's working well. They were generally pretty responsive when I have called/emailed them in the past.
mkivsoopra is offline   Reply With Quote
The Following 2 Users Say Thank You to mkivsoopra For This Useful Post:
Old 02-15-2018, 04:44 PM   #11
fika84
fika84's Avatar
I agree with this ^^. I have their 4.88 and it's built perfectly and quiet. I think it's just Spencer that does everything, so you need to give the guy a break. He's probably busy
fika84 is offline   Reply With Quote
Old 02-15-2018, 04:45 PM   #12
clay217
4.88:1 - 41201-80183 is not a toyota part # also what did you do for an install kit as my parts manager is looking and all the gunk is different, thanks
Old 02-15-2018, 04:46 PM   #13
clay217
i have been trying for a year.....
Old 02-15-2018, 04:49 PM   #14
fika84
fika84's Avatar
Dang! Well hopefully it comes around. Are you reusing the 86 carrier? Or getting an IS300 one?
frs differential
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 10:23 AM
Diff Mount Inserts install - Diff won't lower??? ChRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-17-2017 12:07 AM
Swap AT Diff with MT Diff sydious Engine, Exhaust, Transmission 2 03-17-2016 02:59 PM
Engine Builds-Reviews tg_1981 Forced Induction 17 01-13-2014 05:19 PM
FBM BRZ/FRS Shop Builds/Projects FullBlown Forced Induction 50 10-21-2013 02:10 PM
