Old 02-15-2018, 04:56 PM   #15
clay217
Drives: 2013 scion frs , 1999 subaru legacy
Originally Posted by fika84 View Post
Dang! Well hopefully it comes around. Are you reusing the 86 carrier? Or getting an IS300 one?
i think i will use my stock one, i got the is250 carrier before knowing it doesnt have a lsd and decided now that i am not interested in winter driving due to them starting to use heavy salt and chemicals here so i got a is250 carrier for sale
clay217 is offline   Reply With Quote
Old 02-15-2018, 04:58 PM   #16
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Originally Posted by nextcar View Post
Toyota ring and pinion part numbers compatible with the FRS. Not all can be ordered in North America; I had to order mine from Japan. The only real problem with some of the third party gears is a bit of whine due to not all being helical cut.
3.58:1 - 41201-80125
3.73:1 - 41201-80050
3.91:1 - 41201-80052
4.10:1 - 41201-19605
4.30:1 - 41201-29606 (Included pinion seal will not fit)
4.56:1 - 41201-19557 (Included pinion seal will not fit)
4.88:1 - 41201-80183 (Included pinion seal will likely not fit)<= warning: fitment problems reported
5.13:1 - 41201-80300 (Included pinion seal will likely not fit)
Good luck.
...I went 4.56 with a MT, but sometimes I think I should have gone 4.88
That is not a part that Toyota USA sells, it is a Toyota part number.
Here is what I ordered for my install...
90311-38070 pinion seal $8.71 - the one included in the Toyota kit I used will not fit our housing...
90366-35133 pinion bearing $87.06 - not strictly necessary, but can can be damaged during removal from your old pinion shaft...
12157-10010 drain bolt gasket $1.08
SU003-00122 fill bolt gasket $1.79
90311-43009 quantity 2 differential axle seal($15.60 each)
Most differential shops stock the shims and oil - I was not picky on the oil since I changed it out after 500 mile break in. The toyota kit includes crush sleeve, new bolts, lock tabs...
Not trying to sell you on a Toyota kit; just adding info to the thread. I have heard nothing but good about the Weir stuff.
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
The Following 2 Users Say Thank You to nextcar For This Useful Post:
JeremyR (02-16-2018), Teseo (02-15-2018)
Old 02-15-2018, 05:07 PM   #17
fika84
fika84's Avatar
I pretty much ordered the same things, but did some through Lexus and some through Toyota (whichever was cheaper).. I was surprised that ANY of the lexus parts were cheaper for the same part number... but nonetheless they were! Really only difference between this and mine was that I used the Weir solid spacer kit and different fluid since I put in a mechanical LSD.
fika84 is offline   Reply With Quote
Old 02-15-2018, 08:17 PM   #18
clay217
I am up in Canada so where are these toyota numbers from as my parts guy is from uk and can get them, thanks
Old 02-15-2018, 08:20 PM   #19
clay217
you guys are awsome and a great help, so sick of build forums for this that just say oh 4.88 or 4.55 lol i need the parts lol easy to build but sourcing the parts is a pain in the butter
Old 02-15-2018, 08:44 PM   #20
Teseo
Drives: frs
How much cost the labor for installation?
Old 02-15-2018, 09:13 PM   #21
clay217
i would suspect thats going to vary wildly as rates but i would expect shop rate to be like 5h install/build if your not doing it yourself maybe more time
Old 02-15-2018, 11:51 PM   #22
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
Spence Weir can be hard to reach, but he knows his stuff and sells a great product. He was very fair with me and took a lot of time to give me guidance, and I was so impressed with his knowledge that I actually shipped my differential from Illinois to him so he could install my OS Giken LSD and a Weir Performance 4.56:1 ring and pinion gear set. It’s a great set up and I don’t think you’ll be disappointed if you go that route.
RJasonKlein is offline   Reply With Quote
The Following 2 Users Say Thank You to RJasonKlein For This Useful Post:
clay217 (02-16-2018), jcw99 (02-16-2018)
Old 02-16-2018, 12:32 AM   #23
nextcar
I paid $300 to have the third member set up since I did not have the tools to do this. Note that I brought the third member to the differential shop so the $300 is just to clean, disassemble, install the gears and bearings, shim for proper wear pattern, set crush sleeve and preload, etc. Local rates will vary; this should be a good ballpark figure.
I removed/installed the third member myself, but I imagine a shop would charge another $200-$300 to do that.
Pull out
The Following User Says Thank You to nextcar For This Useful Post:
Teseo (02-16-2018)
Old 02-16-2018, 11:04 AM   #24
fika84
fika84's Avatar
How do you like the OS Giken?? I couldn't swallow the price at first so I went with MFactory and got the inner parts WPC treated. Did you have any chatter with the OS Giken?
Old 02-16-2018, 11:18 AM   #25
nextcar
Since it appears difficult to contact Weir Performance these days, do any of his happy customers know what brand gears he was selling? Weir Performance was not in the business of manufacturing gears; these days there really are not many manufacturers... For those that are looking for lower cost options than the Toyota kits (I paid about $400 vs about $200 for the third party sets).
My guess is that he was selling Yukon Gears, US Standard Gears, Richmond Gears, or possibly US Gears...
Does anyone who bought just gears from him remember what brand was on the box?
Pull out
Old 02-16-2018, 11:59 AM   #26
fika84
fika84's Avatar
Are you sure about that?.. Pretty sure the only ones he doesn't make himself are the used ones..
"Final Drive Gears
We sell only high quality ring and pinion gear sets. All sets are CNC machined and lapped for quiet operation. Be aware of cheaper gear sets, they will not run as quiet or last as long as these gear sets will when properly installed."
Old 02-16-2018, 12:35 PM   #27
nextcar
"Final Drive Gears
Am I positive? No. Am I over 99% confident? Yes. No way he could have the machinery and produce these gears at low volume at that price. I see no claims that Weir Performance actually makes the gears...
Pull out
Old 02-16-2018, 12:54 PM   #28
nextcar
Heads up! I have no connection and make no claims/recommendations on this...
Ebay has a listing for a New Weir Performance 4.56 gear set for FRS with bearings, seals, and solid spacer. Ends tomorrow and has a reserve; don't have any idea what it will sell for. If interested go to ebay and search "weir performance"
I was just trying to find a picture of a weir gear set to see if there were any identifying marks on it and ran across this.
Pull out
NoHaveMSG (02-16-2018)
frs differential
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 10:23 AM
Diff Mount Inserts install - Diff won't lower??? ChRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-17-2017 12:07 AM
Swap AT Diff with MT Diff sydious Engine, Exhaust, Transmission 2 03-17-2016 02:59 PM
Engine Builds-Reviews tg_1981 Forced Induction 17 01-13-2014 05:19 PM
FBM BRZ/FRS Shop Builds/Projects FullBlown Forced Induction 50 10-21-2013 02:10 PM
