Old 02-06-2018, 01:27 AM   #15
CHMBRZ
Drives: 2016 Subaru BRZ Limited
Originally Posted by BatStig View Post
I ordered the extension for the Mocal plate from www.batinc.net .
So you just used one long extension screw for the setup?
CHMBRZ is offline   Reply With Quote
Old 02-06-2018, 12:04 PM   #16
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
Unfortunately, no. Two. One for each part. If i remember correctly, the inner diameter of the TRD plate and the Mocal plate are different.
BatStig is offline   Reply With Quote
The Following User Says Thank You to BatStig For This Useful Post:
sroby (08-17-2019)
Old 02-06-2018, 02:03 PM   #17
CHMBRZ
Ok hence needing the PN ES20 from Bat site?
Old 02-07-2018, 03:15 AM   #18
CHMBRZ
I’m wondering because I have the RacerX fabrications oil cooler was thinking removing the spacer and putting the TRD adapter plate to run the sensors then the racerx oil cooler plate on top. Comes with one long extension screw. Hoping it works.
Old 06-28-2018, 02:37 PM   #19
FL4WLSS
Drives:
So did this work? I am trying to do part research for short block replacement, and wanted to install an oil cooler and oil temp/pressure guage while i was at it.
Sent from my SM-G925V using Tapatalk
FL4WLSS is offline   Reply With Quote
Old 06-28-2018, 11:45 PM   #20
CHMBRZ
I sent you a dm
Old 06-29-2018, 07:40 AM   #21
Firecruiser
Drives: 2014 brz
Not sure if they will sell it separately but jackson racing has an adapter plate with 4 ports on it to accommodate both oil cooler and sensors.
https://jacksonracing.com/product/fr...il-cooler-kit/
Firecruiser is offline   Reply With Quote
pressure and temp oil in this car? pepe Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-25-2015 06:02 PM
Oil pressure and Oil Temp sensor - where did you mount them and how philooo Engine, Exhaust, Transmission 11 05-29-2015 03:41 AM
Installing oil pressure/temp probes xwd Engine, Exhaust, Transmission 12 03-14-2015 01:07 AM
Help Installing Oil Temp Gauge k.houan Engine, Exhaust, Transmission 1 11-11-2014 12:57 AM
Addition of a radiator hose sensor temp adapter & coolant bleeding FutureFT86 Engine, Exhaust, Transmission 9 07-22-2014 12:50 AM
