Old 12-03-2017, 12:22 AM   #1
redlined600
redlined600's Avatar
Drives: Fr-s
IRP shifter issue
I could just be my bad luck but it can't hurt to check yours.
I bought one of these used and upon receiving it I noticed the shift lever was really loose on the longitudinal pivot(that allows the shifter to move left to right).
I took it apart, cleaned it all up and put it back together again. That when i noticed that despite tightening down the lock nut on the longitudinal bolt it was still easy to loosen up. Since there is nothing "locking" the bolt down it's free to back out, after use I'm sure it would loosen up again.
What I found is that the thread for the lock nut was not machined far enough, so it wasn't actually holding anything tight (like the bolt from backing out). A picture is worth a thousand words.
It's not like the bolt would fall out since, at some point it would back up against the lock nut, but if your shifter feels sloppy now you know why.
redlined600 is offline   Reply With Quote
The Following User Says Thank You to redlined600 For This Useful Post:
humfrz (12-03-2017)
Old 12-03-2017, 03:21 AM   #2
What do you expect for $500 ...... something well made .......??
Old 12-03-2017, 03:33 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Hope you have a lifetime warranty on that perfect example of a manufacturer defect.
Old 12-03-2017, 06:55 PM   #4
Hawk77FT
Drives: GTS 86
Send the picture to them. I am sure they will be able to replace it.
Hawk77FT is offline   Reply With Quote
Old 12-03-2017, 08:25 PM   #5
redlined600
Drives: Fr-s
I can't tell if this is serious or in jest.
They don't owe me anything as I bought it used. It's a easy fix regardless, but as stated above a clear manufacturing mistake.
Old 12-03-2017, 11:33 PM   #6
Hawk77FT
Drives: GTS 86
I reckon you should still send them an email with the picture, to see what they can do for you. Maybe send a replacement bolt or something along those lines.
The Following User Says Thank You to Hawk77FT For This Useful Post:
redlined600 (12-04-2017)
Old 12-04-2017, 12:06 AM   #7
Just in jest ....... I'm very seldom serious here on the forum......
However, I was surprised that they cost so much .....
Old 12-04-2017, 12:07 AM   #8
redlined600
Drives: Fr-s
I wouldn't expect them to do anything but I sent an email on the basis of them upping their quality control.
The rest of it looks nicely machined. I'm a bit disappointed that they chose to modify an off the shelf bolt(which looks like it was done on a manual lathe) rather than make one to spec. I guess that's why CAE shifters are $900.
I'm sure it will be all good once I fix the bolt.
Old 12-04-2017, 06:21 PM   #9
Hawk77FT
Drives: GTS 86
For some reason, people have that perception that if it is expensive it must be well made...in actual fact CAE (and I am not taking anyone's side here really) is using inferior quality stuff...and charges double. IRP has teflon bushing and proper bearings (CAE is aluminium on aluminium and plastic washers)...so you make the call which one is really worth its money and which one isn't! They both good in their own right...but I think CAE is an overpriced product that uses an inferior quality materials to build.
FirstWinter (12-07-2017)
Old 01-04-2018, 01:41 AM   #10
redlined600
Drives: Fr-s
As a follow up to this post, IRP sent me a new bolt. I didn't ask for anything and they certainly didn't owe me a thing yet still went out of their way to ship me a new bolt. Pretty awesome of them.
Old 01-04-2018, 04:30 AM   #11
ryoma
ryoma's Avatar
how hard was it to install lol? I have been thinking about it and read the DIY but it still seems like a PITA.
Old 01-04-2018, 05:43 AM   #12
NRXRaptor
That should be standard, but then again not every manufacturer stands by their product. Vmoda fixed my headphones under warranty and all I did was ship it to them. I have the sneaking suspicion Astro would not do the same. No matter because I have since learned that "gaming" headphones are shite compared to ones made for listening to music, yet they cost the same. Regardless, if a company treats you right I'd stick with them. I'm still leery about this particular shifter because it seems like a rattle machine. My car is 2 years old and already has enough rattles that I didn't introduce myself
NRXRaptor is offline   Reply With Quote
Old 02-26-2019, 02:17 PM   #13
Seanzky
Drives: Slow
Can I get an update from IRP owners regarding the rattle? I'm in the market for one and I really like the IRP short shifter but not if it rattles. With the "fix" from IRP, is the rattle completely gone?
Seanzky is offline   Reply With Quote
Old 02-26-2019, 10:28 PM   #14
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
It was lol
Dr. BRZ is offline   Reply With Quote
forks in shifter issue Flame9020 Issues | Warranty | Recalls / TSB 16 02-18-2017 04:42 PM
shifter issue srgssgtmatt Issues | Warranty | Recalls / TSB 5 09-15-2016 03:01 PM
Short shifter clearance issue with driveshaft Gank61 Engine, Exhaust, Transmission 16 03-08-2016 07:48 AM
shifter issue? abutterman Issues | Warranty | Recalls / TSB 54 02-26-2014 06:10 PM
Issue with Kartboy short shifter tisb0b Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 10-20-2013 07:15 AM
