| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
Drives: 2013 WRB BRZ
Do you park in a garage? If you leave the wheels with TPMS in the garage they will be close enough for the car to pick up. If you only take short trips your light will never come on.
| The Following User Says Thank You to slipdog For This Useful Post: | Tcoat (11-07-2017) |
#16 | |
Drives: 2005 Toyota Camry
You can then get new TPMS for the winter set and go from there. This is also useful if you are running track wheels half the time but still want tire pressure monitoring if you drive the car to/from the track. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | Tcoat (11-07-2017) |
#17 | |
This is yet another reason why not to live in NY! |
| The Following User Says Thank You to sweetpea For This Useful Post: | gravitylover (11-07-2017) |
#18 | |
My BRZ was parked in the garage and the tires were approx. 5' to the passenger side on a wall rack. The lights never turned off. Even when I had the wheels stacked next to the car it still did not reset TPMS. For the 3+ years I had the car I had aftermarket wheels without TPMS for about 2.5 of those years, and I drove the car weekly with the TPMS light always on at startup. |
#19 | |
Drives: nuthin'
#20 | |
#21 | |
#23 | |
We have to get a car safetied when bought used and other than annual emissions tests on vehicles 7 years or older that is it. They don't have to be checked again unless sold.
#24 | |
| The Following User Says Thank You to gravitylover For This Useful Post: | Tcoat (11-07-2017) |
#25 | |||
Drives: 2014 BRZ Limited
The Quickset stores up to four sets of addresses, so if you get a set of track tires with another set of TPMS sensors, you can load those in there also. It even stores five sensors in each bank, so if you're lucky enough to be an Australian with a full sized spare, you can load the spare's TPMS sensor also. I see no reason not to do it unless you're just strapped for cash and don't want to buy the Quickset. Quote:
When I lived in NYC years ago the inspections were a huge scam. Since the inspection stations were also repair stations, they would "fail" people for issues that weren't actually grounds for failing, then offer to repair the problem to help them pass. If inspectors are telling people they'll fail for a TPMS light, I can't help but think this is still happening. Quote:
We have a lot of complaints on the Jeep groups about Pennsylvania. PA inspectors have been known to fail Wranglers for not having doors, when the damned things are made to run without them. They'll fail you for rust in non-structural panels. They'll fail you if your tires extend past your fender flares. My 18x9.5 RPF1s on my BRZ would probably fail in PA because they poke a little in the front. Where I live in Florida we have no inspections whatsoever. Some of the things I see on the road here look like they were put back on the road by Aborigine bush mechanics. |
| The Following User Says Thank You to extrashaky For This Useful Post: | Tcoat (11-07-2017) |
#26 | |
| The Following User Says Thank You to gravitylover For This Useful Post: | Tcoat (11-08-2017) |
#27 | |
When the TPMS light came on in my car when I swapped the sensors, it didn't cause the MIL to illuminate or a DTC to be stored. It just lit up the tire light on the dash. There would be no trouble code to justify a failure, nor would it require 75 miles to clear it. On mine the tire light went off before I got to the end of the street. I remain skeptical. What code did you get when your TPMS wasn't installed? |
#28 | |
I have no idea about stored codes but have been told by numerous shops that it shows up when they plug in. |
| TPMS Question | jmh128 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 03-07-2016 07:29 PM |
| Question about brz/frs tpms compatibility | Evo2Brz | BRZ First-Gen (2012+) — General Topics | 15 | 02-16-2015 02:13 AM |
| TPMS question | damaster32 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 01-25-2014 10:12 AM |
| TPMS Question | Randyliciious | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 10-03-2013 02:03 AM |
| Tire question about TPMS | xdbuix | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 10-10-2012 08:53 PM |
