Old 07-06-2012, 12:20 PM   #29
Roadstercycle
FRS Rear Mount Turbo
Roadstercycle's Avatar
Drives: 2013 FR-S Raven, Rear Turbo
Looks like a good idea. Pull them back out, 86 the gold (pun intended), paint them black and that's a keeper. Again really good idea.
Roadstercycle is offline   Reply With Quote
Old 07-06-2012, 12:26 PM   #30
EsoBOFH
Senior Hoonigan
EsoBOFH's Avatar
Drives: 2016 Hot Lava 6MT FR-S
Originally Posted by ATL BRZ View Post
how?
I just read through the thread that sportsguy83 posted... sounds like air doesn't actually pass through the diaphragm... guess it could be a turbulence issue if it's really effecting a drop in power. Sounds like all the tests were inconclusive though. Anyway.. if you prefer the sound after removing, it's your car so more power to you!
EsoBOFH is offline   Reply With Quote
The Following User Says Thank You to EsoBOFH For This Useful Post:
Sportsguy83 (07-06-2012)
Old 07-06-2012, 12:29 PM   #31
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by EsoBOFH View Post
Well you've got a 1" hose going into the intake, which is now closed up. Hasn't that reduced the intake area?
Unless there is no flow through the noise generator, and it's somehow just operated solely on vacuum.
I'm pretty sure that when the car is running, it's always under vacuum. The intake area is fixed at the tip of the fresh air scoop:
Plugging the noise generator holes doesn't reduce the intake area. It just reduces the turbulence of the air under vacuum going to the throttle body and intake manifold.
I think the resonator can be removed and plugged as well, but you'd have to figure out a way to support the left side of the airbox so it doesn't sag.
The Following User Says Thank You to ATL BRZ For This Useful Post:
EsoBOFH (07-06-2012)
Old 07-06-2012, 12:33 PM   #32
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
No air passes through the noise generator. It's a dead end into a diaphragm "drum". The back of the drum then goes into a tube that connects into the main cabin.
Hawaiian is offline   Reply With Quote
Old 07-06-2012, 12:49 PM   #33
xcelir8brz
Drives: 2013 BRZ Limited
I'll be stopping at Pep Boys this afternoon to see if I can find an 'cap' for removing the resonator to the left of the airbox. From what I can tell, the airbox is still properly supported with the left and right bolts without this 'loose resonator' (riveted and wobbly).
And regarding '86'ing' the gold color and painting it black, I am also planning on doing that later this afternoon as well (or finding caps for these locations as well).
xcelir8brz is offline   Reply With Quote
The Following User Says Thank You to xcelir8brz For This Useful Post:
ATL BRZ (07-06-2012)
Old 07-06-2012, 12:58 PM   #34
Don@Accelerated
Don@Accelerated's Avatar
First Issue we've had. Unlike many of the other people, I won't cover it up. We'll figure it out. Make the people happy and move forward.
-Don
Originally Posted by Swift Racing Technologies View Post
Brian, Let me get this right, you were sold and delivered a prototype unit??? Did AP not do long term tests and watch the ST and LT fuel trims during their R&D phase?
"First to market" is NOT always a good thing.
Don@Accelerated is offline   Reply With Quote
The Following 4 Users Say Thank You to Don@Accelerated For This Useful Post:
Sportsguy83 (07-06-2012), Symbiont (07-10-2012), white devil (07-06-2012), xcelir8brz (07-06-2012)
Old 07-06-2012, 01:20 PM   #35
ATL BRZ
ATL BRZ's Avatar
Originally Posted by xcelir8brz View Post
I'll be stopping at Pep Boys this afternoon to see if I can find an 'cap' for removing the resonator to the left of the airbox. From what I can tell, the airbox is still properly supported with the right bolt without this 'loose resonator'.
Keep us updated!
Old 07-06-2012, 01:35 PM   #36
White64Goat
I noticed that you installed 2 plugs into the factory inlet elbow, one in the hole that goes to the noise generator (towards the left) but what does the 2nd plug in the bottom of the elbow close off?
Old 07-06-2012, 03:48 PM   #37
xcelir8brz
That closed off a tiny little resonator. Didn't show the pic, sorry.
Old 07-06-2012, 03:49 PM   #38
xcelir8brz
-Don
Exactly. Thank you!
Old 07-06-2012, 03:55 PM   #39
xcelir8brz
So, here's the deal. I might as well add to the title of this thread '...and resonator delete', because I made it happen.
I spent about $10 more on parts to remove the large resonator to the left of the airbox. I actually spent more on different parts, but what I'm going to show you is $10.00 more (minus some black high temp paint on hand as well as a 2.25" band clamp).
After doing this mod, the intake sounded better (less whimpy sounding), the exhaust was a bit louder, and no kidding, I felt the low end (i.e. no matter what I did I ended up chirping the rear tires). By no means did I receive any 'growl' but overall the stock modified system sounds pretty darn good now!
It all started with lightly drilling out the top of two rivets and wala, the resonator came out.
See the pix below:
And a very clean engine...
You can visit my web site to see higher resolution shots if you need to.
Old 07-06-2012, 04:01 PM   #40
xcelir8brz
Painted black. See revised post.
Old 07-06-2012, 04:07 PM   #41
ATL BRZ
ATL BRZ's Avatar
Thanks for the pics of the resonator delete! Looks much cleaner under the hood! I'll def be deleting the noise generator and the resonator when I get my BRZ at the end of July!
Old 07-06-2012, 04:17 PM   #42
ATL BRZ
ATL BRZ's Avatar
After looking at it again, I doubt you even need the expansion plug for the resonator delete. I think it would be sealed fine with just the hitch ball hider and a hose clamp.
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Removing and Replacing BRZ/FR-S Intake, Air Filter and Noise Generator Delete GrimmSpeed DIY (Do-It-Yourself) Guides 99 01-25-2015 01:24 AM
rattling noise in the trunk ayetothejay Scion FR-S / Toyota 86 GT86 General Forum 2 06-26-2012 11:19 PM
HID noise Carlsbad BRZ First-Gen (2012+) — General Topics 6 06-20-2012 12:39 AM
Strange noise Random_Art Other Vehicles & General Automotive Discussions 15 06-03-2011 03:31 PM
