Old 10-14-2017, 09:03 PM   #1
Mithosphere
Fart-noise maker
Mithosphere's Avatar
Drives: 2014 Scion FR-S
Bazooka 8" Powered Subwoofer Issue
I recently purchased a Bazooka BTA8100FHC 8" powered subwoofer and followed this thread to install it. Installing it went fine, very easy and straightforward.
Once everything was hooked up though, I noticed the sound on the subwoofer seemed a little wonky...
With the trunk closed, I can only hear that odd vibration when the heavy bass stops. I've not had this issue with any other system in any other car. IT functions normally and sound fine to me in the car with the trunk closed, but when I open the trunk and listen to the sub, like in the video above, all I can hear is that feedback-like sound.
Here's the caveat:
It's a refurbished unit that I bought for almost half off - the previous owner looks to have cut the positive and negative wires for the FAST harness. I spliced these together with some wire nuts. I then routed the wiring down the passenger side of the car along the door sill.
Before I return it, what might be another cause for the issue?
Mithosphere is offline   Reply With Quote
Old 10-14-2017, 11:22 PM   #2
Gunman
Drives: 2019 Mazda Miata RF
Move it closer into the corner. 2-4 inches away, and see if that helps.
Old 10-14-2017, 11:49 PM   #3
Mithosphere
Fart-noise maker
No difference.
Only when I apply pressure to the foam surround does the bass sound like it should without that weird rattle/vibration/feedback.
I'm under the impression that it's broken on the inside.
I ordered a new one, which should be here by Tuesday. I'll try it with the new subwoofer and existing wires, then the new wiring and old refurb, then all new.
Old 10-15-2017, 12:01 AM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
That sub is blown.
replace it.
That sound is the voice coil rubbing against the magnet shaft. The only other way that could happen is if was dropped so hard the magnet moved out of alignment.
If you know anything of what fried electrical smells like take a good sniff. It's it's smelled burnt, well there's your answer. If I'm not mistaken those subs are duel voice coils, so one coil could have got toasted.
The Following User Says Thank You to Mr.ac For This Useful Post:
Mithosphere (10-15-2017)
Old 10-15-2017, 12:13 AM   #5
Mithosphere
Fart-noise maker
That sub is blown.
replace it.
Thank you!
I was just about to post my youtube searches regarding blown subs. Found a couple that sounded exactly like my issue.
Old 10-18-2017, 10:00 PM   #6
Mithosphere
Fart-noise maker
Angry
Right, so I purchased another one - new this time - but after connecting all the wires, grounding it, and ensuring it had power.... nothing.... LED indicator won't light up, unit won't power on. Not going to be buying another Bazooka tube again.
So it too is being returned!
I get to dismantle the passenger side for the third time tomorrow and then tape over the holes left by the FAST harness.
Old 10-19-2017, 01:18 AM   #7
DAEMANO
Time Traveller
Have you considered the BRZ 10" OEM Kicker sub (comes with it's own amp)? It's a little more work to install, but everyone that buys one seems to like it. I have one to install myself, just waiting for a full day.
https://parts.subaru.com/p/Subaru__/...630SCA000.html
Old 10-20-2017, 10:59 AM   #8
RickyBobby
Drives: 2013 Firestorm FR-S AT
After 1 1/2 years my Bazooka BT8100FCH stills sounds great. After a few Tail of the Dragon runs I added a couple of velcro strips between the floor mat and the trunk foam blocks for extra stability. http://www.homedepot.com/p/VELCRO-Br...0199/202261921
Sounds like your first sub was fubar.
I'm assuming you are using their FAST-9999 harness which comes in 2 parts. With a multimeter, and with the key on in the accessory position, check the positive pin side, red cable, of part 1 that connects to your HU for 12V to see if that's connected correctly, use one of the HU chassis screws/bolts as a ground for the multimeter.
If yes, then connect it to part 2, the long cable that plugs into the sub, and with a multimeter check that the corresponding ground and 12V pins on the connector (see pic) are getting 12V. If no, check your ground wire connection.
If yes, then when you connect part 2 to your sub, with the key on in the accessory position, the green LED should be on. Also make sure that the connector is fully seated on the sub.
RickyBobby is offline   Reply With Quote
Old 10-23-2017, 12:51 AM   #9
Mithosphere
Fart-noise maker
I need the space in the trunk, so I need something that's easily removable. I haul a rather giant instrument once a week that takes up the back seat and the trunk - all of it.
I may place a sub in the back seat, somehow figure out how to strap it into the factory baby seat mounting locations.
Old 10-23-2017, 02:13 AM   #10
Kaotic Lazagna
Drives: GR Corolla
Very weird. I have the 50w version in the FR-S (OEM HU) and the 100w version in the Yaris (Kenwood Excelon HU). Both work great. Are you sure you're tapping into the 12v power wire, and if so, are you making a successful puncture?
Also, if you've lengthened the ground wire, reverse it and make it the original length again.
Old 11-01-2017, 05:58 PM   #11
PCR92
Drives: White GT86
What are your thoughts in general with the Bazooka subwoofer? I was strongly thinking about putting one in my GT86 but JL Audio seems to be raved about as the recommended subwoofer to buy.
I would probably install it like the image below
PCR92 is offline   Reply With Quote
Old 11-01-2017, 10:27 PM   #12
CraigVM
Drives: Car Collector
Options
With the first blown bazooka, You can pick up a replacement driver for around $60.
I completely understand wanting to be able to pull out a sub / enclosure and have every inch of your trunk space available. For that reason I installed a very small NVX MVPA1 amp that easily mounts in the back of my glove box. That way I just have to pull the sub / enclosure with nothing but a speaker wire left that I can easily tuck out of the way.
CraigVM is offline   Reply With Quote
Old 11-02-2017, 02:50 PM   #13
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
I have a Powered Bazooka in my trunk and it sounds good and has decent bass, but I much prefer the look of the OEM audio one if it was not so expensive. Depends on what ya want I guess.
22R
22R is offline   Reply With Quote
Old 11-02-2017, 03:45 PM   #14
DAEMANO
Time Traveller
The OEM Subaru Kicker 10" has a speed knob and front bracket intended to allow you to pull the box out whenever you need the space very easily. Still it holds the sub in place securely when driving hard. In the install video below it's shown at about 8:15 mark.
[ame="https://www.youtube.com/watch?v=gZndLMZlNEU"]losmt2 - Subura BRZ / Scion FRS Factory Sub Install - YouTube[/ame]
And also in the upper left of this pic
DIY: Installation of a Bazooka BT8100FCH Subwoofer to a Bespoke/Pioneer PT546-00140 RickyBobby DIY (Do-It-Yourself) Guides 6 07-17-2016 03:27 PM
Powered 100 watt 8 inch bazooka install with fast 1761. HELP!! Leight1104 Cosmetic Modification (Interior/Exterior/Lighting) 4 02-19-2016 12:19 AM
Powered 100 watt 8 inch bazooka install with fast 1761. HELP!! Leight1104 DIY (Do-It-Yourself) Guides 2 02-18-2016 04:30 PM
Subaru - 10" powered subwoofer by Kicker(H630SCA000) Gothenburg 07 Audio/Visual, Electronics, Infotainment, NAV 2 01-15-2015 12:24 AM
Powered subwoofer under driverseat Gofrs Electronics | Audio | NAV | Infotainment 24 04-29-2014 10:27 AM
