Old 02-18-2016, 03:32 PM   #1
Leight1104
Leight1104's Avatar
Drives: 15 asphalt FRS
Powered 100 watt 8 inch bazooka install with fast 1761. HELP!!
My friend and I tried installed the aforementioned sub in my car with the fast harness. The sub turned on and played but not as much as you'd expect an 8 inch sub. Anyone else ran into this? If so what'd you do to get the full power?
Leight1104 is offline   Reply With Quote
Old 02-18-2016, 03:44 PM   #2
swarb
Which model? link?
From what I found-
It's 100watts MAX.
so probably ~50ish watts rms.
50watts isn't much to begin with.
Play with the crossover settings.
Take a pic of the back of the amp.
How many amps is the fuse?
The only idea I have is to boost the signal.
Again, 50watts is not much to begin with.
And post in the right section. http://www.ft86club.com/forums/forumdisplay.php?f=27
Old 02-18-2016, 04:31 PM   #3
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
IceFyre13th is offline   Reply With Quote
Old 02-18-2016, 08:44 PM   #4
Gunman
Drives: 2019 Mazda Miata RF
Is the bazooka pointed into a corner? the loose a lot of efficiency if not corner loaded
Gunman is offline   Reply With Quote
Old 02-19-2016, 12:19 AM   #5
Kaotic Lazagna
Drives: GR Corolla
I just installed the BTA850FH in mine. I first tapped into the rear speaker wires. Didn't sound too impressive. I eventually switched to the front speakers, and it's such a huge difference. I guess these tubes require full range signal, and the rear speakers are high pass filtered.
With that said, where did you tap into? Also, where did you ground it? Furthermore, I have the tube firing rearward and the port up top.
Powered 100 watt 8 inch bazooka install with fast 1761. HELP!! Leight1104 DIY (Do-It-Yourself) Guides 2 02-18-2016 04:30 PM
2015 BRZ Limited - Install Powered Sub, retaining stock HU johnjc2145 Electronics | Audio | NAV | Infotainment 8 08-22-2015 09:41 AM
shop to install a self powered subwoofer Speed2th Southern California 1 04-17-2015 10:48 AM
Anyone local to NY-Long Island interested in a Bazooka 100 Watt 8-Inch Sub? Foobar NY / NJ / CT / PA 0 12-02-2014 12:19 PM
MACBOOK PRO 13 inch with 8GB RAM and SAMSUNG EVO 250GB SSD SUPER FAST!! eurominican Miscellaneous 0 10-10-2014 06:04 PM
