Southern California SoCal
Old 10-12-2017, 12:46 AM   #1
vin08
275/1000
Drives: 2016 RS2 auto
Check engine light came on after loading OTSv2.76
Hi guys/gals,
I need help please. I just got my OFT and loaded OTS v2.076\BINs\ZA1J_D ROMS (US 6AT)\Stage 1 - 91oct on my 2016 with auto transmission and I can only get 91 octane where i live. My check engine light came on and my idle is at around 6k and the engine start knocking on me. Is anyone havng this problem or know how I can fix it? My ECU show no fault even with the check light on. Car is stock other then a Injen cold intake SP1230.
vin08 is offline   Reply With Quote
Old 10-15-2017, 04:03 AM   #2
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Wtf 6k idle??
Decimus is offline   Reply With Quote
The Following 3 Users Say Thank You to Decimus For This Useful Post:
D_Thissen (10-15-2017), Somerandom18 (10-15-2017), Teseo (10-15-2017)
Old 10-15-2017, 11:02 AM   #3
D_Thissen
D_Thissen's Avatar
Originally Posted by vin08 View Post
Hi guys/gals,
What was the code?
Old 10-15-2017, 03:34 PM   #4
vin08
275/1000
sorry. 500rpm rough idle. But it all good after driving it around town for about 30mins or so.
Old 10-15-2017, 03:35 PM   #5
vin08
275/1000
Originally Posted by D_Thissen View Post
What was the code?
P0700, but gone away after driving it around tow for about 30mins.
Old 10-15-2017, 08:29 PM   #6
D_Thissen
D_Thissen's Avatar
I think that's a trans related code.
The Following User Says Thank You to D_Thissen For This Useful Post:
vin08 (10-17-2017)
Old 10-15-2017, 10:31 PM   #7
JoeeStacks
Drives: Brz
After flashing tunes, it helps to clear any codes that could occur. I had some random CELs after flashing OFT tunes and clearing the code before starting the car helps. One time I had a fuel pump issue after flashing back to stock. Cleared the code and it never came back.
Now I'm on ecutek and they recommend clearing any codes / dtc after any flash.
Daily Project: Honda s2000
Track: 707 WHP Turbo Honda Civic EG
Old: Kraftwerks Supercharged Subaru Brz
JoeeStacks is offline   Reply With Quote
The Following User Says Thank You to JoeeStacks For This Useful Post:
vin08 (10-17-2017)
Old 10-17-2017, 09:00 PM   #8
vin08
275/1000
So whats difference between ecutek and OFT?
Old 10-17-2017, 10:10 PM   #9
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Almost Everything. Ecutek are used by tuners for custom tunes. OFT is used for mainly off the shelf tunes. Although oft can be used for custom tunes, it's less popular than ecutek.
The Following User Says Thank You to Decimus For This Useful Post:
vin08 (10-17-2017)
Old 10-22-2017, 01:36 PM   #10
jupillam
jupillam's Avatar
Drives: White out Scion Frs
Its normal, just does that to only AT transmission. Dont worry and have fun driving.
jupillam is offline   Reply With Quote
The Following User Says Thank You to jupillam For This Useful Post:
vin08 (10-22-2017)
Old 10-22-2017, 03:57 PM   #11
vin08
275/1000
I just bought a open flash UEL also so it's coming together now.
Check engine light came on after loading OTSv2.76 vin08 Software Tuning 2 10-12-2017 02:05 AM
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 09:39 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
