Old 10-17-2017, 03:51 PM   #15
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
Originally Posted by TwistedGray View Post
Nope, didn't even think about that. I hadn't touched it in 200ish miles actually.
Check that. It won't reset immediately and requires a few drive cycles but that could very well be the case. Also pop open your hood and make sure all the fluids have their caps on secure.
Good luck my guy Take that car over to Autozone and get the code read and throw us that code and we'll crack down on it. Autozone does it for free and prints it out for you, takes them like 5 minutes.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
Old 10-17-2017, 03:52 PM   #16
TwistedGray
IG thomas50shades
Drives: ISO: BRZ
See my previous post
We must have been posting at the same time.
TwistedGray is offline   Reply With Quote
The Following User Says Thank You to TwistedGray For This Useful Post:
VoltsFRS2013 (10-17-2017)
Old 10-17-2017, 03:55 PM   #17
VoltsFRS2013
UPDATE - Went to AutoZone and used theirs. It came back
Note: After their reader was done the CEL went away. I've since started, stopped, driven, etc several times and it has not come back.
Going to assume that the repair is going to be on the cheaper spectrum of things and under warranty if you have one considering it's ignition related. Could be much worse so I'd let out a huge sigh of relief
Call up your local dealer and see what they say.
Old 10-17-2017, 03:58 PM   #18
TwistedGray
IG thomas50shades
Drives: ISO: BRZ
A quick Google unearthed a whole thread on this code - http://www.ft86club.com/forums/showt...=30879&page=32
Old 10-17-2017, 04:57 PM   #19
DarkSunrise
DarkSunrise's Avatar
That's odd - I've read and cleared the P0351 code with my OFT in the past. Wonder why your's is different?
2022 BRZ Build
2013 FR-S Build
Old 10-17-2017, 05:10 PM   #20
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Because he/she hasn't flashed their car with OFT yet.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
DarkSunrise (10-17-2017)
Old 10-17-2017, 05:14 PM   #21
DarkSunrise
Ah ok that makes sense.
2022 BRZ Build
2013 FR-S Build
Old 10-17-2017, 05:36 PM   #22
-Willis-86touge
Drives: Stock
I think it's just a glitch. Sometime when you plug it in, I believe the a short and it send weird signal to your pcm. On two different occasions I plug it in and had check engin lights. This worried me as well. Also on about three diffent times I plugge it in and my air conditioner wouldn't work and all my lights were lit up including traction, wheel sensors, engine light, basically any and everything. So I turned it off and re flashed and everything went away. And no lights or anything for months then of course one day I would get in a rush and plug it in and then shit would go haywire again.
-Willis-86touge is offline   Reply With Quote
Old 10-17-2017, 05:43 PM   #23
Icecreamtruk
Drives: Track preped NA FRS
P0351 is not a glitch, or a one of. Very recurrent problem, altho very minor. Keep driving and enjoying the car. It will come back at some point and go away on its own. Overtime it will happen more frequently. Eventually you will have to swap that coilpack (its the easier one to swap, no need to lift the engine, but you need flexible hands). If you track the car or "drive spirited" often in hot weather, it will come on during it. You can keep pushing the track. I've pushed on a bad coilpack for 3 track days (2 of them back to back) and even tho you lose a bit a power, nothing else happens, the car just runs a tiny bit richer. Welcome to the club of "I eat coilpacks for breakfast club".
Icecreamtruk is offline   Reply With Quote
The Following 2 Users Say Thank You to Icecreamtruk For This Useful Post:
strat61caster (10-17-2017), TwistedGray (10-17-2017)
Old 10-17-2017, 07:05 PM   #24
TwistedGray
IG thomas50shades
Drives: ISO: BRZ
Lol, "I eat coilpacks for breakfast"
Old 10-17-2017, 10:21 PM   #25
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
That would not result in P0351 and is a separate issue.
ineedyourdiddly
Old 10-18-2017, 06:05 AM   #26
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Do you have a header with no heat shielding or uncoated?
guybo is offline   Reply With Quote
Old 10-18-2017, 11:37 AM   #27
-Willis-86touge
Drives: Stock
Not sure if your talking to me or the guy who started the post but as for me no. But recently I did find out I had a big hole in one of my resonators because it had been rubbing on my crank pully so maybe that had some to do with it. Like I said in a another post I urg everyone to check theirs too. It's seems that the intake it self slowly rotates or vibrated enough that the resonator leans back!
Old 10-18-2017, 11:41 AM   #28
-Willis-86touge
Drives: Stock
I had the code po171. This is not not mine but another's pic, but mine looked almost identical.
Issues with my 86 please help belleh Issues | Warranty | Recalls / TSB 11 12-14-2016 07:45 AM
K&N CAI issues. All help welcome Matty B Engine, Exhaust, Transmission 6 11-01-2015 05:22 PM
So more issues. bdanisi Issues | Warranty | Recalls / TSB 40 12-03-2014 04:30 PM
Oft e85 issues sosick Software Tuning 14 05-22-2014 06:40 PM
more issues after CEL fix.. DrewZ926 Issues | Warranty | Recalls / TSB 2 11-07-2012 09:15 PM
