| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#29 |
Only users lose drugs.
Drives: All the time
That much, I can guarantee.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#30 |
[insert cool phrase here]
Drives: BRZ Premium
See, way to much headaches trying to Frankenstein them to fit.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#31 | |
Drives: Impretzal
#32 | |
Time Traveller
| The Following User Says Thank You to DAEMANO For This Useful Post: | MyNameIsCacauate (10-11-2017) |
#33 |
Kouki-Monster
Post pictures when you shoot the wheel across a freeway
Rich Anderson
EMPOWER AUTO |
| The Following User Says Thank You to empower-auto For This Useful Post: | venturaII (10-16-2017) |
#34 |
Drives: Impretzal
#35 |
Kouki-Monster
If you can get that photo too I'll be doubly impressed ya whinge
Rich Anderson
EMPOWER AUTO |
#36 |
Drives: 15 BRZ LTD, 05 FXT
Bolt on spacers are okay, I run 20mm bolt on spacers square.
That said, if you can find 25mm slip ons, I suggest sticking with those and ARP studs. It's a strong assembly with less failure points. Just because something is hub centric, doesn't mean the three brands worth of different tolerances will actually work well once you've stacked X, Y, and Z together. It's a recipe for vibration. There's a shop near me that will custom make a single spacer to any size, and they are CNC'd to interlock with whatever pockets/grooving your wheel has, so they spin true and actually are like a custom hub centric + locking ring. You may be able to find a local service like that. (They will also cut a wheel's hub back to lower the offset and bring a poking wheel in for you.) I think there are a few options for you, the PBM's will get you close and are a good solution since it's one brand and it's hubcentric. I hope they work well for you.
| spacer, stud clearance on rota GRA | balci | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 03-24-2017 04:54 PM |
| Lug nuts, spacer, ARP extended wheel stud, camber bolt, fumoto drain valve | Jesse0923 | Brakes, Suspension, Chassis | 1 | 10-05-2016 12:48 PM |
| Lug nuts, spacer, ARP extended wheel stud, camber bolt, fumoto drain valve | Jesse0923 | Wheels and Tires | 0 | 10-01-2016 09:50 PM |
| H&R DRS Spacer (3025560) Stud installation question | Dihudaxia | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 10-19-2015 09:16 PM |
| Spacer question | Midnight Dream 86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 01-26-2014 09:37 PM |
