Old 10-08-2017, 05:21 PM   #29
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by MyNameIsCacauate View Post
. guess were not on the same level ☺.
That much, I can guarantee.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 10-08-2017, 11:07 PM   #30
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
See, way to much headaches trying to Frankenstein them to fit.
Old 10-10-2017, 12:22 AM   #31
MyNameIsCacauate
Drives: Impretzal
Originally Posted by DAEMANO View Post
1. Yes, much better as you get the all the advantages of stronger aftermarket extended studs I noted above.
2. You possibly could find a 35mm slip on, but a more flexible route would be to get a stackable kit like the 30mm one Parts Shop Max sells. Just make sure that your spacers are hubcentric and are made to lock together. I also agree that 35mm is a lot of spacer, but for some body kits and applications extremely low offsets are required.
https://store.partsshopmax.com/shop/...-5-125-56.html
I went ahead and purchased 2 pairs of 30mm stackables for the front and back. Considering many run work meisters with spacers, I believe the 35mm measurement may have been wrong for the stock studs.
MyNameIsCacauate is offline   Reply With Quote
Old 10-10-2017, 01:58 PM   #32
DAEMANO
Time Traveller
Post your results. Hope it works out just as you imagined.
The Following User Says Thank You to DAEMANO For This Useful Post:
MyNameIsCacauate (10-11-2017)
Old 10-16-2017, 02:12 PM   #33
empower-auto
Kouki-Monster
empower-auto's Avatar
Post pictures when you shoot the wheel across a freeway
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
The Following User Says Thank You to empower-auto For This Useful Post:
venturaII (10-16-2017)
Old 10-16-2017, 02:28 PM   #34
MyNameIsCacauate
Drives: Impretzal
sure thing buddy, I'll also snap one with your mums snatch in me mouth
Old 10-17-2017, 04:53 PM   #35
empower-auto
Kouki-Monster
If you can get that photo too I'll be doubly impressed ya whinge
Rich Anderson
EMPOWER AUTO
Old 10-23-2017, 10:55 AM   #36
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Bolt on spacers are okay, I run 20mm bolt on spacers square.
That said, if you can find 25mm slip ons, I suggest sticking with those and ARP studs. It's a strong assembly with less failure points. Just because something is hub centric, doesn't mean the three brands worth of different tolerances will actually work well once you've stacked X, Y, and Z together. It's a recipe for vibration.
There's a shop near me that will custom make a single spacer to any size, and they are CNC'd to interlock with whatever pockets/grooving your wheel has, so they spin true and actually are like a custom hub centric + locking ring. You may be able to find a local service like that. (They will also cut a wheel's hub back to lower the offset and bring a poking wheel in for you.)
I think there are a few options for you, the PBM's will get you close and are a good solution since it's one brand and it's hubcentric. I hope they work well for you.
JazzleSAURUS is offline   Reply With Quote
spacer, stud clearance on rota GRA balci Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-24-2017 05:54 PM
Lug nuts, spacer, ARP extended wheel stud, camber bolt, fumoto drain valve Jesse0923 Brakes, Suspension, Chassis 1 10-05-2016 01:48 PM
Lug nuts, spacer, ARP extended wheel stud, camber bolt, fumoto drain valve Jesse0923 Wheels and Tires 0 10-01-2016 10:50 PM
H&R DRS Spacer (3025560) Stud installation question Dihudaxia Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-19-2015 10:16 PM
Spacer question Midnight Dream 86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 01-26-2014 10:37 PM
