Old 10-07-2017, 05:23 AM   #1
MyNameIsCacauate
Drives: Impretzal
Stud trimming with spacer question
I have a set of wheels that don't have the extra holes for spacers. I'm planning on running 35mm spacers on some s1 3p for the rears(since the studs are about 35mm wouldn't need to trim). However, my fronts are going to be 20mm spacers, how am I gonna go do this isn't it unsafe to trim 15mm's of the stud?
MyNameIsCacauate is offline   Reply With Quote
Old 10-08-2017, 01:22 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Honestly sell those wheels, buy ones with the proper offset. No extra work, no lame spacers. No worrying about frankinstine set ups.
save yourself the headache.
Old 10-08-2017, 01:46 AM   #3
MyNameIsCacauate
Drives: Impretzal
Considering relipping it right now to the proper offset, I just want something temporary. By the way, the stock studs are 35mm right? Wanted to double check.
Old 10-08-2017, 01:59 AM   #4
DAEMANO
Time Traveller
Actually, I'd recommend changing the studs to stronger extended aftermarket studs (ARP). This gives you flexibility to run whatever wheels or slip on spacers you want while helping to ensure your studs don't break easily.
Sadly, the stock studs are short and notorious for breaking if mishandled at all. You simply cannot guarantee that everyone that takes your wheels off are going to reinstall them without over-torquing your lugs.
Running a spacer is not some act of evil. Many people with BBKs have to run them to get caliper clearance on lower offset wheels. I've run spacers on extended studs for years on my car with no issues whatsoever.
The Following User Says Thank You to DAEMANO For This Useful Post:
Tristor (04-18-2018)
Old 10-08-2017, 02:12 AM   #5
MyNameIsCacauate
Drives: Impretzal
How would I go with extended studs if my wheels have no pockets in them? Isn't the point of shaving studs to match the length of the spacer if you're lacking pockets?
Old 10-08-2017, 04:05 AM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
MyNameIsCacauate: there are slip on spacers, studs simply go through. But to have enough thread for secure mount of lugnut you have your extra length of extended aftermarket ARP stud.
Old 10-08-2017, 04:17 AM   #7
MyNameIsCacauate
Drives: Impretzal
I'd rather stick to bolt on spacers considering 35mm is quite large, wouldn't want to make my ride anymore dangerous that it needs to.
Old 10-08-2017, 04:39 AM   #8
MyNameIsCacauate
Drives: Impretzal
Would extended studs and slip-ons be a better alternative to a 35mm bolt on?
Old 10-08-2017, 04:44 AM   #9
MyNameIsCacauate
Drives: Impretzal
just did a little more research! thanks for the output I think I'm going to go this direction! but are there any 35mm slip-ons?
or do I buy one of those project kics 30mm wide tread spacers that come with studs already, remove those studs and use ARP extended lugs. Is that how this works?
Old 10-08-2017, 05:14 AM   #10
MyNameIsCacauate
Drives: Impretzal
doesn't seem like 35mm slip on's exist, well good ones at least.
Old 10-08-2017, 05:46 AM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
MyNameIsCacauate: i somehow missed bit of 35mm. Of course you can put multiple spacers for total thickness of that, but 35 is a bit on high side, with such i'd probably go for bolt-on ones. With 20-25 i'd consider both types, below - slip ons.
Old 10-08-2017, 05:50 AM   #12
MyNameIsCacauate
Drives: Impretzal
Which brings me to my original point. How am I going to run bolt-on spacers if my wheels have no pockets in them?
Old 10-08-2017, 06:17 AM   #13
DAEMANO
Time Traveller
1. Yes, much better as you get the all the advantages of stronger aftermarket extended studs I noted above.
2. You possibly could find a 35mm slip on, but a more flexible route would be to get a stackable kit like the 30mm one Parts Shop Max sells. Just make sure that your spacers are hubcentric and are made to lock together. I also agree that 35mm is a lot of spacer, but for some body kits and applications extremely low offsets are required.
https://store.partsshopmax.com/shop/...-5-125-56.html
Old 10-08-2017, 06:23 AM   #14
MyNameIsCacauate
Drives: Impretzal
Never heard of these, considering them atm. Debating between them and the h&r bolt on.
spacer, stud clearance on rota GRA balci Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-24-2017 04:54 PM
Lug nuts, spacer, ARP extended wheel stud, camber bolt, fumoto drain valve Jesse0923 Brakes, Suspension, Chassis 1 10-05-2016 12:48 PM
Lug nuts, spacer, ARP extended wheel stud, camber bolt, fumoto drain valve Jesse0923 Wheels and Tires 0 10-01-2016 09:50 PM
H&R DRS Spacer (3025560) Stud installation question Dihudaxia Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-19-2015 09:16 PM
Spacer question Midnight Dream 86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 01-26-2014 09:37 PM
