Old 10-04-2017, 12:22 AM   #29
Originally Posted by MyGT86Yas View Post
No it's not my 1st manual car. The new foreman concluded that it wasn't a fault transmission but engine. Even though they have the engine pulled out for inspection but they still couldn't find out what the problem is They just hope the new engine will fix it.
Maybe if they hook an AT to the new engine .......that would solve all your problems .......
Old 10-04-2017, 12:30 PM   #30
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
I'm still quite confused where the actual problems are on OP's car? I've still yet to read anything regarding mechanical failure or even hindrance.
HKz is offline   Reply With Quote
Old 10-04-2017, 05:59 PM   #31
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
It makes a 'click' on acceleration as described in post #11
could be an axle nut or catastrophic engine failure, guess the dealership decided to replace the engine
ineedyourdiddly
Old 10-05-2017, 12:35 AM   #32
MyGT86Yas
Drives: 2017 WRB BRZ
You can go back to see #1 post. I updated it and put the whole story there.
MyGT86Yas is offline   Reply With Quote
The Following User Says Thank You to MyGT86Yas For This Useful Post:
strat61caster (10-05-2017)
Old 10-05-2017, 02:48 PM   #33
HKz
Reformed
HKz's Avatar
still confused how your tranny issues had anything to do with the engine. just difficult to see it being an issue with a facelifted 86 and not user error. too bad you don't have a video showing of you shifting "normally" and showing the stick popping out.
Old 10-05-2017, 05:38 PM   #34
strat61caster
Sounds like it had nothing to do with it at all. Engine replacement is for other noises.
Thanks for the clarification and documenting this awful process. Your problems are odd, a few are normal operation like #2, #6, & #7 (#7 patiently explained by Ultramaroon twice) but popping out of gear and abnormal noises (within reason) are certainly not.
Does the car have a short shifter in it? The TRD short shifter is known to be problematic and improper install can screw up shifting noticeably.
You'll have to be patient with the skepticism, I've never seen anyone claim to have an 86 that's popped out of gear and I've beat the hell out of mine without repercussion as have many others. Abnormal noises come and go, it's hard to tell what's going on based on text description alone.
Get that foreman and tech a case of beer when your car is healthy again, they're going the extra mile to get your car fixed even if we're all skeptical of what the hell is going on with your car.
ineedyourdiddly
Ultramaroon (10-06-2017)
Old 10-05-2017, 09:58 PM   #35
MyGT86Yas
It could be two separate problems, the clicking noise and the transmission issue. I'm pretty positive that the transmission problems (shifter pop out, can't shift into gear when in speed) were caused by the spring that was found loose in the 1st repair. My guess was when they replaced the transmission in the 2nd repair the spring got messed up again, or it just has bad design
Old 10-05-2017, 10:08 PM   #36
MyGT86Yas
No, it doesn't have a short shifter. The whole powertrain and transmission system is stock.
This foreman in Orange is super nice and helpful. He did take an extra mile to help me on this issue. He spent half an hour test driving with me to hear the noises that I was complaining about
Old 10-06-2017, 02:44 PM   #37
Much better rundown in your update. If we're talking about the retaining clips for the throwout bearing, The loose spring theory makes sense. Drawing a mental line between cause and effect, I can see where a loose one could allow the fork to knock back and cause some sponginess. Then it becomes a simple case of dragging clutch.
I just hope you get it all worked out. You have some great support in that dealership you're with. I agree with Strat that a case or two of beer is in order after the dust settles.
Old 10-15-2017, 05:15 PM   #38
MyGT86Yas
I talked to the foreman last week and the latest information I got was:
The head casing was inspected and pressure tested and will be re-used in the new engine.
Other than that part, all other parts are new (block and the upper half) and the whole engine is assembled at the dealership.
I was told that they should have the car ready and thoroughly inspected by tomorrow, will let you guys know if that actually fix the problem.
Old 10-15-2017, 11:17 PM   #39
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
Good luck and please let us know how things go. Out of curiosity, what is your age?
RJasonKlein is offline   Reply With Quote
Old 10-17-2017, 12:08 PM   #40
MyGT86Yas
They broke the injector seals when assembling the engine. If the injectors are not in back order I should have the car back tonight...should...
Old 10-17-2017, 12:16 PM   #41
MyGT86Yas
Not sure if this is something I should worry/complain about, I can clearly see the carbon build-up in the head casing (they told me they gonna reuse it) but I was told it was supposed to be a brand new engine...
Old 10-17-2017, 10:17 PM   #42
MyGT86Yas
And Toyota decided to lemon my car
Ultramaroon (10-17-2017)
Engine/Transmission noise N1rve Issues | Warranty | Recalls / TSB 48 05-06-2018 10:17 PM
17' manual transmission noise dostoyevsky Issues | Warranty | Recalls / TSB 16 04-15-2017 03:49 AM
Transmission Grinding Noise RedFR-s Issues | Warranty | Recalls / TSB 18 07-06-2016 02:18 PM
Automatic transmission noise. zxzr750 Engine, Exhaust, Transmission 0 10-21-2014 05:58 PM
transmission noise when reaching 23-25m/h Mokiki Issues | Warranty | Recalls / TSB 7 05-09-2013 09:13 PM
