Old 04-14-2017, 01:07 PM   #1
dostoyevsky
Drives: 2017 BRZ
17' manual transmission noise
Hey guys, small question, my 2017 BRZ makes a weird noise when I put it into gear sometimes (the clutch is not engaged) like I can feel it move under the car and hear the gears pretty loudly. Sometimes the transmission kicks under the car, any idea if this is normal?
dostoyevsky is offline   Reply With Quote
Old 04-14-2017, 01:22 PM   #2
humfrz
It's a manual transmission ..... it sits at your feet ...... it's shielded from the cabin by tin foil ..... most likely, what you are hearing is ..... "normal".
If it bugs you, I suggest you go drive another one to compare how it sounds .....
humfrz
Old 04-14-2017, 01:41 PM   #3
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
Just going into place is all. Our shifter is connected directly to the transmission and our transmission can be noisy. All the weird sounds i hear in this car i train my mind to think of as racecar sounds, helps ease the paranoia that something may be broken. If something ever does break, gives you physical symptoms, or serious audible symptoms, you still have warranty.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Old 04-14-2017, 02:19 PM   #4
Teseo
Drives: frs
Totalled.
Dibs on Final Drive gear
Old 04-14-2017, 02:30 PM   #5
Da Brz
Drives: 2016 Subaru BRZ
Every manual transmission is different. I've found ours to be pretty rough and noisy. I normally don't have to slam gears when I'm hot rodding. But this car seems to require it or you'll miss a gear.
Da Brz is offline   Reply With Quote
Old 04-14-2017, 02:44 PM   #6
Somerandom18
Drives: 2017 manual BRZ
If you accelerate at low rpm it will make a sort of clanking noise this is normal. As for the kicking that's driver error and take setting used to.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 04-14-2017, 02:51 PM   #7
Tokay444
Anti stance.
Tokay444's Avatar
What's an 17 foot manual transmission? Maybe that's part of the problem.
Old 04-14-2017, 03:39 PM   #8
dostoyevsky
Drives: 2017 BRZ
How is shifting into gear driver eror? What could I be doing wrong?
Old 04-14-2017, 04:23 PM   #9
Somerandom18
This car's transmission is touchy and you have to be very precise when shifting otherwise it will jerk.
Old 04-14-2017, 04:54 PM   #10
Ultramaroon
not playing cards
Ultramaroon's Avatar
It's normal.
There's enough spinning mass on the input side that for some time after you disengage the clutch it spins until the synchro grabs it.
Old 04-14-2017, 04:55 PM   #11
spike021
spike021's Avatar
I'll admit I was hella imprecise this morning on my way to work and jerked _a lot_.
But yeah, practice till it's smooth, OP.
On my good days and drives it feels just like an auto with no jerk.
spike021 is offline   Reply With Quote
Old 04-14-2017, 05:24 PM   #12
Somerandom18
Practice makes perfect.
Old 04-14-2017, 05:54 PM   #13
humfrz
Maybe his transmission swap was overkill ......
humfrz
Old 04-14-2017, 06:00 PM   #14
Tokay444
Anti stance.
Tokay444's Avatar
Still not as extreme as Caitlyn's.
MANUAL TRANSMISSION Anthony7515 NY / NJ / CT / PA 10 05-13-2016 02:36 PM
MANUAL TRANSMISSION Anthony7515 Southern California 1 05-12-2016 01:42 PM
Is the frs/brz your first manual transmission car? swarb Off-Topic Lounge [WARNING: NO POLITICS] 36 03-04-2015 08:22 PM
Manual transmission 2nd into 1st MrMista Engine, Exhaust, Transmission 9 10-13-2013 10:48 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
