Old 05-09-2014, 01:24 AM   #1
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Engine/Transmission noise
Hi All:
I've started to notice that my FRS has a really sharp gear change in the morning from 1st to 2nd. It literally jolts the entire car. My car is an automatic and I've searched that this is normal on the manual version of the car.... Would that issue carry over to the automatic? Should I regard this as normal?
Another issue is...
Tonight I drove without music and with the fan off and I noticed that upon acceleration the car whines like it has a supercharger. It's pretty loud at about 3000 RPM. Can anyone confirm this is normal? Does your automatic FRS have this as well? I've tried searching "Scion FRS Whine Accelerating" "SCION FRS AUTOMATIC WHINE".
On my previous car, a whine noise ment a failing CVT... would a whine noise be normal in this case?
It sounds like this...but this is a manual transmission with some mods...but i'm not sure if the mods make that noise?
[ame="https://www.youtube.com/watch?v=gW6CHGpaRfw"]https://www.youtube.com/watch?v=gW6CHGpaRfw[/ame]
Thanks!
Car is a 2013 FRS, Stock, Automatic.
N1rve
Old 05-09-2014, 12:07 PM   #2
jdubz13frs
jdubz13frs's Avatar
Drives: 2013 Scion FR-S 6MT
Based on your two issues, I'd guess there's an issue with your AT fluid pump. Too much pressure will cause a hard shift and I've heard many trannys start the whine when the pump bearing is going out on it
jdubz13frs is offline   Reply With Quote
Old 05-09-2014, 01:56 PM   #3
N1rve
N1rve's Avatar
Sounds serious
Update:
This morning it's not as loud.. but the whine is still there.
N1rve
Old 05-09-2014, 04:34 PM   #4
davebrus
Drives: fr-s
it could be that you have low transmission oil, I would check that! because I had the same Problem, then I refilled it with new Oil and annoying V-teck Sound went away!
davebrus is offline   Reply With Quote
Old 05-09-2014, 10:10 PM   #5
BRZnut
Drives: BRZ DGM Limited
mine sometimes has a faint wine like that in the am when I first get into the car, but its gone after few min of driving
Old 05-09-2014, 11:11 PM   #6
N1rve
N1rve's Avatar
What did you change your ATF fluid with? Did you go with OEM Toyota fluid?
N1rve
Old 05-10-2014, 10:46 AM   #7
FRSure
Drives: Toyota
I have the auto frs. I get the whine sound when accelerating up to 2500rpm.. Only when the car is cold though.
FRSure is offline   Reply With Quote
Old 05-13-2014, 04:12 PM   #8
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
I have the whine as well, same car (10 series, AT). I can clearly hear it when accelerating hard on the freeway onramp while in 2nd and 3rd gear.
I have noticeable jolts in the morning from 1st to 2nd too. Goes away after driving a bit, I think it's just cold tranny fluid. I sure hope it's not a failing AT fluid pump or low AT fluid, I mean, I barely have 2k miles on this thing!
aegisdrgn is offline   Reply With Quote
Old 07-05-2014, 09:50 PM   #9
EnrichedFlour
EnrichedFlour's Avatar
Drives: 2013 FRS
I am having this exact problem. I first thought it was normal because it being AT. My truck made a similar sound. But once under load (cold or hot, hard or easy acceleration.) it makes a very noticeable whining sound and is driving me nuts! Has there been any resolve to this issue?
EnrichedFlour is offline   Reply With Quote
Old 07-05-2014, 10:49 PM   #10
mike the snake
Could it possibly be the rear diff that you are hearing?
Old 07-06-2014, 12:29 PM   #11
EnrichedFlour
Drives: 2013 FRS
No it's somewhere up front. You can slightly hear it when the car is in park or neutral and you rev it past 2800rpm. I did this when the car was cold and warm. Still the same sound
Old 07-07-2014, 02:59 AM   #12
N1rve
N1rve's Avatar
I haven't looked into it as other people have stated it's normal. I haven't had a transmission failure yet soooo I guess it's good for now?
N1rve
Old 07-07-2014, 11:18 PM   #13
EnrichedFlour
Drives: 2013 FRS
Well I have an appointment with toyota. Hopefully they say it's all good I'll keep very or here posted if they are still concerned
Old 07-07-2014, 11:20 PM   #14
N1rve
N1rve's Avatar
If it's an issue lmk... so I can go get something done LOL.
WE CANNN JOIN FORCESSSS LOLOL
N1rve
Transmission noise at startup Toxicmilk45 Issues | Warranty | Recalls / TSB 2 01-28-2014 11:03 AM
Transmission noise when up shifting after hard rev 1Cor10:23 Engine, Exhaust, Transmission 2 09-03-2013 03:22 PM
transmission noise when reaching 23-25m/h Mokiki Issues | Warranty | Recalls / TSB 7 05-09-2013 09:13 PM
White line transmission brace noise Mathewgzlz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 01-07-2013 07:21 AM
transmission noise (when going to downshift) Hotlava86 Issues | Warranty | Recalls / TSB 5 09-03-2012 10:04 PM
