Ohne Titel
Drives: 2017 BRZ PP ISM
Oil Temp on Harry's Lap Timer - iPhone Version
Are there any iPhone users with Harry's Lap Timer (HLT) who have figured out how to see oil temperature?
I see that the oil temp was added to the Android version of the app: http://www.ft86club.com/forums/showt...t=48010&page=5 I checked the Harry's forum and tried posting, but no answer yet: http://forum.gps-laptimer.de/viewtop...=1364&start=10 I'm running a Veepeak Wi-Fi adapter for OBD2 info, and it works great with the DashCommand app on my iPhone 6 Plus. I'd really like to get oil temp right in HLT, so I don't have to run 2 devices/2 apps. The OBD2 readout from Harry's is attached for reference. I have the Petrolhead version of HLT. Also planning to run an XGPS150 over bluetooth for faster GPS updates. |
| The Following User Says Thank You to TofuJoe For This Useful Post: | AndyBRZ (09-27-2017) |
#2 |
Drives: '15 BRZ
Are you sure Petrolhead displays oil temp? Maybe you need to upgrade?
I use GrandPrix and it's displayed just fine right away, allthough I don't use it anymore since I switched to Pivot DualGauge. |
#3 | ||
Ohne Titel
For the record, I asked Harry on Facebook why some Android users were seeing oil temp, and I wasn't seeing this info on iOS. Here's his response:
Oh, and Petrolhead will show oil temp on the timer screen if it's available. Grand Prix is the only version where you can overlay this info on a video though. |
#4 | |
Drives: '15 BRZ
Also wouldn't that mean that you couldn't/shouldn't see the oil temp with any other app either? |
#5 |
Ohne Titel
@brzest - it just means that app designers need to add the specific PID for our cars.
Torque works on Android. DashCommand on iOS works, but it's an extra $10 for the 86 specific PIDs. |
#6 |
Ohne Titel
According to an 86 related Facebook group post, oil temp doesn't work on Harry's Lap Timer for 2013 model year cars. There was a firmware update for 2014 and later cars that shows oil temp on iOS. I can confirm that oil temp works in Harry's on a 2017 BRZ with an iPhone 6 Plus.
#7 | |
Drives: '13 FRS - STX
#8 |
Ohne Titel
@strat61caster - you're seeing oil temp on a 2013? That's good news!
#9 | |
Next time I think I'll run Torque, yeah it's not a smart program and I won't grab GPS data out of it but I'd rather have 10+ Hz of throttle and speed and I'm manually syncing and analyzing in RaceRender anyway because I'm cheap so only benefits to switching as far as I'm concerned. But Harry's is a solid track laptimer that you can use to pick out some big stuff. Sorry, went off on a tangent, I'm just looking for ways to stave off dropping $500 on Solo Storm+hardware. fwiw, warm day, the coolest IAT was ~90F, oil hit ~230F during a ~60s run so I understand the concern. Coolant rock solid though at 95C max. Right now I'm of the opinion that the oil can take most amateur motoring including a 20-30 minute hot track session based on the used oil analysis I've done. |
| The Following User Says Thank You to strat61caster For This Useful Post: | TofuJoe (09-13-2017) |
#10 |
Ohne Titel
I've had good luck using the Dual XGPS150 with Harry's Lap Timer. Gives you a 5 Hz data rate instead of 1 Hz, and only $80: http://amzn.to/2xz2z5o
#11 | |
https://www.amazon.com/Qstarz-BT-Q81.../dp/B003YCZINA |
| The Following User Says Thank You to strat61caster For This Useful Post: | TofuJoe (09-14-2017) |
#12 | |
#13 | |
Drives: 2013 Scion FR-S Firestorm
| The Following User Says Thank You to jjaisli For This Useful Post: | strat61caster (09-16-2017) |
#14 |
Ohne Titel
@jjaisli - good to know. I solved the problem by selling my 2013 and getting a 2017. LOL
| The Following User Says Thank You to TofuJoe For This Useful Post: | jbailey8748 (05-07-2018) |
| Harry's Lap Timer for Android: Now Available | ATL BRZ | Tracking / Autocross / HPDE / Drifting | 66 | 06-02-2017 03:02 PM |
| oil temp pressure, etc AND lap timer on a head unit | mokinbird87 | Electronics | Audio | NAV | Infotainment | 5 | 07-03-2016 07:36 PM |
| Track Junkies: Harry's Lap Timer, worth $20 bucks | gmookher | Tracking / Autocross / HPDE / Drifting | 49 | 01-23-2015 10:04 AM |
| iPhone/iPad app with oil temp | nzer | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 05-11-2013 04:10 AM |
| Oil Temp with Dash Command app on iPhone and iPad | nzer | AUSTRALIA | 0 | 04-20-2013 06:27 PM |
