Old 12-14-2012, 08:51 AM   #1
gmookher
Track Junkies: Harry's Lap Timer, worth $20 bucks
Download an app for iphone or ipad called Harry's Lap timer,well worth 20 bucks, over what a dedicated device costs
http://www.gps-laptimer.de/Home.html
Was recommended to me by Vortech, enjoying it so far tho I havent had it out on a track, it got the POIs for the ones I go to!
Appears you can configure for more than one car and add sensors
cool!
gmookher is offline   Reply With Quote
The Following User Says Thank You to gmookher For This Useful Post:
diirk (12-14-2012)
Old 12-14-2012, 09:02 AM   #2
diirk
diirk's Avatar
Drives: 4Runner
I know TemeCal was using it and was pretty happy with it.
I'm a Android user, so I just downloaded TrackMaster. $5.99.
I'll run it this weekend and see how it does. I pulled down a map for Streets Of Willow yesterday and configured the split markers. I think this time I'm just going to run the TM on the phone and use video from the GoPro's. Then I guess I have to install a program on my laptop to overlay the TM on the video. I'll try to play with that on Sunday.
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 12-14-2012, 11:56 AM   #3
Mark Slide Squad
Mark Slide Squad's Avatar
Drives: 2013 Whiteout FR-S 6MT, S14 Kouki
I used it last event and it's great! It was extremely accurate compared to the track transponder. The overlay is awesome! I used a phone mount that has a suction cup, and stuck it to in the inside of the windshield. The app records video and puts the overlay in there too, check it out.
[ame="http://www.youtube.com/watch?v=fa4eMus0m6I"]Scion FR-S on Street of Willow Springs CW Extreme Speed Track day 11/24/12 - YouTube[/ame]
Mark Slide Squad is offline   Reply With Quote
The Following 4 Users Say Thank You to Mark Slide Squad For This Useful Post:
amram (04-07-2014), cobrabyte (12-14-2012), Scooby South (12-19-2012), ShoNUFF (12-19-2012)
Old 12-14-2012, 12:01 PM   #4
diirk
diirk's Avatar
Drives: 4Runner
I've watched your video many times already. I'm curious about what you need to do for processing/posting the video. Does Harry's handle all of it so you just upload to YT, or do you have to run everything through another program to overlay the TM on the Video?
diirk
Old 12-14-2012, 12:04 PM   #5
IIRC it's all done by Harry's. I highly recommend an external GPS antenna with it; Harry's is hit or miss when it comes to properly working.
Old 12-14-2012, 12:10 PM   #6
gmookher
http://gopointtech.com/products/
Also recommended by them, afr, oil temp are actually more significant than boost, to me. Our obd gives plenty of warning for both
Old 12-14-2012, 12:22 PM   #7
Mark Slide Squad
Harry's Lap Timer does not do everything for you. It will record the raw video, and then you go to the video library inside Harry's Lap Timer. You then select the video, and then it will give you an option of "Overlay". Click that and it will add the overlay (it takes 5 mins or so to process). After that, you have to export the video. You can't upload to Youtube from Harry's. When you export, it will save it in your Camera Roll. From there you can upload it directly to Youtube from your Camera Roll (use Wifi) or you can connect your iPhone to your computer and download the video from your iPhone and then upload it to Youtube. That's what I did, then the movie will stay 720p resolution. If you upload straight from your Camera Roll to Youtube, I think it compresses the video and resolution suffers.
To touch on CSG Mike's point more, I've had no issues with accuracy yet, but it depends on the track oh how strong the GPS signal is. SOW is good. I heard Chuckwalla isn't good at all, and Buttonwillow is marginal. External GPS is definitely the way to go if you don't want any issues at any track you go to.
The Following 3 Users Say Thank You to Mark Slide Squad For This Useful Post:
amram (04-07-2014), bestwheelbase (12-14-2012), diirk (12-14-2012)
Old 12-14-2012, 12:32 PM   #8
diirk
diirk's Avatar
Drives: 4Runner
Thanks for the detailed reply. I was curious about the process. Using Trackmaster I have to export the TM file and the video to a computer and do the overlay there. So that's an additional step in the process that I'm not fond of. Hopefully in the future they'll make it more streamlined.
diirk
Old 12-14-2012, 12:56 PM   #9
atledreier
Drives: GT86 DGM
You can do it all on your phone. In Harry's, select the lap in the lap list and press overlay. It wil, spend a little time processi g, then save it to your camera reel on your phone. Upload to YT from there. Very simple. With OBDII you get a lot more info.
atledreier is offline   Reply With Quote
Old 12-14-2012, 12:58 PM   #10
TemeCal
Drives: 86
I was really impressed with Harry's Lap Timer. I compared every lap from the transponder with the lap times in Harry's Lap Timer. Every recorded lap time was very close - within 1/10th of a second. It was so good, that I'm not sure I'll be running a transponder on future events (unless the rental is free).
You are correct about the video from your camera roll going to youtube. The quality is absolutely horrible. However, there is an app (I think it's called 720tube), that will upload it to YouTube in HD.
I'd easily pay the $20 for Harry's Lap Timer. Very much worth it to me.
TemeCal is offline   Reply With Quote
The Following 2 Users Say Thank You to TemeCal For This Useful Post:
amram (04-07-2014), Mark Slide Squad (12-14-2012)
Old 12-14-2012, 01:07 PM   #11
While I think Trackmaster and HLT are great entry level tools, you guys will want more in-depth data from an external antenna and/or a dedicated datalogger.
Old 12-14-2012, 01:07 PM   #12
diirk
diirk's Avatar
Drives: 4Runner
Harry's sounds really good. Wish it was ported over for Android.
Might have to "borrow" my wife's iPhone....
diirk
Old 12-14-2012, 01:15 PM   #13
diirk
diirk's Avatar
Drives: 4Runner
As an update, Harry's Lap Timer is supposed to be available for Android first quarter 2013.
diirk
Old 12-14-2012, 05:25 PM   #14
atledreier
Drives: GT86 DGM
The day it goes android is the day I sell my iPhone. HLTpro is the thing that keeps me with apple.
The Following User Says Thank You to atledreier For This Useful Post:
CSG Mike (12-14-2012)
Is the FR-S worth getting? DIM Scion FR-S / Toyota 86 GT86 General Forum 60 10-28-2012 11:43 PM
Australian Motor Magazine: 86 vs BRZ and Bang For Your Bucks 2012 Kenno Scion FR-S / Toyota 86 GT86 General Forum 4 08-12-2012 09:08 AM
Preview for you BRZ junkies, another fix. RearDrive BRZ First-Gen (2012+) — General Topics 2 05-04-2012 08:11 PM
How much is RWD worth it? mankarn86 Scion FR-S / Toyota 86 GT86 General Forum 53 04-24-2012 05:15 PM
Lap timer button? Longhorn248 BRZ First-Gen (2012+) — General Topics 15 01-14-2012 07:51 PM
