Old 04-25-2016, 07:13 PM   #1
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
oil temp pressure, etc AND lap timer on a head unit
I`ve been researching and found out that idatalink maestro will display obdii info on an aftermarket head unit. I was a bit concerned about doing something like a dashcommand + bluetooth obdii connector since it seems the connection can be a bit sketchy at times and I dont want to manually turn it on and off every time (or leave it on because i dont want to drain my shorai battery), hence the choice to do idatalink maestro. refresh rate also seemed not too good...
however the idatalink maestro does not have a lap timer..
i guess my question is, is there an app that does both the lap times AND vital info from obdii like oil temp, pressure, and water temp? I do not want to get external gauges. I prefer a solution on a head unit.
mokinbird87 is offline   Reply With Quote
Old 04-25-2016, 08:24 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
There isn't presently a way to read oil pressure from the CAN bus. You'd have to install a sensor and a module to put the info onto the bus, so the head unit can retreve it.
Torque does read GPS, but I don't know if it has lap timers, or if it's just used for 0-60 and 1/4 mile times.
Old 04-26-2016, 11:55 AM   #3
mokinbird87
BOXER FR
so far it seems like harry`s lap timer is pretty ideal but i still have to use an external obdii sensor idatalink allows obdii info without having to plug anything since it`s hardwired.. ahhh i want OEM level of integration..
http://cdncontent2.idatalink.com/cor...S_20140917.pdf
Old 04-26-2016, 09:19 PM   #4
Calum
That Guy
You could pick up an obd2 port spliter, or hard wire a second port, and use that.
Or, someone said there is CAN hi and low behind the stereo, but I got lazy and didn't dig into it to see where. But that's all the elm327 chip, that's in most of the standard cables and bluetooth dongles, uses.
Old 07-03-2016, 07:24 PM   #5
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
It will read the oil temp off of those 2 can bus on the obd2 ports correct?
tofurun is offline   Reply With Quote
Old 07-03-2016, 07:36 PM   #6
Calum
That Guy
Yes.
Removing OEM Oil Temp/Pressure sender Bodalenko DIY (Do-It-Yourself) Guides 6 11-30-2017 03:32 PM
oil, water temp and lap time on head unit? mokinbird87 Tracking / Autocross / HPDE / Drifting 6 04-29-2016 07:37 PM
pressure and temp oil in this car? pepe Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-25-2015 05:02 PM
Oil pressure and Oil Temp sensor - where did you mount them and how philooo Engine, Exhaust, Transmission 11 05-29-2015 02:41 AM
Anyone run Tyredog pressure/temp monitors? Thorpedo Tracking / Autocross / HPDE / Drifting 11 01-23-2015 01:51 AM
