#813 | ||
Drives: FT86
Now this involves some risk. I did this to a K00P manual here flashed an A01G, now the car did not start , but recovery was to reflash original K00P and resync security. Its jist looping a couple of pins on obd port for 30 min. All good car recovered and all ok. Now as your car is old rom logic its possible the older rom will work in your car. And if not you should be able to recover like i did. You can make up a flash only definition, see first post in this thread for you K01I rom. Do that and confirm you can reflash your stock rom. Then try flashing A01I older rom If car starts runs, log and check all ok, happy days you can now tune Car wont start reflash original K01I And then most likely ecu security resync proceedure Full info here http://www.ft86club.com/forums/showthread.php?t=102810 You wont need to worry about vin or other stuff just reflash K01I Then loop pins and wait 30 mins 7. Turn OFF ignition 8. Loop pins 4 and 13 on OBD port in car (this puts control units in comms mode) 9. Turn ignition to full ON position with working key or for keyless fob in car and two pushes of start button (in park or not pressing clutch) DO NOT TRY TO START car, DO NOT remove FOB from car during the 30 minute period. To be really safe here make sure everything electrical is off in car radio, fans lights ect have the drivers window down and doors closed. Reach in through window to operate ignition at start and end of 30 minute period. Because when you open door window does the jump/up/down ie electrical load/spikes . 10. Wait at least 30 minutes (the CEL light should flash if pins looped successfully) 11. turn OFF ignition (again reaching through window not opening door) 12. Remove loop on OBD port pins 4 to 13 13. Start car let it run for more than 5 seconds. 14. Enjoy your car. Now i cannot offer you a 100% guaranee, however i did this on a 2017 manaual car and recovered. So sgould be same for 2017 auto |
| The Following User Says Thank You to steve99 For This Useful Post: | xxBrun0xx (09-10-2017) |
#814 | |
Drives: Toyota 86 GTS
MAF IAT Comp B8DF4 107C28 107C40 107C68 MAF Load Comp B8E2C 107CB8 107CF0 107D38 GDI Firing Angles BB68C 112958 112984 1129C8 BB6A8 BB6C4 BB6E0 BB6FC 112E08 112E34 112E78 GDI Pressure Multiplier A BB718 112F34 112F58 112F80 GDI Pressure Target B BB76C 113004 113040 113084 Injector Ratios BB814 1132B8 1132E8 113310 BB830 113388 1133B8 1133E0 BB84C 113458 113488 1134B0 Primary OL Fuel BBA34 1139D0 113A04 113A60 OL Fuel Additive BBA6C 113BA0 1138D4 113C30 GDI Pressure Multiplier B BBC9C 1145DC 114600 114628 Cranking BBD28 BBD44 BBD60 BBD7C BBD98 BBDB4 BBDD0 BBDEC BBE08 BBE24 Closed Loop Fuel BC2EC 1160F8 116124 116150 BC308 116244 116270 11629C Base Timing A? BCE98 119E4C 119E84 119EE0 Base Timing B? BCEB4 11A024 11A05C 11A0B8 Timing Compensation (IAT) Activation BCFB0 11A29C 11A2BC 11A2D0 Catalyst Warm Up Idle BD058 BD090 Transient Ignition Retard BD0E4 11A63C 11A65C 11A6BC Timing Compensation Per Cylinder BD18C 11A8D0 11A910 11A928 BD1A8 11A988 11A9C8 11A9E0 BD1C4 11AA40 11AA80 11AA98 BD1E0 11AAF8 11AB38 11AB50 Knock Correction A BD26C 11AC0C 11AC44 11ACA0 Desired Overrun Mass Airflow A BDD08 11D95C 11D9B0 11D9F0 Desired Overrun Mass Airflow B BDD40 11DCA8 11DCFC 11DD3C Idle Speed Stability A BDDB0 11E024 11E084 11E0B0 Idle Speed Stability B BDDCC 11E2C0 11E320 11E34C MAF Correction After Start BDF3C 11ED04 11ED30 11ED50 BDF58 11EE00 11EE2C 11EE4C Target Throttle Plate Position Maximum BE1E8 13C76C 13C7C0 13C81C Requested Torque B BE290 13CC9C 13CCDC 13CD38 Requested Torque A BE4B4 Intake Cam Advance Safe BF18C 125BFC 125C3C 125C9C Intake Cam Advance Normal BF1A8 Intake Cam Advance Base BF1C4 Exhaust Retard Base BF1FC Exhaust Cam Retard Normal BF368 Exhaust Cam Retard Safe BF384 126E84 126EC4 126F24 Fuel Multiplier Display Offset B7DE8 101CF8 101D0C Requested Torque Base BE0F0 13C498 13C4F4 MAF Scale BEA30 122444 12251C |
| The Following User Says Thank You to Wayno For This Useful Post: | steve99 (09-07-2017) |
#815 | ||
Drives: 2017 gt 86 auto
![]() How do you 'thank' a post on here? |
| The Following User Says Thank You to Dazrour For This Useful Post: | Compelica (10-08-2021) |
#816 | |
Drives: FT86
The reason for A01I is it will work in all 2012-2016 auto cars that came with I roms Same with manuals A01G will work in all 2012-2016 manual This is confirmed All ecu even 2017 is same processor and appears to be same hardwsre worldwide Their are usa guys running G roms in cars that came with C roms originally Last edited by steve99; 09-07-2017 at 06:46 AM. |
#817 | |
I'd prefer this approach to try A01 and make the K00D/G/I redundant, but perhaps there are quite a few more hardware changes in MY17 than happened in MY15 that the K00x roms might need to be mapped anyway to pull out things like the updated transient ignition retard injector compensations, not to mention all the unmapped stuff, etc. Having said that, most of those changes will appear and could be pulled out of K00G anyway.
#818 |
Drives: UK GT86
The EU MY17 ROMs are more similar to the MY15 G series, although there are still differences. Perhaps that definition is a better starting point.
.: Stealth 86 :.
#819 |
Better starting point is the K00G def, as some tables will have identical locations.
Cleaned up that K00G def that was uploaded, added the missing tables. Looks like EU MY17 got the 4.3 FD.
#820 | |
Around 120 tables done so far, in around 6-8 hours. |
#821 |
Drives: UK GT86
.: Stealth 86 :.
#822 |
#823 |
AU 6AT MY17
#824 |
Drives: Toyota GT86
It has been changed to a 4.3. Guy in our group (Belgium) had a 2016 BRZ after 2 or 3 months the car was totaled by an old lady and he bought a 2017 BRZ, he confirmed the FD change, also the change in suspension setup.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
| The Following User Says Thank You to elBarto For This Useful Post: | Wayno (09-20-2017) |
#825 |
Drives: FT86
Added ZA1JK00S 2017 Auto Australian rom to first post as supplied by wayno.
note the K00S and the K01I auto roms are interchangeable |
#826 |
Drives: UK GT86
Interesting, the MY17 BRZ spec change info state otherwise.
.: Stealth 86 :.
| Tags |
| ecuflash, tactrix, taxtrix, tuning |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 12:10 PM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
| Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 08:27 PM |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 10:18 PM |
| Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 07:27 AM |
