#799 | |
Drives: 2013 DGM BRZ Limited
Hey guys I've been reading up on various tuning posts and ordered my genuine Tactrix Openport 2.0 and it will arrive tomorrow. So as far as I understand, you can read and save the current rom on your ecu with ECUFLASH but need the definition file in order to be able to edit and flash it.
If I want to open the rom in ROMRAIDER and then edit and save, then flash to the car with ECUFLASH, I need a specific ROMRAIDER definition and a specific ECUFLASH definition? So when I get my openport 2.0 tomorrow, I will pull the current tuned rom from my car (open source dyno tuned) and find out the calibration ID associated with it. I believe all that is accurate. Now what I don't understand is in the OP where the Rom compatibility is discussed: Quote:
Thanks! |
#800 | |
Drives: GT86
Example picture |
#801 |
Drives: UK GT86
No, it just means that the ECU is compatible with those ROM versions. Go get a B01D file, edit that and flash that onto the ECU. That way you have all the updated changes made by the OEM that we can't see etc.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | kuangxtc (08-17-2017) |
#802 |
I am having a problem reading my current ROM. I hope I can find some help.
I just received my tactrix and have the 32bitbase file in the correct directory. My car has the B01D calibration ID, so I have the raw definition in brz/2012/2013/2014 folders. ECUFLASH reads the current rom, but it says there are no definition files for the rom. I save it as .bin and try to open in Romraider with the specific romraider definition file and it still says no matching ecu definitions. And there's no Rom Metadata for the read in ECUFLASH. Is there something I'm overlooking? Thanks! ![]() ![]() ![]() ![]() ![]()
#803 |
Drives: FT86
post up the rom image you saved and ill look at it. It probably been tuned previously with a calid hacked rom
Id also download the latest 32bitbase and B01D Ecuflash definitons from the github site the error message your getting saving your rom as .bin is normal ,about the padding. Just click yes to save as bin also try opening a stock B01D rom that attached to first post in this thread, see if that will open. If not update your 32bitbase and defs from github Last edited by steve99; 08-17-2017 at 05:10 PM. |
#804 |
Drives: FT86
Added ZA1JK00P 2017 Australian manual new logic rom for udated car with red intake manifold
#805 |
Drives: FT86
Added ZA1JK01I
2017 auto European |
#806 |
Drives: Superchared BRZ
Ecuflash Definition file for 2017 BRZ MT Chinese Market ID ZA1JK00N
Hi everyone
can someone help me out with the definition file for 2017 BRZ MT foe the Chinese Market , calibration ID : ZA1JK00N Attached is the Stock file appreciate any help Cheers |
#807 |
Drives: 2017 gt 86 auto
Hi
I believe this is the rom from my car Still having trouble with the definition file for this thing, its the old logic but doesnt match any of the old definition files. Attempted reverse engineering the rom using IDA but its a little beyond my current understanding. Anyone know an easier way to identify the tables if they should be similar to a previous rom? |
#808 | |
Drives: FT86
Unfortunatly very few people possess both the skills and time to reverse engineer these roms and find the tavles and logging addresses. Basicly one guy on ghe planet tdd over at romraider, and i think hes swamped and has a real job to do as well. If your in a hurry your going to have to buy brzedit, ecutek or oft. |
#809 | |
Drives: Toyota 86 GTS
There will be large chunks of tables with similar data, but at locations offset from earlier roms. |
#810 | |
Drives: UK GT86
.: Stealth 86 :.
#811 |
Thanks everyone for the responses in the posts above. It looks like the community could do with a few more hackers 😉
I have a feeling the oft guys dont have a working rom for this id either, I emailed shiv as that would be my preferred option over ecutek. I'll have a go with ScoobyRom it looks promising and see how far I can get. Hopefully post findings and guidance back to the forum incase anyone else fancies giving it a go on any new roms. Cheers. |
#812 | |
| Tags |
| ecuflash, tactrix, taxtrix, tuning |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 12:10 PM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
| Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 08:27 PM |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 10:18 PM |
| Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 07:27 AM |
