#15 |
Drives: Raven FR-S 6M
You will usually see higher RPM for longer periods on the track.
“The World is Flat”
[||•]=(86)=[•||] |
| The Following User Says Thank You to Apoc For This Useful Post: | Mr.ac (09-04-2017) |
#16 |
Drives: '13 BRZ
Your car can handle running at 4k for 20 mins.
#17 |
Be a blast to watch you go around the track at 4K. You truly do not have a clue on a single thing do you?
| The Following 5 Users Say Thank You to Tcoat For This Useful Post: | Apoc (09-04-2017), Mr.ac (09-04-2017), N8RH8R (09-04-2017), Somerandom18 (09-04-2017), strat61caster (09-04-2017) |
#18 |
Drives: BRZ 2017 Pure Red, MT
Running on a track for 20min at 4k is going to be a long 20 minutes, lol. Especially on a FR-S where you're in the torque dip....
Euhh, yes?!? I did a lot of HPDE in my old RSX and was shifting 100-200 rpm before rev limiter, like almost everyone who is tracking their car is doing. I haven't done any lapping yet in my BRZ, but I do a lot of autocross, and I often bump a couples of time on the rev limiter, because a shift to 3rd is not beneficial. All fast drivers will do that in autocross. As for the OP, I don't see how an aftermarket warranty will be economically viable. You will surely end up paying the same amount of money an engine repair would cost you. |
#19 |
Drives: '13 BRZ
#20 | |
Drives: '13 BRZ
YOU SHIFTED |
#21 |
You would be running 4k-7k where peak power lives. Even in the video you posted the E46 is running higher than 4k
“The World is Flat”
[||•]=(86)=[•||] |
#22 |
Drives: Track preped NA FRS
Guys, lets end this argument,. Get a 4.88 or 5.1 final drive and your car will never be below 5k rpm ever at the track, since you only use 3-5 gears
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | N8RH8R (09-04-2017) |
#23 | |
Drives: 2013 frs
#24 |
True I have not tracked this car. I won't because I find the extra wear and risk of damage unacceptable due to it's importance for my work. That does not mean for one second I have never tracked a car. If you are tracking this car at 4K then you are going to piss off every other driver there since by the time they have lapped you 3 or 4 times they will have had enough of you.
#25 |
Drives: 2017 manual BRZ
What if your car is a diesel??
Sent from my Pixel XL using Tapatalk |
#26 | |
Drives: '13 BRZ
You clearly know nothing about this subject. How can one person constantly miss the point entirely? You clearly have a learning disability. Watch the 2 videos I posted. Does that look like abuse? |
#27 | |
#28 |
Drives: '13 BRZ
I've seen several posters here refer to tracking as abuse. Like it's the worst thing you can do to a car. Meanwhile, the same people will buy a car that has been modded and hooned. That level of ignorance is overwhelming and it warranted posting a new thread.
Anyone with half a brain can see the track videos I posted and decide for themselves. For the rest of you, best of luck buying modded trash heaps that have "never been tracked". LMFAO. |
| Extention of Toyota warrenty | FT_86_SM_GP | AFRICA | 9 | 12-23-2015 01:34 PM |
| Michelin Pilot Super Sports Warrenty? | FLASCH | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 05-11-2013 10:39 PM |
| Condensation in taillights are covered under warrenty | cjdriiiiift | Northwest | 1 | 10-24-2012 09:40 PM |
| warrenty questions | koteman | Issues | Warranty | Recalls / TSB | 3 | 10-21-2012 06:34 PM |
