Old 12-14-2012, 03:42 PM   #1
Surakusa
Mechanical Guru
Surakusa's Avatar
Drives: 2013 Scion FR-S (Argento) M/T
Fuel Gauge is Inaccurate
I arrived at the gas station to top off my fuel and noticed that after doing so... the fuel gauge did not move at all. The only way I have found to fix this is if I remove the battery for 12 seconds...
I started experimenting with this. What causes it, and how to remedy the situation...
Apparently this only happens (at least for me) when you have filled up, then traveled a little ways (let's say 50 miles) and then just topped off the gas at your ending destination. (I do this when I come home from visiting family so I have enough gas for the week). So I guess the trick is... Use at least 1/4 of the tank before filling up again... Otherwise, the fuel gauge is thrown off...
If for some reason it still happens to you... I know I hate having to reset all my radio stations and stereo configurations... you can just pull the battery for about 5 seconds... If done right. Only the dashboard is reset and your radio settings are maintained.
Give it a shot!
Surakusa is offline   Reply With Quote
Old 12-14-2012, 03:52 PM   #2
Skye
Drives: TR2,CooperS,BRZ
Don't top your tank, there's a warning against doing so. I found this out the hard way with a CEL when on a trip with my WRX.
Skye is offline   Reply With Quote
Old 12-14-2012, 03:55 PM   #3
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I'd bring that to the dealer! I never had problem with it!
Rayme is offline   Reply With Quote
Old 12-14-2012, 03:59 PM   #4
i_4got
i_4got's Avatar
Drives: Whiteout FR-S
Does that mean continuing to fill up your tank even after the pump auto stops you? If so, then yeah, it's a really bad idea to do that since there's a warning right on the fuel door.
i_4got is offline   Reply With Quote
Old 12-14-2012, 04:05 PM   #5
Cheddar
Saving them pennies...
If the pump stops, then you stop.
Cheddar is offline   Reply With Quote
Old 12-14-2012, 07:08 PM   #6
mashal
DADA
mashal's Avatar
Drives: 2013
Lol some people these days .. Please explain me to me how this is a car issue ???
The needle in most cars now don't move for the first 50-80 miles anyways .. And you got alot of time if your topping up a gallon of gas
I-Tapatalk
mashal is offline   Reply With Quote
Old 12-17-2012, 09:17 AM   #7
Surakusa
Mechanical Guru
Surakusa's Avatar
First off, no i'm not topping it off in a sense that I'm going past the fill line when the gas pump stops... But yes it does start dropping for me around 50miles traveled and I travel a little bit more than that from my parents place... but once it starts dropping and I arrive at my house, I will top it off just so I have that full tank of gas for the week. (used to anyway haha). I don't do it anymore... So yes it is an issue if the fuel gauge drops and you fill up and it still doesn't move back to full. :P I'm not the first to experience this here, but I just wanted to post my experience and how I came up with a temporary fix if someone else does it that is least annoying.
Old 12-17-2012, 10:19 PM   #8
roddy
roddy's Avatar
Drives: '13 Ultramarine
I knew what you meant. I have had the same problem. Since I started refueling at 1/2 tank or less, the issue has not happened. I got in the habit of keeping the tank as full as possible a long time ago. Back in the day when carburetors and steel gas tanks were the norm. It's a hard habit to break.
Old 01-02-2013, 12:03 PM   #9
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
I thought I'd read this issue occured... Just had it happen to me in the BRZ. I had only drove 50 miles and since I had to go by my regular fuel station I decided to go ahead and fill her back up since I was already there... I didn't "top off" the tank just as the original OP and the gauge never moved. Now that I've finally drove a little over 50 it has started moving again.
Anyway, just wanted to post that this has happened recently if anyone else searches the issue. I know I'm going to mention it to my dealer when I go in for service next; however, I can't say I've been too impressed with how they've handled other things so far... (I'll be switching where I get my car maintained if they fail to impress this next and possibly final time!)
Subaru STI :
Old 01-02-2013, 12:18 PM   #10
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
ive filled my car up 70 times without an issue its full when the pump stops and it fills 10.5 gallons any time the light comes on when my fuel is low just like it is supposed to
my fuel gauge doesn't move till about 50-60 miles either, my last car i could go 120 miles before it came off full lol...
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 01-02-2013, 12:26 PM   #11
Kimsey47
Kimsey47's Avatar
@carbonBLUE This isn't the initial "non-move" that you typically see with full tank. My gauge was reporting between the first 1/4th of a tank being used and not to the "pegged" full location... When it was then refueld it does not move from that location to the typical "full" location. Basically it shows that you're not full when you actually are...
It appears that the gauge has started reporting accurate after I have now used enough fuel to pass that gauge mark... It is a really odd bug!
Subaru STI :
Old 01-09-2013, 07:08 AM   #12
AlexTheGreek
AlexTheGreek's Avatar
Drives: BRZ Premium Black
Just picked up my new BRZ last night and the same thing happened to me. I did about 20 miles from when the dealer topped up. I decided to re-fill the tank to reset my MPG avg because of all the idling at the dealer during the intro.
Anyway, here are the facts:
-Topped up ~2gallons
-Needle was about 15/16th full.
-1 mile later the next day, needle is below 7/8th
AlexTheGreek is offline   Reply With Quote
Old 09-02-2017, 09:35 PM   #13
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
This happened today on my 2017 Toyota 86. I am just gonna burn down to bout half a tank and fill again and see if it goes back right ? Anybody know of a real fix or solution. Not a big deal just more a quirk than a problem.
22R
22R is offline   Reply With Quote
Old 09-02-2017, 10:26 PM   #14
22R
Most have worked themselves out. A couple of guys have had to have it fixed.
Fuel gauge not reading properly FR-S Hot Lava Issues | Warranty | Recalls / TSB 27 10-29-2014 10:33 AM
Fuel gauge stuck? Nate219BRZ Issues | Warranty | Recalls / TSB 6 08-27-2012 04:40 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 04:29 PM
European fuel/coolant gauge face arbnpx Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 12:23 AM
