Old 09-01-2017, 09:46 PM   #1
mr.brz1234
Drives: sport-tech
clutch spring question
hi there just recently picked up my brz and having some trouble with 1st gear i cannot feel the clutch biting point at all
i was reaserching and found out that people remove these springs to get a better feel of the clutch now my question was that if i removed the spring would it cause any pre mature wear on the clutch as in wearing out? or burning it? thanks!
mr.brz1234 is offline   Reply With Quote
Old 09-01-2017, 09:52 PM   #2
BRZHarley
Drives: 69 Firebird, 2015 BRZ
No. Best free mod you can do in your driveway...
Ed
BRZHarley is offline   Reply With Quote
The Following User Says Thank You to BRZHarley For This Useful Post:
jcw99 (09-02-2017)
Old 09-03-2017, 01:48 AM   #3
mr.brz1234
Drives: sport-tech
Ed
thanks!!
Old 09-03-2017, 02:28 AM   #4
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
It doesn't change the engagement point. For that you would have to adjust your clutch pedal height. It just assists those drivers with pipe cleaner legs.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
justinco (09-03-2017), re-animator (09-07-2017)
Old 09-03-2017, 11:10 AM   #5
Sonder
Drives: '17 BRZ w/ PP || MBTA
So removing the clutch spring doesn't harm the car in any way, correct?
Sonder is offline   Reply With Quote
Old 09-03-2017, 08:40 PM   #6
Irace86.2.0
Correct.
Old 09-03-2017, 10:43 PM   #7
Poodles
Drives: 2015 Series.Blue
Just makes the clutch harder to push if the spring is removed. You'll adapt to the feel in time and be thankful it's there in heavy traffic.
The Following User Says Thank You to Poodles For This Useful Post:
funwheeldrive (09-07-2017)
Old 09-05-2017, 05:46 PM   #8
ejasons
Drives: 2017 White BRZ Premium
I tried to perform the procedure this past weekend, couldn't at all figure out how to get my head, shoulders, and arm(s) in place to where I could do it. Others haven't mentioned much trouble, so I must be missing something pretty obvious -- any tricks to recommend?
ejasons is offline   Reply With Quote
Old 09-06-2017, 10:04 PM   #9
mr.brz1234
Drives: sport-tech
i am about 6 foot and what i did is moved the seat all the way back put the steering column all the way up and i still couldnt get to it so i just took out the driver seat took out the spring and put the driver seat back in
Old 09-06-2017, 10:40 PM   #10
LudwigMiles
Drives: '13 BRZ
Did removing the spring accomplish what you wanted?
LudwigMiles is offline   Reply With Quote
Old 09-07-2017, 10:59 AM   #11
mr.brz1234
Drives: sport-tech
yup did exactly what i wanted
The Following 2 Users Say Thank You to mr.brz1234 For This Useful Post:
BRZHarley (09-07-2017), funwheeldrive (09-07-2017)
Question about the clutch spring removal btan219 Engine, Exhaust, Transmission 4 05-12-2017 09:54 PM
Clutch Spring Removal DaBoBo21 Engine, Exhaust, Transmission 6 04-10-2017 06:26 PM
FS: MTEC clutch spring nunonuna Transmission and Driveline 2 07-13-2016 01:34 PM
FS: MTEC Shifter Spring Kit + Clutch Spring Kit BRAND NEW $59 shipped susko Transmission and Driveline 2 01-21-2016 04:42 AM
Clutch spring removal Sandy AUSTRALIA 4 07-22-2015 11:14 PM
