Old 03-24-2017, 02:48 PM   #1
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Clutch Spring Removal
Hey guys,
I've been told by a few guys I work with that removing the clutch spring is highly recommended to help with pedal feel. I've been searching around the forum and I see that a good amount of FRS/86/BRZ owners are satisfied with this modification. My only question is, will there be premature wear on the clutch since removing the spring gives way to a tiny bit of play in the pedal? Looking to do this this weekend if I'm made a believer. Thanks!
DaBoBo21 is offline   Reply With Quote
Old 03-24-2017, 02:51 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I didn't notice much play play in the pedal after removing the spring. You will need to adjust the clutch sensor anyway and that will eliminate some of the play.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 03-24-2017, 02:52 PM   #3
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
I did this mod 2 weeks ago. At first it was cool but now I absolutely hate it. The wobbly pedal bothers me soo much. I ordered the MTEC clutch spring in the hopes it may resolve the slop and still give a better feel. But we'll see.
Just my opinion and preference though.
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
Old 03-24-2017, 03:16 PM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I did it last year. I never adjusted the pedal or sensor and I still don't feel and looseness or play. Totally happy with the mod.
Old 03-24-2017, 06:39 PM   #5
mr_squirrel
mr_squirrel's Avatar
Drives: 2017 86 Halo
Did this as soon as I got my car home. Didn't notice any play, and I love the stiffer feel.
Sent from my ONEPLUS A3000 using Tapatalk
mr_squirrel is offline   Reply With Quote
Old 04-10-2017, 09:28 AM   #6
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
I wanted to throw an update out there on this... for those of you hesitating to do this. Don't. Hands down the best thing you can do for clutch response. The "mush" at the top of the peddle does not bother me one bit. It's heavier.. You CAN FEEL THE GRAB POINT. It makes everything noticeably better. I cannot express enough how happy I am with this mod. It literally took me ten minutes to get use to. All of my shifts are seem-less and smooth. Downshifts are more fluid. No more dead pedal. For those of you suffering from this and second guessing your ability to drive this beauty.. It's the return spring causing it. Take that sh*t out.
That being said, I did order the MTEC spring prior to this just in case I decide to put a spring back on. But with how amazing it felt driving my BRZ yesterday evening I will most likely keep it the way it is. The "mush" does not bother me. Honestly, how the pedal feels now is how I think it should feel coming off the line. YOU WILL NOT REGRET DOING THIS! *paranoia gone... for now...*
I loved this car before, but now it's tenfold. Don't let that return spring hold you back!
Old 04-10-2017, 05:26 PM   #7
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Just wait until you swap out the clutch slave cylinder
Decay107 is offline   Reply With Quote
How To: Free Clutch Spring Removal in 15 Minutes - A must do for manual trans! VerusEric DIY (Do-It-Yourself) Guides 242 05-21-2025 08:05 AM
Clutch return spring removal MikeyBRZ Engine, Exhaust, Transmission 186 09-16-2020 12:40 PM
How To: Clutch Spring Removal in 15 Minutes eric6 DIY (Do-It-Yourself) Guides 165 02-14-2017 11:44 PM
Clutch spring removal Sandy AUSTRALIA 4 07-22-2015 10:14 PM
Clutch Spring Removal & Throwout Bearing DemonRawr Issues | Warranty | Recalls / TSB 2 05-13-2015 08:08 PM
