Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 07-02-2012, 09:38 PM   #71
86drift
86drift's Avatar
Drives: Toyota 86 GT
Originally Posted by TonyJZX View Post
where is the obd port on the 86?
you may as well get a bluetooth dongle and use the Torque app on Android and a cheap China tablet and mount it on the centre console for full engine, environment, speed monitoring.
It's above your left leg when in the driver's seat. Easy to access as there's no cover.
86drift is offline   Reply With Quote
Old 07-02-2012, 10:13 PM   #72
Loki556
Drives: RA23
Any chance of a picture? How high is it? Is it in the way of the clutch pedal?
Loki556 is offline   Reply With Quote
Old 07-02-2012, 10:34 PM   #73
TonyJZX
Drives: VN Commode
all the more reason to buy automatic!
but seriously... you may be able to get obd2 extension cords that dont stick out as much as the dongle
TonyJZX is offline   Reply With Quote
Old 07-02-2012, 11:30 PM   #74
86drift
86drift's Avatar
Yes, see pic and yes (unless you have a very big dongle...) The pic is taken from the floor pointing up.
The Following User Says Thank You to 86drift For This Useful Post:
Satu23 (07-03-2012)
Old 07-05-2012, 02:36 AM   #75
Z86
Drives: 86 GTS Auto in Pegasus White
Drove my 86 about 300kms today after picking it up. Whilst I have a GTS and have the digital speedo - I tried hard not to use it to try and give an opinion on the dial one.
Really, the dial one is fine - intact I think the size and spacing of the numbers is awesome. The gaps between 10 km/h are plenty big enough for you to see roughly half way - and lets be honest, you don't need to know your speed to the exact kilometer - all Aussie speed limits are in 10km/h increments, so you'll easily see when you are 5 over.
On top of that, it didn't take long for me to get the "feel" for what speed I was doing.
Z86 is offline   Reply With Quote
Old 07-05-2012, 03:13 AM   #76
TonyJZX
Drives: VN Commode
thank you and all the more reason to buy the automatic 86!
Old 07-05-2012, 06:58 AM   #77
Loki556
Drives: RA23
Dadhawk, have you tried mating the obd output to any hud units?
That would just be so amazing!
Old 07-05-2012, 09:58 AM   #78
No, I haven't but it would be interesting to see the results. I only used mine sporatically and typically when I'm doing some troubleshooting before taking to the mechanic or whatever. When I do use it I either use it with my Droid X phone or my tablet.
Old 08-01-2012, 07:33 AM   #79
JiB
JiB's Avatar
Drives: GT86
Ok, so it took a while to find this thread!
Now, from my experience!
Once you are use to where to look, it doesnt become to difficult to see what speed your doing! BUT, its alot easier to learn RPM's for gears to know your speed.
I have 2 stored in my memory for your viewing pleasure!
- 1st one is easy, and i find for my area, the most common speed limit 60km/h
3rd Gear / 3000RPM is 60km/h on the dot!
- 2nd one is for 80km/h
4th Gear / 2500RPM is 80 km/h on the dot!
Love this car!
JiB is offline   Reply With Quote
Old 08-01-2012, 08:29 AM   #80
450hp/tonne
Drives: 2011 Corolla Ascent Sport
I assume this is the rpm/speed at which you stop accelerating (then shift up to cruise), as I'd use 5th at 60 km/h and 6th for anything above 67 km/h ...
450hp/tonne is offline   Reply With Quote
Old 08-01-2012, 08:34 AM   #81
JiB
JiB's Avatar
Drives: GT86
seriously?! the slightest hill and you wouldnt make it up :\ if im feeling lazy, i MIGHT change to 4th at 60km/h but most of the time, rolling 3rd
Old 08-01-2012, 09:41 AM   #82
RAN94A
Grand PooBah
RAN94A's Avatar
Drives: Toyota 86 GT MT
personally i would be using 4th for 60km all the time.. but then again ive heard this is the kinda car that you should be one gear lower than you're normally used to..
RAN94A is offline   Reply With Quote
Old 08-01-2012, 11:31 AM   #83
abitolder
Drives: 2013 FRS Argento MT
In Canada but with the digital readout I still find it difficult to read analogue speedometer and all you see on the gauges are the red needles when you have sunglasses on in the daytime, and yes it is sunny and hot here. You can turn on the parking lights but a manual over ride to turn on the dash lights would have been a big help.
abitolder is offline   Reply With Quote
Old 08-01-2012, 05:52 PM   #84
Bauer
Drives: Black 86 GT
Originally Posted by celicajim View Post
Does the AUDM 86 have OBDII port?
OBD II HUD
http://www.ebay.com.au/itm/Head-up-d...item20c780c6df
Like this idea better than buying a dongle and then not bother to use it. Anyone on it yet?
Bauer is offline   Reply With Quote
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Speedometer Accuracy MTeator Scion FR-S / Toyota 86 GT86 General Forum 16 08-22-2012 08:39 AM
traction control issue *KID* Scion FR-S / Toyota 86 GT86 General Forum 13 07-08-2012 08:13 PM
First 86 issue and advice Mr.Eightsix Scion FR-S / Toyota 86 GT86 General Forum 34 05-19-2012 11:49 AM
Headrest issue? Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 11 12-01-2011 03:48 PM
