Old 01-28-2016, 08:25 PM   #1
Zhangy
Drives: 2015 FRS
Fan static/humming noise
Anyone had experience with fan static/humming noise coming out of the passenger side vent? when I turn off the fan the noise is gone.
Zhangy is offline   Reply With Quote
Old 01-28-2016, 08:39 PM   #2
Frsboxer
Drives: 2015 scion frs
You may have something like paper or a leaf in the blower motor
Frsboxer is offline   Reply With Quote
The Following User Says Thank You to Frsboxer For This Useful Post:
mdm (01-28-2016)
Old 01-28-2016, 08:54 PM   #3
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
http://www.ft86club.com/forums/showthread.php?t=19649
I remembered we had this thread. Wow, it's over 3 years ago.
More here.
http://www.ft86club.com/forums/showthread.php?t=40231
http://www.ft86club.com/forums/showthread.php?t=15965
http://www.ft86club.com/forums/showthread.php?t=11037
Old 01-28-2016, 09:45 PM   #4
Anyone remember when the heater in a car was mounted on the inside of the firewall, right where you could get to it .... ??
Fixing the fan was a snap .......
(I gotta get a grip on my so-called life .... )
Old 01-29-2016, 11:05 PM   #5
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
Had this. Had the dealer replace the pos motor. Sound went away for 3 month. Its back.
Crickets under the hood.
Static on the inside.
I think the engineers figured these will cancel each other out.
NOT..
anyways. I will be spraying some silicon grease on that shit.
Ill tell you how it goes in two months when i actually get around to doing it.
nos145 is offline   Reply With Quote
The Following User Says Thank You to nos145 For This Useful Post:
BaBaFlyingSheep (08-26-2017)
Old 01-30-2016, 06:13 AM   #6
roddy
roddy's Avatar
Drives: '13 Ultramarine
I had a similar noise pop up this year...ended up having to change the blower (heater) fan motor. Take it to the dealer. If that is the problem, it should be covered on your 2015. My 2013 was out of warranty so I had to fix it myself. IIRC, the part was around $175 CDN.
@humfrz and others who may be wondering, if you end up having to do this, it is actually very easy on this car...no need to rip the dash apart. The blower motor is located directly below the glove box, and all you need to remove is 3 screws and an electrical plug. The whole job takes 10-15 minutes from start to finish.
The Following User Says Thank You to roddy For This Useful Post:
humfrz (01-30-2016)
Old 01-30-2016, 08:03 AM   #7
Ramn
Ramn's Avatar
Drives: 2015 GTI
I'm going to replace it with this one. Hope the noise goes away.
Ramn is offline   Reply With Quote
Old 01-30-2016, 08:11 AM   #8
BRZnut
Drives: BRZ DGM Limited
has anyone heard a random chirp (sounds like a bird chirp) coming from the passage side of the dash when the heat is on? Goes away as soon as you turn off the heat so suspect it is from the blower motor.
Old 08-26-2017, 09:47 PM   #9
BaBaFlyingSheep
Drives: 2015 BRZ Ltd 6MT
Did Silicone Grease Work?
NOT..
Did the silicone spray end up working to get that noise gone? It's annoying as hell.
BaBaFlyingSheep is offline   Reply With Quote
Weird humming noise from behind radio in middle of dash JesseE Issues | Warranty | Recalls / TSB 6 10-17-2016 06:50 PM
Consistent Humming Noise From Front Right Area zussypoo Issues | Warranty | Recalls / TSB 4 08-24-2015 05:19 PM
Humming noise while driving maylchi Issues | Warranty | Recalls / TSB 9 03-13-2015 01:29 AM
help!! weird humming noise?? sid94 Issues | Warranty | Recalls / TSB 3 05-17-2014 12:16 PM
Humming noise from the rear/gas tank? Turbo95eg6 Issues | Warranty | Recalls / TSB 3 11-30-2013 04:10 PM
