#141 | |
Drives: Whiteout FR-S
I haven't seen anybody running EBC either, i guess there is a reason for that. |
#142 |
Drives: 2012 BRZ Premium WRB 6MT
Yes, those are the correct part numbers front and rear.
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division www.essexparts.com ![]() |
| The Following User Says Thank You to JRitt For This Useful Post: | ft_sjo (11-12-2012) |
#143 | |
"High quantities" is a relative term. Our idea of a high volume is likely far different from their idea of a high volume. Also, because the volumes are far lower, production for racing pads is sometimes done in a special "race shop," rather than the main production line. They require special handling and higher production costs. For all of these reasons, costs can sometimes be higher for a new shape, or a rear vs. a front, etc. It all boils down to their cost, which they have to cover and make their target profit. It's a completely variable cost, based on a long list of items. On the FT86, the fronts were already a common shape currently being produced by most pad manufacturers. That made it easy. The rear however, was more rare.
#144 | |
I checked on this for you. The CL Brakes RC5+ would probably be a good choice for you as a dual-use pad. We can get them in the standard OEM FT86 front, and the 2008 WRX rear shape. They will make a little noise on the street, but they can take a solid beat-down. About a third of the way down this page you can see them on track in a fast Lancer Evo. If you wanted to take a step further towards more track-oriented, the CL Brakes RC6E compound is an option. We have that compound in both shapes as well. They would be tougher on discs and noisier though. As you said, Endless MX72 is an option as well. They would possibly be a little easier on discs when driven cold on the street. I talked to Endless, and they gave me the part#'s for the lower spec FT86 brake pad shapes (the RA model): Front pads: EP386 Rear pads: EP418 On the higher spec model (standard in the USA): Endless front: EP386 (same as RA model) Endless rear: EP472 So...another confirmation that the front caliper pad shape is the same on all FT86 models...just the rears are a bit different. Let us know if we can help.:happy0180:
Jeff Ritter|Mgr.- High Performance Division www.essexparts.com ![]() Last edited by JRitt; 11-13-2012 at 03:39 PM. Reason: Added caliper info |
| The Following 2 Users Say Thank You to JRitt For This Useful Post: | GT86_PRAGUE (05-19-2015), ultra (11-13-2012) |
#145 |
Drives: Automatic car
I use Carbotech XP8 as it is good for racing compounds. It is Good initial bite at race temperatures, high coefficient of friction, excellent modulation and release characteristics. Very high fade resistance and very rotor friendly. Excellent as a front brake pad for lighter applications. It is Perfect for track day use with any tire and can still be driven safely to and from the track. But a problem of noise I have to face.
#146 | |
Drives: DC5
#147 |
Drives: '13 BRZ
I need new pads (and maybe rotors).
I am fine with stock pads. I might do one track day a year, so this is just for DD use. I don't really want race pads or any performance upgrade. Do you guys buy basic parts stuff at the dealer? For my other cars, I never buy parts at the dealer. (ripoff) I also don't buy parts from auto parts stores (Duralast, etc) Instead, I buy from online vendors like FCPEuro that sell OE branded parts like Sachs, Lemforder, Mahle, Seimens/VDO, etc. Is there something like that for Subaru? |
#148 | |
Drives: frs
#149 | |
Drives: Subaru BRZ / Toyota 86 Experts
#150 |
Le Ingenieur
Drives: 2015 Subaru BRZ Aozora
I am using Project Mu HC800s, while I like the bite of the pads, I seem to go through them way too quickly. In 3-4 track days or so, the pads will be cooked and have very little material left. (Im on oem brakes) Is there a recommendation on longer lasting pads that I can daily as well?
#151 | |
Drives: Track preped NA FRS
I wouldnt recommend hybrid pads (DTC-30 or Street/Race for example), because while they might work, they last a lot less than race pads when used on track. |
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | Dawan (08-21-2017) |
#152 |
Drives: '13 BRZ
Thanks. That was a nicely produced video.
But, I'm not looking to do upgrades, and just want OEM equiv. Looks like Amazon is an option. They sell Wagner, ACDelco, Akebono, and Centric. (And Hawk) I believe all are reputable brands. RockAuto sells Centric, Raybestos, Wagner, ACDelco, PowerStop, etc. The point is, there seems to be non-dealer options. |
#153 | |
Le Ingenieur
#154 | |
| Brake cooling duct kit | tranzformer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 12-14-2011 01:37 PM |
| FR-S Rear brake light... | MF_DEUCE | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 70 | 05-05-2011 03:53 PM |
| Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 10:28 AM |
| Brake override system in the FT-86? | mrKiKaZ | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 02-22-2010 11:33 AM |
