Old 08-10-2017, 08:38 AM   #71
LudwigMiles
Drives: '13 BRZ
Originally Posted by fierostetz View Post
Want the new final drive ratio, and at least near me almost all the FRS/BRZ I see around are being flogged. If it wasn't a car that was prone to "enthusastic" driving, like a Camry or something, I'd be comfortable used. I just don't want to inherit someones thrashed transmission and get denied warranty later. Since I can't work on things myself anymore I kinda want to make sure I have the warranty.
I would never buy a car that has been modded either. And you're right, a lot of these twins are like that
Unmolested bone stock cars with low miles that have not been abused are out there. You just need to find them. I found a '13 from the original owner who was a perfect seller. No mods, never driven hard, garaged, etc.
What are grounds for a void warranty ?
LudwigMiles is offline   Reply With Quote
Old 08-10-2017, 08:57 AM   #72
https://www.toyota.com/t3Portal/docu...FRS_WMG_lr.pdf
WHAT IS NOT COVERED
This warranty does not cover damage
or failures resulting directly or
indirectly from any of the following:
> Fire, accidents or theft
> Abuse or negligence
> Misuse — for example, racing or
overloading
>Improper repairs
> Alteration or tampering, including
installation of non-Scion Authorized
Accessories
> Lack of or improper maintenance,
including use of fluids other than
those specified in the Owner’s
Manual
> Installation of non-Scion Authorized
Parts
> Airborne chemicals, tree sap, road
debris (including stone chips), rail
dust, salt, hail, floods, wind storms,
lightning and other environmental
conditions
> Water contamination
This warranty also does not cover the
following:
Tires
Tires are covered by a separate
warranty provided by the tire
manufacturer. See page 28.
Normal Wear and Tear
Noise, vibration, cosmetic conditions
and other deterioration caused by
normal wear and tear.
NEW VEHICLE LIMITED WARRANTY
WA
REPLACEMENT PARTS
Warranty coverage is not dependent
upon the use of any particular brand of
replacement parts. However, Scion
recommends using only Scion
Authorized Parts when you need to
replace a part on your vehicle. Like all
Scion products, Scion Authorized Parts
are built to the highest standards of
quality, durability and performance.
They are also designed to fit your
vehicle’s exact specifications.
Your Authorized Servicing Dealership
maintains an extensive inventory of
Scion Authorized Parts to meet your
vehicle service needs. And because it is
linked electronically to Scion’s Parts
Distribution Centers, the dealership
has quick access to any parts it may
not have in stock.
Scion Authorized Parts are covered by
their own warranty (see your dealer for
details) or the remainder of any
applicable New Vehicle Limited
Warranty, whichever is longer.
Non–Scion Authorized Parts, or any
damage or failures resulting from
their use, are not covered by any
Scion warranty.
GENERAL INFORMATION
You are responsible for ensuring that
your Scion is operated and maintained
according to the instructions in the
Owner’s Manual and this booklet.
You should keep detailed records of
vehicle maintenance, since under some
circumstances they may be required for
warranty coverage. These records
should include date of service, mileage
at time of service and a description of
service performed and/or parts
installed. For your convenience, a
maintenance log is included in this
booklet. If you sell your vehicle, you
should give your maintenance records
to the new owner.
Scion will not deny a warranty claim
solely because you do not have records
to show that you maintained your
vehicle. However, damage or failures
caused by improper maintenance or
lack of maintenance are not covered
under warranty.
Dadhawk (08-10-2017)
Old 08-10-2017, 09:49 AM   #73
JSube
JSube's Avatar
Drives: 2017 ISM PP BRZ
I'd strongly encourage you to look into the '17 Performance Pkg cars. Adding the Sachs dampers and Brembos with great looking wheels for $1K is a crazy bargain, IMO. I also suspect the shorter final drive is a big plus and hides some of the torque dip character, but I don't have any seat time in earlier cars. If you're getting the car for it's chassis like I did, the PPkg. enhances things I care most about. I love this thing and I came out of a '15 STI, which I also loved, but not that much I guess
JSube is offline   Reply With Quote
The Following 3 Users Say Thank You to JSube For This Useful Post:
Harjotdhanota (08-10-2017), JonRZ (08-14-2017), Tcoat (08-10-2017)
Old 08-10-2017, 02:32 PM   #74
Sonder
Drives: '17 BRZ w/ PP || MBTA
I've never tracked or autocrossed a car before. I've only driven automatics and have only driven 2 cars with over 200hp in them, an '07 Mustang V6 and a '07 Volvo S40 T5. Both belonging to my parents.
I went with the performance package though anyways. One, because the wheels with the red calipers look so much better. Two, if I ever wanted to track it I'd have some necessary components. Three, resale value should I decide to sell it down the road. Four, the deal was too good to pass up and I probably would have regretted not getting it.
Will I take full advantage of what the PP offers? We'll see.
Sonder is offline   Reply With Quote
The Following User Says Thank You to Sonder For This Useful Post:
Tcoat (08-10-2017)
Old 08-10-2017, 02:38 PM   #75
bababooey
Drives: BRZ SWP Limited -6MT
@Tcoat, hope you didnt copy line by line , that is a tall post
EDIT: to contribute, I didnt realize how much money could be sunk/spent (depending on perspective) into trinkets & doodads for various upgrades
bababooey is offline   Reply With Quote
The Following User Says Thank You to bababooey For This Useful Post:
Tcoat (08-10-2017)
Old 08-10-2017, 02:48 PM   #76
Copy? I wrote that all out by hand, took a picture, converted it to Adobe, printed it then typed it out here. Someplace along the line it took on a wonky format.
A lot of money can be spent on stuff. If much of that stuff is actually an "upgrade" is debatable.
bababooey (08-10-2017)
Old 08-10-2017, 04:53 PM   #77
Jasonb
Drives: 17 Series Yellow BRZ
I've had a 2017 Series Yellow Subaru BRZ for 5 weeks now and a little over 2,200 miles. I have literally zero complaints. The stereo and the head unit is fine. I use bluetooth to my Galaxy S8 for music and it works fine. It works just fine and sounds just fine. No complaints there. The stock tires are also not bad. They are made more for fuel mileage, tire life, and to be somewhat quiet, but stick decently well for how I drive. The power, at least on the 2017 model years that are 6 speed manual is not that bad either. Sure, an extra 50hp and 50ft lbs of torque wouldn't hurt but it's still a fun car. Exiting a corner at 5,000+ rpm in 3rd is plenty of fun. I plan to probably do a Nameless axleback for some better sound, and then eventually a UEL header and an OpenFlash tablet for a little extra power and to reduce the torque dip. The Series Yellow has Subaru's performance package included which has the better shocks, bigger brakes, and better looking and .5" wider wheels, so I won't be changing wheels, or upgrading brakes or suspension. All I really want to do is some exhaust pieces and an open flash tablet.
Jasonb is offline   Reply With Quote
The Following User Says Thank You to Jasonb For This Useful Post:
Tcoat (08-10-2017)
Old 08-10-2017, 09:23 PM   #78
LudwigMiles
Drives: '13 BRZ
This. This. This.
This is the point of the car.
You don't need to mod anything.
The car is not a muscle car, it's a scalpel.
In case I never said it, I REALLY like this car.
Old 08-12-2017, 06:38 AM   #79
JSube
JSube's Avatar
All that stuff you're thinking of doing in front of the exhaust will have a huge effect on the sound of your exhaust. Nameless makes a solid product but all their mufflers, regardless of size, are turned up to 11 after they're broken in. If that's what you're after, then full speed ahead!
Old 08-14-2017, 07:03 PM   #80
Jasonb
You really think the Nameless axleback 2.5" with the 5" mufflers is going to be loud? And then crazy loud with a header? I want a bit of extra sound, and a nice deep sound, but I don't want it to be obnoxious. I kinda figured with the stock front pipe, overpipe and midpipe still in place it would still be kind of tame.
Old 08-14-2017, 08:06 PM   #81
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
I've had my 2017 BRZ performance package for 7 months now and I would buy it again in a heartbeat. The car itself is a ton of fun to drive stock.
There's another BRZ owner in Dallas who has his heavily modded (Tomei headers, CF hood/wing, KW coils, ecutek tune, e85, etc), and we're putting down the same numbers at MSR Cresson in my stock (at the time) car. He was not happy about that.
mjanmohammad is offline   Reply With Quote
Old 08-14-2017, 09:23 PM   #82
Jasonb
Really? Stock 2017 had the same power as an earlier year running headers, and an e85 tune?
Old 08-14-2017, 09:31 PM   #83
fierostetz
fierostetz's Avatar
Drives: '87 Buick GN, '16 500 Abarth
Same numbers as in times at the track
Past Rides: '87 Mazda 626 with junkyard turbo, '86 Fiero SE v8 swap, '87 Fiero GT v8 swap, '87 Grand National, '96 Nissan Maxima (s/c), '04 Dodge SRT-4, '08 VW Rabbit 5cyl, '10 VW Golf 5cyl.
Current: '87 Grand National '16 Fiat 500 Abarth (dumb, immature fun!!)
Shopping for a BRZ/'86 right now as an additional toy.
fierostetz is offline   Reply With Quote
Old 08-14-2017, 10:16 PM   #84
Jasonb
Gotcha. That's even more fun than dyno numbers. I want to do a track day eventually. I'm in south eastern NC, I wonder what road courses are around here that let people drive on them.
After owning it for several years - would you still buy it again? accel Scion FR-S / Toyota 86 GT86 General Forum 118 06-22-2017 10:35 PM
Owning S2000 and 86 Chad86 Other Vehicles & General Automotive Discussions 21 11-16-2015 02:31 AM
Owning an FRS for a year... krulux Scion FR-S / Toyota 86 GT86 General Forum 60 08-08-2015 02:02 PM
Owning a frs in canada badlab CANADA 32 04-01-2015 03:31 PM
My 24 experience owning an FR-S Doji Style Scion FR-S / Toyota 86 GT86 General Forum 7 06-06-2012 09:16 PM
