#71 | |
Drives: '13 BRZ
Unmolested bone stock cars with low miles that have not been abused are out there. You just need to find them. I found a '13 from the original owner who was a perfect seller. No mods, never driven hard, garaged, etc. What are grounds for a void warranty ? |
#72 | |
https://www.toyota.com/t3Portal/docu...FRS_WMG_lr.pdf WHAT IS NOT COVERED This warranty does not cover damage or failures resulting directly or indirectly from any of the following: > Fire, accidents or theft > Abuse or negligence > Misuse — for example, racing or overloading >Improper repairs > Alteration or tampering, including installation of non-Scion Authorized Accessories > Lack of or improper maintenance, including use of fluids other than those specified in the Owner’s Manual > Installation of non-Scion Authorized Parts > Airborne chemicals, tree sap, road debris (including stone chips), rail dust, salt, hail, floods, wind storms, lightning and other environmental conditions > Water contamination This warranty also does not cover the following: Tires Tires are covered by a separate warranty provided by the tire manufacturer. See page 28. Normal Wear and Tear Noise, vibration, cosmetic conditions and other deterioration caused by normal wear and tear. NEW VEHICLE LIMITED WARRANTY WA REPLACEMENT PARTS Warranty coverage is not dependent upon the use of any particular brand of replacement parts. However, Scion recommends using only Scion Authorized Parts when you need to replace a part on your vehicle. Like all Scion products, Scion Authorized Parts are built to the highest standards of quality, durability and performance. They are also designed to fit your vehicle’s exact specifications. Your Authorized Servicing Dealership maintains an extensive inventory of Scion Authorized Parts to meet your vehicle service needs. And because it is linked electronically to Scion’s Parts Distribution Centers, the dealership has quick access to any parts it may not have in stock. Scion Authorized Parts are covered by their own warranty (see your dealer for details) or the remainder of any applicable New Vehicle Limited Warranty, whichever is longer. Non–Scion Authorized Parts, or any damage or failures resulting from their use, are not covered by any Scion warranty. GENERAL INFORMATION You are responsible for ensuring that your Scion is operated and maintained according to the instructions in the Owner’s Manual and this booklet. You should keep detailed records of vehicle maintenance, since under some circumstances they may be required for warranty coverage. These records should include date of service, mileage at time of service and a description of service performed and/or parts installed. For your convenience, a maintenance log is included in this booklet. If you sell your vehicle, you should give your maintenance records to the new owner. Scion will not deny a warranty claim solely because you do not have records to show that you maintained your vehicle. However, damage or failures caused by improper maintenance or lack of maintenance are not covered under warranty.
| The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (08-10-2017) |
#73 | |
Drives: 2017 ISM PP BRZ
I'd strongly encourage you to look into the '17 Performance Pkg cars. Adding the Sachs dampers and Brembos with great looking wheels for $1K is a crazy bargain, IMO. I also suspect the shorter final drive is a big plus and hides some of the torque dip character, but I don't have any seat time in earlier cars. If you're getting the car for it's chassis like I did, the PPkg. enhances things I care most about. I love this thing and I came out of a '15 STI, which I also loved, but not that much I guess
![]() Quote:
| The Following 3 Users Say Thank You to JSube For This Useful Post: |
#74 | |
Drives: '17 BRZ w/ PP || MBTA
I went with the performance package though anyways. One, because the wheels with the red calipers look so much better. Two, if I ever wanted to track it I'd have some necessary components. Three, resale value should I decide to sell it down the road. Four, the deal was too good to pass up and I probably would have regretted not getting it. Will I take full advantage of what the PP offers? We'll see. |
| The Following User Says Thank You to Sonder For This Useful Post: | Tcoat (08-10-2017) |
#75 |
Drives: BRZ SWP Limited -6MT
@Tcoat, hope you didnt copy line by line
, that is a tall postEDIT: to contribute, I didnt realize how much money could be sunk/spent (depending on perspective) into trinkets & doodads for various upgrades |
| The Following User Says Thank You to bababooey For This Useful Post: | Tcoat (08-10-2017) |
#76 | |
A lot of money can be spent on stuff. If much of that stuff is actually an "upgrade" is debatable.
| The Following User Says Thank You to Tcoat For This Useful Post: | bababooey (08-10-2017) |
#77 |
Drives: 17 Series Yellow BRZ
I've had a 2017 Series Yellow Subaru BRZ for 5 weeks now and a little over 2,200 miles. I have literally zero complaints. The stereo and the head unit is fine. I use bluetooth to my Galaxy S8 for music and it works fine. It works just fine and sounds just fine. No complaints there. The stock tires are also not bad. They are made more for fuel mileage, tire life, and to be somewhat quiet, but stick decently well for how I drive. The power, at least on the 2017 model years that are 6 speed manual is not that bad either. Sure, an extra 50hp and 50ft lbs of torque wouldn't hurt but it's still a fun car. Exiting a corner at 5,000+ rpm in 3rd is plenty of fun. I plan to probably do a Nameless axleback for some better sound, and then eventually a UEL header and an OpenFlash tablet for a little extra power and to reduce the torque dip. The Series Yellow has Subaru's performance package included which has the better shocks, bigger brakes, and better looking and .5" wider wheels, so I won't be changing wheels, or upgrading brakes or suspension. All I really want to do is some exhaust pieces and an open flash tablet.
| The Following User Says Thank You to Jasonb For This Useful Post: | Tcoat (08-10-2017) |
#78 |
Drives: '13 BRZ
#79 | |
All that stuff you're thinking of doing in front of the exhaust will have a huge effect on the sound of your exhaust. Nameless makes a solid product but all their mufflers, regardless of size, are turned up to 11 after they're broken in. If that's what you're after, then full speed ahead!
#80 | |
#81 |
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
I've had my 2017 BRZ performance package for 7 months now and I would buy it again in a heartbeat. The car itself is a ton of fun to drive stock.
There's another BRZ owner in Dallas who has his heavily modded (Tomei headers, CF hood/wing, KW coils, ecutek tune, e85, etc), and we're putting down the same numbers at MSR Cresson in my stock (at the time) car. He was not happy about that.
#82 | |
#83 | |
Drives: '87 Buick GN, '16 500 Abarth
Same numbers as in times at the track
Past Rides: '87 Mazda 626 with junkyard turbo, '86 Fiero SE v8 swap, '87 Fiero GT v8 swap, '87 Grand National, '96 Nissan Maxima (s/c), '04 Dodge SRT-4, '08 VW Rabbit 5cyl, '10 VW Golf 5cyl.
Current: '87 Grand National '16 Fiat 500 Abarth (dumb, immature fun!!) Shopping for a BRZ/'86 right now as an additional toy. |
#84 |
| After owning it for several years - would you still buy it again? | accel | Scion FR-S / Toyota 86 GT86 General Forum | 118 | 06-22-2017 10:35 PM |
| Owning S2000 and 86 | Chad86 | Other Vehicles & General Automotive Discussions | 21 | 11-16-2015 02:31 AM |
| Owning an FRS for a year... | krulux | Scion FR-S / Toyota 86 GT86 General Forum | 60 | 08-08-2015 02:02 PM |
| Owning a frs in canada | badlab | CANADA | 32 | 04-01-2015 03:31 PM |
| My 24 experience owning an FR-S | Doji Style | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 06-06-2012 09:16 PM |
