#43 |
Drives: FT86
If 3 was noticably darker than 1 then it suggests a problem with 3. It looked a bit dark to me, but hard to tell from photo.
Its possible that its either not firing spark plug correctly or the 3 injector is leaky/defective and its running rich on that cylinder as a result you done coil and plug, so swapping 1/3 injectors and see if misfire starts on 1. Its then possible its leaky damaged direct injector, but thats a crap load of work and expense and you would not want to do that without proper diagnosis. They are matched set and all seals and fuel rails should be replaced if removed. alter that its looking difficult like weird wiring fault looks like shop time http://www.ft86club.com/files/BRZwiringi.pdf |
#44 | |
Drives: FT86
#45 |
Drives: Track preped NA FRS
For what is worth. I've had problems with P0351 (coilpack cylinder 1) for the last 2 years. My car is NA and on gas really not an apples to apples problem, but when the code would show up it would iddle like crap. Last time I changed the coil, I decided to look at the plugs, my plug on cylinder 1 looked like yours, while the rest were not as black. After the last time I changed it, I had a problem with the vtt sensor (P0016). It was only the sensor, and swapping to a new one fixed the issue. But another coilpack has gone by since that. It looks to me like something isnt right somewhere else and the consequence (not the cause) is the coilpack failing, or the vt sensor failing as well, both could result from extra heat on cylinder 1. I do not know the source of my problems, I cant really diagnose it since changing the coilpack seems to magically fix everything, so I think Im stuck with it.
I saw somewhere that there is a very recent service bulletin for 2013-2014 cars to change out their wirning harness and coilpacks to the newer version (2015-2016) because there is an issue where they get loose and cut connection. I think your next logical step is to disconnect the coilpack and mesure the voltage, current and resistance of everything in between the ECU and the coilpack itself, including connectors and wires. It could be as simple as a burnt wire not transmitting an stable signal. I didnt see any post about you testing connections (altho I skimmed over your thread rather quickly), so maybe try that next since its easy. Good luck on your search. |
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | Sojhinn (07-31-2017) |
#46 |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Swapped cylinder 1 & 3 injectors. Same issue on cylinder 3.
So that leaves weird wiring issue, mechanical issue for cylinder 3 (valve or something) , or di system. Taking it a shop this morning. Thanks for all your help guys. I'll make sure to respond with the solution. Sent from my iPhone using Tapatalk
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
| The Following User Says Thank You to Sojhinn For This Useful Post: | Icecreamtruk (07-31-2017) |
#47 |
No compression cylinder 3.
| The Following 2 Users Say Thank You to Sojhinn For This Useful Post: | Chronology (07-31-2017), Icecreamtruk (07-31-2017) |
#48 |
#49 | |
I have the car at shop down here. (JuJu Built) Working on plans. Leak down test pointing to intake valves. If that's the case going to build the heads. Sent from my iPhone using Tapatalk
| The Following 2 Users Say Thank You to Sojhinn For This Useful Post: | Chronology (07-31-2017), humfrz (08-01-2017) |
#50 |
Drives: 13' Satin White Pearl BRZ
Glad you got in the shop today. I'm sure they will pull it and open it up today, fingers crossed on the best of the worst case.
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
| The Following User Says Thank You to Chronology For This Useful Post: | Sojhinn (07-31-2017) |
#51 | |
Thanks again bro. I really appreciate everything you did. Sent from my iPhone using Tapatalk
#52 |
While I'm waiting for the engine to be pulled. Anyone want to daydream and come up with some ideas for some awesome parts to put in?
#53 |
Drives: 2016 Scion FR-S
#54 |
Drives: Subaru BRZ 2017
| Ignition Coils - Misfiring Help | SmireyFase | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 16 | 11-10-2016 03:06 PM |
| Engine Misfiring and Stalling | FIREISFUN135 | Issues | Warranty | Recalls / TSB | 7 | 09-19-2016 04:19 PM |
| Rough day for my 86 | KiddCoast | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 33 | 03-23-2015 04:30 AM |
| Stalling, Misfiring, poor idle.. Car is at Toyota, hopefully some results soon | WTF | Issues | Warranty | Recalls / TSB | 12 | 06-14-2014 11:40 PM |
| At 5,000kms and fuel injectors 2 & 4 are misfiring!!! | UnLeasHer | AUSTRALIA | 55 | 11-12-2012 05:41 AM |
