Old 07-25-2017, 02:26 PM   #43
churchx
churchx's Avatar
Drives: 2014 GT86
Would anyone blame torque dip if it had been honda's 4-banger? VTEC, yo
Old 07-25-2017, 04:46 PM   #44
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
S2000 being somewhat comparable at 100hp per liter has a flat torque from 3000rpms - 6000rpms before rising at the end. Not much better at all. Would rather have our linear torque rise with UEL & Tune
SuperTom is offline   Reply With Quote
Old 07-25-2017, 07:41 PM   #45
Williampreza
Williampreza's Avatar
Drives: 2017 Ice Silver BRZ Limited
You would definitely want to pass on this idea then. There will almost certainly be losses in other areas of the powerband. Without variable cams or variable intake geometry, every breathing mod is bound to be a compromise. This is (may be, should be, maybe will be) a compromise in favor of high rpm power at the expense of torque somewhere lower down.
Williampreza is offline   Reply With Quote
Old 07-26-2017, 08:38 AM   #46
celek
Resident Gear Head
celek's Avatar
Originally Posted by Williampreza View Post
Second suggestion, slightly more involved/expensive would be to hack the legs off a stock pre-2017 manifold (used ~$75) and epoxy in a box or cylinder. Problem with that is adjusting the volume to experiment/ building more iterations.
I am working on that
celek is offline   Reply With Quote
The Following 3 Users Say Thank You to celek For This Useful Post:
Jonsey (07-26-2017), ort895 (07-27-2017), Williampreza (07-26-2017)
Old 07-26-2017, 10:35 AM   #47
Williampreza
Those are lovely indeed! Been following your ITB build, getting all sorts of ideas (dual plenum, dual throttle body, cross ram!) 😂
Old 07-26-2017, 10:47 AM   #48
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Hey Celek,
I love the ITB project, was looking at it in the other thread a couple of weeks ago. I know you know what you're doing, but I'd just like to offer a suggestion that you can take or leave, but that I feel very strongly about:
I would strongly recommend against using two throttle motors and instead either use a throttle motor/wheel mounted between the runner banks, and then link that throttle wheel to throttle wheels on each set of throttle bodies. Or You could run the throttle on one bank as you have it set, and then on the opposite side of the bank run a throttle wheel with a linkage going to the other bank of throttle bodies attached to it's own throttle wheel.
I would hate to have to deal with two throttles that potentially didnt react the same, or at worst one failed so it was substantially slower than the other or didnt open at all. It might make the problem of syncing them a non-issue, and reduce the likelihood of some tuning issues.
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
The Following 5 Users Say Thank You to GrimmSpeed For This Useful Post:
Captain Snooze (07-26-2017), celek (07-27-2017), CSG Mike (07-26-2017), Jonsey (07-27-2017), wparsons (07-26-2017)
Old 07-26-2017, 11:17 AM   #49
CSG Mike
CSG Mike's Avatar
Here's my s2000.
Old 07-26-2017, 11:19 AM   #50
CSG Mike
CSG Mike's Avatar
Just for funsies.... C30-94 on F22C, but out of fuel pump. ACN91.
Old 07-26-2017, 11:28 AM   #51
radroach
Drives: car
@CSG Mike
might want to get those links checked out, photobucket doesn't support linking any more.
The Following 2 Users Say Thank You to radroach For This Useful Post:
Teseo (07-27-2017), wparsons (07-26-2017)
Old 07-26-2017, 03:06 PM   #52
SuperTom
SuperTom's Avatar
Originally Posted by radroach View Post
@CSG Mike
Yep switch to imgur
Old 07-27-2017, 08:52 AM   #53
celek
Resident Gear Head
celek's Avatar
Originally Posted by GrimmSpeed View Post
Hey Celek,
Chase
Engineering
I will have to search through my saved links I have a company that makes a sync box for 2 throttle bodies. Not overly expensive. Or maybe I will build an Arduino box that way I can tune each side perfectly
The Following User Says Thank You to celek For This Useful Post:
wparsons (07-27-2017)
Old 07-29-2017, 09:04 PM   #54
Williampreza
Not specifically what you are talking about, but related and relevant for people interested in multiple throttle bodies/intake manifolds.
http://www.promracing.com/pro-m-duo-...er-module.html
Old 07-29-2017, 09:18 PM   #55
Williampreza
Here's my s2000.
Would love to see these pics. Can you repost?
Old 07-30-2017, 02:15 AM   #56
CSG Mike
CSG Mike's Avatar
ugh, effing photobucket.
high rpm, intake manifold, na build
2013 intake manifold vs 2017 Aluminium intake manifold Bobster Engine, Exhaust, Transmission 29 12-19-2016 10:40 AM
FBM Intake Manifold Fonzi Engine, Exhaust, Bolt-Ons 1 03-11-2016 07:36 PM
Intake Manifold Fonzi Engine, Exhaust, Bolt-Ons 0 03-03-2016 08:29 PM
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
BRZ, FR-S, GT86 | Power Block Manifold Riser by Crawford Performance | UP TO 25% OFF! iA Performance Groupbuys 18 11-04-2014 04:25 PM
