Old 07-21-2017, 01:56 PM   #1
Williampreza
Williampreza's Avatar
Drives: 2017 Ice Silver BRZ Limited
NA Power: Intake Manifold Volume Solution?
I've read in several places on this forum that one of the obstacles to NA power is the intake manifold, specifically that the plenum volume is insufficient.
One example from @celek :
Agree with both statements above.
I think our TQ dip is partially because the head outflows the stock manifold, completely emptying the plenum until it starts to catch back up.
The heads if you think about it, the port design is simular if not the same as the FB25... 2.5ltr Turbo, or the FA20DIT WRX.
They flow enough power to make 750+ HP with minimal or no modification.
That being said on a NA 2.0ltr they outflow the stock manifold. But even with attempts to make an afermarket manifold out there no one is increasing the plenum size enough and the same result occurs.
The head does not need ported its factory flow is fine. The actual bottleneck is the intake itself. @Tim Radley told me he actually gained some power positioning putty in the intake ports to choke it down and gain more velocity. Making it more efficient to the manifold on top.
From this thread: OFT Tuning to 8,500 RPM
I've also seen a couple of attempts to resolve this issue by completely redesigning the intake manifold, with the flaws @celek pointed out above.
What if a simpler solution/test of this hypothesis was attempted?
If the plenum= volume from the throttle body to the intake runners, then why not simply add volume by adding spacers behind the throttle body? It's not a complicated shape and the "plenum" on the stock manifold is not large enough (IMHO) that the diameter change would matter (right?).
Additionally, since spacers would be simple to fabricate (I'm thinking a rectangular block of plastic, cut into different lengths to test and 5 holes drilled through, one big one and four for bolts. A fancier approach could be a length of pipe with flanges on each end for the manifold and TB to attach to.
"Why haven't you tried this yourself?" you might ask.
Well, I'm nowhere near a tuner that could test and tune, I don't have an intake tube that's adaptable to the the resulting changes in physical position of the TB, and, frankly, I'm not on that level of "tuning" yet.
To sum up:
1.) Fabricate several different lengths of spacers, basically throttle body-diameter tubes, to go between the TB and the intake manifold.
2.) Sell first-born for money for dyno time.
3.) Bolt each one on, tune , then try the next size, and so on till one works.
4.) If none of that works, I have other ideas, all involving hacking the plenum and epoxy.
Thoughts?
@celek, @Tim Radley, @Element Tuning
Last edited by Williampreza; 07-21-2017 at 02:11 PM. Reason: Tagging interested parties.
Williampreza is offline   Reply With Quote
Old 07-21-2017, 02:07 PM   #2
OND
OND's Avatar
Drives: 2023 BRZ
Intake plenum volume is not that hard to tune, so I can't imagine why Subaru would get it wrong.
There are already TB spacers and IM spacers out there, but I am not sure if any of them give solid gains.
OND is offline   Reply With Quote
Old 07-21-2017, 02:35 PM   #3
Williampreza
Doing more reading on this subject, working my way back through Jeff Hartman's "How to Tune and Modify Engine Management Systems" to grapeaperacing.com and on to their white paper on induction systems, page 13, suggests that we're looking at a plenum volume of roughly 40-50% of total cylinder displacement (for 7000-7500 rpm). So 1 liter.
At 65 mm diameter, that's an 9-11 inch tube. Hmm...
Old 07-21-2017, 02:46 PM   #4
wparsons
wparsons's Avatar
I don't agree with the original hypothesis. If it were the heads out flowing the manifold, it would get choked further as RPM's increase.
The IM spacers increase runner length and shift the power lower in the RPM band.
There's also good evidence that a good header and tune totally eliminates the torque dip without going near the TB and IM.
flickr
Old 07-21-2017, 02:51 PM   #5
Williampreza
mmm.. Yes. I've seen this exact argument elsewhere and I think you were involved. My point is that this is an easily and relatively cheaply testable hypothesis. Also, we're not talking about intake runner length, we are manipulating plenum volume, albeit by adjusting the effective length of the plenum.
Old 07-21-2017, 02:52 PM   #6
It's a volume vs flow issue. I can verify that the IM is indeed the limiting factor.
Old 07-21-2017, 02:53 PM   #7
Most manufacturers/cars have intentionally undersized plenums to boost low RPM efficiency for MPG.
Old 07-21-2017, 03:04 PM   #8
Williampreza
Second suggestion, slightly more involved/expensive would be to hack the legs off a stock pre-2017 manifold (used ~$75) and epoxy in a box or cylinder. Problem with that is adjusting the volume to experiment/ building more iterations.
Old 07-21-2017, 03:07 PM   #9
Williampreza
Oh! I forgot to include the volume of the existing plenum. That makes this much more reasonable. (Anybody know what the stock plenum volume is?)
Old 07-21-2017, 03:09 PM   #10
airjonny
airjonny's Avatar
Drives: Nissan Murano
Wonder if that is the same case for the red intake manifolds. Is anyone tuned on the 17s yet?
airjonny is offline   Reply With Quote
Old 07-21-2017, 03:14 PM   #11
Williampreza
I have a 17 with the red intake and no, I'm not going to hack at it (yet)
Old 07-21-2017, 04:17 PM   #12
Icecreamtruk
Drives: Track preped NA FRS
Very interesting topic, I sadly dont have anything to add to it, but Im all for learning so, in for the updates
Old 07-21-2017, 08:17 PM   #13
majjbjohn
Drives: 2015 FR-S
dosent jim crawford make spacers?
eta: yeap
https://crawfordperformance.com/coll...t-brz-frs-gt86
majjbjohn is offline   Reply With Quote
Old 07-21-2017, 08:18 PM   #14
Williampreza
Yes, but those are for the intake runners. This is for the plenum.
high rpm, intake manifold, na build
2013 intake manifold vs 2017 Aluminium intake manifold Bobster Engine, Exhaust, Transmission 29 12-19-2016 10:40 AM
FBM Intake Manifold Fonzi Engine, Exhaust, Bolt-Ons 1 03-11-2016 07:36 PM
Intake Manifold Fonzi Engine, Exhaust, Bolt-Ons 0 03-03-2016 08:29 PM
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
BRZ, FR-S, GT86 | Power Block Manifold Riser by Crawford Performance | UP TO 25% OFF! iA Performance Groupbuys 18 11-04-2014 04:25 PM
