Old 07-21-2017, 11:14 AM   #1
chazmuska
chazmuska's Avatar
Drives: 2014 Scion FR-S
OFT is flashing on and off sporadically...very erratic!
So I recently purchased an OFT just a couple of weeks ago, and this morning it was acting very erratic. When I attempted to go to real data display to view my ECU's live data...it just started blinking on and off very erratically. I emailed sales@openflashperformance to see what they recommend. Has this happened to anyone, if so how can I fix it?
Note: Everything else is working fine when toggling through the menus. I've tried to unplug and replug it back in, still no luck.
Link to video: https://urldefense.proofpoint.com/v2...xJRvKvD9mFg&e=
chazmuska is offline   Reply With Quote
Old 07-21-2017, 12:11 PM   #2
PandaBRZ
PandaBRZ's Avatar
Drives: SWP BRZ
You have a tuning alert set that is being triggered. That sound and flashing to to ensure you know something critical is happening like overheating, high oil temps, etc. Go into your tuning alerts and check your recipes.
Read my writing about the BRZ on my website.
PandaBRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to PandaBRZ For This Useful Post:
chazmuska (07-21-2017), Tcoat (07-21-2017)
Old 07-21-2017, 12:51 PM   #3
chazmuska
chazmuska's Avatar
Interesting you say that because yesterday I did, for the first time, set a tuning alert for Oil Temp and coolant temp, but they were set at 240 degrees and 235 respectively....and I had just turned on my car when it started doing this (engine was cold). I did forget to mention that I deleted the tuning alerts thinking that was the issue but it still does it! Just prior to me setting the alerts I also did a calibration because touch sensitivity was way off. (took me three tries even with a stylus pen). I'll play around with it again on my lunch break to see if I can get it to stop flashing.
UPDATE: I figured it out! Apparently I never deleted the alerts. After taking a closer look at the alert table settings, the temperature settings were set to go off "under" the values I entered. All I had to do was convert the symbol < to >. Something so simple overlooked. At least now I know how the Alert is displayed!
Old 01-16-2018, 12:59 AM   #4
SkyeHack
SkyeHack's Avatar
Drives: 2018 BRZ tS
What mount are you using for your OFT?
SkyeHack is offline   Reply With Quote
AFR mostly rich, erratic at times Synack Forced Induction 49 07-07-2018 11:15 AM
wrong flashing my ECU aagun Software Tuning 5 11-09-2016 03:18 PM
Scion FRS Police Standoff Erratic Driver Arrested After Chase Speed2th Off-Topic Lounge [WARNING: NO POLITICS] 7 05-22-2016 03:38 AM
Flashing from E85 to 91 Phantobe Software Tuning 18 02-16-2015 06:44 PM
Flashing cel wtf ! :/ sweetfrs Issues | Warranty | Recalls / TSB 16 12-07-2013 02:13 AM
