Old 04-06-2015, 02:34 PM   #1
Synack
Boosted
Synack's Avatar
Drives: Sideways
AFR mostly rich, erratic at times
Just developed this issue today and being that this is my first turbocharged car I would like to ask for some help diagnosing possibilities.
  1. When I cold start the car, everything is fine at idle.
  2. When I start to drive the car at normal throttle, the AFR tends get pegged at 10 after a minute.
  3. Come to a stop and now my idle is 10 for AFR.
  4. Now low throttle and normal throttle driving has awful response and is still at 10.
  5. Every now and then the AFR gets back to normal or almost normal for ~30 seconds, and then it will go back to 10 AFR.
After some research I've found a broad list of issues it might be:
  • Air filter (new one shipped tomorrow)
  • MAF dirty (about to go buy cleaner and spray it)
  • Boost leak (after MAF?)
  • Fuel pump (I already have a 485LPH brand new sitting at home)
  • Spark plugs (20,000 miles on the same plugs, never replaced since turbo setup)
  • Injectors
I was hoping I could get it narrowed down a bit more before I start throwing money at it.
Old 04-06-2015, 03:25 PM   #2
350matt
Drives: toyota mr2/ Toyota GT86
Hello
I'd check for exhaust leaks before the O2 sensor as if this has been experiencing an exhaust leak then it will have been running very rich as the sensor will see the extra air pulled in as fresh / lean fuelling and be adding fuel to compensate.
if thats OK try replacing the 1st O2 sensor
350matt is offline   Reply With Quote
Old 04-06-2015, 03:34 PM   #3
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by 350matt View Post
Hello
Running wideband and the 2nd O2 is disconnected I believe. I'll check for leaks around the turbo.
Are you talking mostly about turbine housing exit to exhaust area?
Old 04-06-2015, 03:57 PM   #4
350matt
yes any leaks upstream of an O2 sensor can pull air in and so give a false rich reading
you say you're running wideband, is the sensor replacing the factory wideband or is it additional?
also are you on the stock ECU with ECUtek, OFT etc? or on a standalone like Motec?
Old 04-06-2015, 04:09 PM   #5
Synack
Boosted
Synack's Avatar
Drives: Sideways
Almost positive the wideband replaced factory, I'll have to double check as I haven't even had to look at it since building the car.
I use Ecutek.
Old 04-06-2015, 05:05 PM   #6
350matt
OK if the wideband has replaced the stock item and you're not using any closed loop function in your tune then it won't be effected by any leaks or faulty sensor
from the sound of it though I suspect that you are using closed loop but have changed the sensor gains so it uses the Wide band as the main input
Old 04-06-2015, 05:13 PM   #7
Kodename47
Kodename47's Avatar
Drives: UK GT86
Have you any catalogs? Might help to see if trims are at play etc?
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-06-2015, 06:17 PM   #8
Synack
Boosted
Synack's Avatar
Drives: Sideways
All I have at the moment is Torque. Which I doubt can help.
I know for a fact that the 2nd O2 is disconnected. I don't know about the closed loop or not because I didn't tune or build the car. I've only taken it apart several times for maintenance and parts/turbo replacements and the occasional cleaning.
Old 04-06-2015, 06:21 PM   #9
Synack
Boosted
Synack's Avatar
Drives: Sideways
Saw some improvement on the drive home for no reason whatsoever. Was running upper 12's and 13 flat AFR for most of the ride in higher gears and part throttle. I didn't go past 8psi either, which I'm not sure if it helped the situation or not. Idles at upper 13's and occasionally 14's now as of getting home.
Sprayed the MAF and several other electrical components completely clean just now too.
I suppose I'll update tomorrow but I'm very skeptical that this just randomly "fixed" itself. Unless maybe there was some bad gas or something of the sort.
I have some gaskets on the way because I'm about to buy a new turbo anyway (different reason).
I'll post more symptoms and/or hopeful good updates as soon as they come. Thanks for the help.
Old 04-07-2015, 09:53 AM   #10
Synack
Boosted
Synack's Avatar
Drives: Sideways
STILL HAVING ISSUES
But they aren't as bad.
  • Idle is now ~12 instead of 10. (Still too rich when it used to be 14-15AFR idle)
  • Light throttle ~13-14AFR. (Not really concerned about this but could be better)
  • Heavy throttle 10.5-12AFR. (Definitely too rich)
Any ideas? Could this just be a wideband going bad or?
Old 04-07-2015, 10:41 AM   #11
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Dude you gotta get an EcuTek cable and get some datalogs to trouble shoot. You still running a D3PE tune right.
Old 04-07-2015, 10:48 AM   #12
Synack
Boosted
Synack's Avatar
Drives: Sideways
I'm getting Nick's next week. Yes still running the D3 tune.
I'm literally waiting for the turbo to ship before my flex-fuel upgraded turbo project and now this happens. I just placed an order for a replacement wideband sensor though, I feel like this one has been put through A LOT of crap. It's had oil blasted on it numerous amounts of times before I originally fixed the oil problem. It just seems like a smart move regardless of whether it fixes this problem or not.
Old 04-07-2015, 02:02 PM   #13
Synack
Boosted
Synack's Avatar
Drives: Sideways
It has to be the AEM wideband sensor. Basically every tells me these things are lucky to last 2 years and I've had it for a bit more than that. Combined with said turbo oil problems above I don't see how the sensor even made it this far.
I also noticed that when the key is ON but engine off the sensor reads mid 11's. Not sure what that means.
Old 04-07-2015, 04:48 PM   #14
Kodename47
Kodename47's Avatar
Drives: UK GT86
Tried a recalibration?
I was told some time ago that the NGK sensor AFX was the best wideband if you're not going professional lab quality. It's not too badly priced either.
.: Stealth 86 :.
Kodename 47 DJ:
Cel gas running to rich anthonyravenfrs Scion FR-S / Toyota 86 GT86 General Forum 3 07-15-2014 01:55 AM
So what would you say is too Lean? Too Rich ? Opinions Pls. BC-Boy Software Tuning 27 05-29-2014 10:05 PM
POST YOUR 1/4 MILE TIMES Quarter mile times NYCsubaruBRZ Tracking / Autocross / HPDE / Drifting 1 02-04-2014 06:59 AM
Running rich KslayFRZ Issues | Warranty | Recalls / TSB 15 10-25-2013 11:42 PM
Rich man's FR-S (WRB BRZ) Hamza7 Cleaning and Detailing 9 06-24-2012 11:36 AM
