Old 11-08-2016, 03:38 PM   #1
aagun
Drives: 86
wrong flashing my ECU
i own gt86 that ECU rom ID is JA01J
i flash it with JA01G by mistake . but the car still works fine with no DLC
when i detect that case i reflash it to normal Rom
can i use JA01G to my ecu? and not blind it
as my knowledge the ecu will blind
aagun is offline   Reply With Quote
Old 11-08-2016, 04:26 PM   #2
Paging @steve99
Old 11-08-2016, 04:27 PM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I thought you can flash other tunes so long as they are compatible with your ECU that's why you query the ECU first?? But I have no idea lol!
Old 11-08-2016, 04:47 PM   #4
steve99
Ok what we have found is that the ECU hardware appears to be same for all cars, even auto and manual.
This means you can flash any rom to car 2012-2016 (the my 2017 is an unknown) and it should not "brick" the ECU.
However different countries have different options on car.
for example USA cars have more evap/cpc systems than out Australian car. Infact the CPC pressure connection as used by flex kits is not even pinned on australian cars.
So while a rom from another country will not brick ecu, the car may thow a lot of cel codes as it sees different hardware connections or the firmware in other modules like dash auto trans computer etc is different.
Manual roms wont work in auto cars, well the engine will run but theirs no code (or tables not populated) to talk to the auto trans computer.
But its very likely you could run a A01G rom in your A01J car.
I cannot guarantee this though.
If you find the A01G works fine, it will be very helpfull to you as a lot of development has been done on this rom like flex code.
Old 11-09-2016, 02:44 PM   #5
aagun
Drives: 86
thx for responding . next plan is reflashing JA01G on my car and find what will happen .
Old 11-09-2016, 03:18 PM   #6
See! That is why you are my goto guy on this subject.
Flashing from E85 to 91 Phantobe Software Tuning 18 02-16-2015 06:44 PM
Help flashing w/EcuTek xDanger_208x Software Tuning 5 03-27-2014 09:06 PM
Flashing cel wtf ! :/ sweetfrs Issues | Warranty | Recalls / TSB 16 12-07-2013 02:13 AM
Flashing your ECU question Blackout808 Engine, Exhaust, Transmission 3 04-05-2013 10:33 PM
People flashing the ECU on Mac Bg8780 Engine, Exhaust, Transmission 2 04-04-2013 07:03 PM
