Old 07-19-2017, 08:27 PM   #15
steve99
Drives: FT86
Let the cars idle for a minute stationary
Check the afr and commanded afr both should be pretty close to 14.7 and fairly stable might go to 15 or 14.4 or so but outside that is unusual
Check the long term fuel trims at idle should be less than 10%
If you got unusual values check for intake or exhaust leaks dirty maf sensors clean connectors on maf and o2 sensors.
You can try bumping idle to 750 and setting the overun fuel resume to 1400 from 1300
But fix hardware ussues first
Seen couple if guys with bad front o2 sensors
Bad rear 02 usyally only effect cruise fueling
Detroiter (07-19-2017)
Old 07-19-2017, 09:41 PM   #16
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
OFT - Control Minimum RPMs?
Edit: nevermind I read it wrong :P
Old 07-19-2017, 11:49 PM   #17
Turdinator
Señor Member
Turdinator's Avatar
I found on petrol the stg 2 OFT tunes to be really good at idle. I am now on e85 stg 2 OFT and the idle is not as consistent. Not terrible but will occasionally bounce around. I have a light flywheel so just figured the e85 tune wasn't as sorted.
1974 TA22 Celica
2013 86 GT
Old 07-20-2017, 08:50 AM   #18
majixmatrix
BRZ Wannabee
majixmatrix's Avatar
Drives: 2013 Limited BRZ
Update, changing the PI/DI ratio tables didn't work for me. Might work for you guys with bigger injectors though, definitely worth a shot. It's only been one day but the car is relearning since I reflashed it and dipping as low as ever until it learns not to do that $hit... *sigh*
majixmatrix is offline   Reply With Quote
Old 07-20-2017, 08:52 AM   #19
majixmatrix
BRZ Wannabee
I did some data logging this morning, I'll take a look tonight. I'm pretty sure the car is just learning how low it can go, I just find it very frustrating haha we'll see if it persists but this is really good input, thanks!
Old 07-20-2017, 10:11 AM   #20
paintdude258
paintdude258's Avatar
Same thing has been happening to me for months and months. I have a Tomei UEL and have tried several tunes, cleaned my MAF, air filter, bought new o2 sensors, injector orings replaced, new gaskets for my header and exhaust, yet this problem still persists.
I have noticed that when I have the A/C on, the problem becomes MUCH worse than when I turn the A/C completely off.
Originally Posted by Detroiter View Post
I have been having this issue come up periodically even after putting hundreds of miles on the car after the flash. I'm running a Tomei UEL header with full catless exhaust on the OFT stage 2 e85 tune. Probably every 3 days it seems my car has trouble finding its idle. While monitoring with the OFT I see that the AFR seems to hunt around going up to mid 15s then jumps down to 13s which is where the car seems to bog down and almost stall sometimes turning off the headlights. I can't seem to find any reason as to why it happens though.
paintdude258 is offline   Reply With Quote
The Following User Says Thank You to paintdude258 For This Useful Post:
Detroiter (07-20-2017)
Old 07-20-2017, 03:07 PM   #21
Kodename47
Kodename47's Avatar
Drives: UK GT86
It's not this. There are other settings other than the Target Idle RPM. Correct MAF settings help, it seems having slightly negative trims help. Try increasing the Idle Airflow and Load maps (if they are there).
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-20-2017, 07:54 PM   #22
steve99
Drives: FT86
Idle stability tables may help as well
Old 07-20-2017, 07:57 PM   #23
Kodename47
Kodename47's Avatar
Drives: UK GT86
This tends to be more when blipping the throttle or revs dropping and less so if the idle is unstable, unless the stability tables are jacked up and ends up in oscillation.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-20-2017, 10:09 PM   #24
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Is this only happening on aftermarket headers? Specifically UEL headers? I ask because if that's the case, then the folks with this problem might be running into a peculiarity with the idle control loop. Other than the Target Idle, are there other parameters we can adjust that have been defined? Haven't checked out the "idle stability tables" Steve mentioned, but those sound promising by title.
Maintaining a consistent idle might sound easy, but getting a machine to balance consistently is surprisingly complex. There are likely damping functions built in to the control loop to keep it from oscillating back and forth. Part of setting that up is adjusting for things like intake length, intake resonance, exhaust resistance, exhaust resonance, angular acceleration, etc. Making a change to ANY of these would mess with that control loop. If you change the header to a completely different design, you will have to adjust how the ECU maintains idle, or more likely than not deal with transient effects like this.
Spuds is online now   Reply With Quote
Old 07-20-2017, 11:39 PM   #25
steve99
Drives: FT86
arh ok
well try the overrun fuel resume table maybe bump it to 1400 from 1300
Old 07-20-2017, 11:48 PM   #26
steve99
Drives: FT86
I have UEL header
have my base idle at 650
modded idle stability tables
full DI at idle
no stalls coming to stop
dips slightly on a/c cycling
and on rear demister turn on
but no stall or shaking just dips to say 550 then recovers
Old 07-21-2017, 01:08 AM   #27
Spuds
The Dictater
Spuds's Avatar
I have UEL header
full DI at idle
Wasn't trying to suggest your setup or methodology is incorrect. I actually agree with you on the stability tables if they are what I think they are.
I was just attempting to point out that the shape of the header is a part of the idle control loop. Changing that is the same as messing with the ECU regarding idle stability.
The Following User Says Thank You to Spuds For This Useful Post:
steve99 (07-21-2017)
Old 07-21-2017, 06:21 AM   #28
Yoshoobaroo
TRACKBREAD
I have UEL header
full DI at idle
Can you elaborate on your idle stability tables?
jdl, oft, romraider, rpms, stage 2
Minimum 51% Ethanol smg1138 Software Tuning 13 03-15-2016 04:44 PM
Minimum HPDE Brake Pad Thickness DarkSunrise Tracking / Autocross / HPDE / Drifting 11 10-28-2014 10:26 PM
Set a minimum post count to sell in Classified? mav1178 Site Announcements / Questions / Issues 9 08-26-2013 07:25 PM
The bare minimum? Scaldy Scion FR-S / Toyota 86 GT86 General Forum 8 06-11-2012 09:58 AM
Minimum requirements... Blokatos Scion FR-S / Toyota 86 GT86 General Forum 528 11-15-2011 04:04 PM
