Old 03-12-2016, 07:44 PM   #1
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Minimum 51% Ethanol
Recently I've noticed more and more E85 stations in my area posting this sign on their pumps. It used to be 70% minimum, but that seems to be going away. I'm getting concerned about this because I sometimes run the OFT E85 tune which I believe can only handle a minimum of 60% ethanol content. Should I just give up on E85 or is there something that can done to deal with this change? I'm guessing the OFT tune can be edited to compensate, but I'm not sure how to do that. Anybody tried?
smg1138 is offline   Reply With Quote
Old 03-13-2016, 02:16 PM   #2
Ashikabi
Ashikabi's Avatar
Flex fuel will fix this. But OFT doesn't support it yet. I thought e85 had to be at least 70% by law?
Old 03-13-2016, 02:46 PM   #3
phrosty
Pretty sure Shiv mentioned you only need about ~E40 to handle the timing on his E85 tunes.
If that's the case, you might be able to get away with just rescaling your MAF.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 03-13-2016, 10:10 PM   #4
smg1138
smg1138's Avatar
Really? I could have sworn I read somewhere that it was 60%.
Old 03-13-2016, 10:18 PM   #5
Ashikabi
Ashikabi's Avatar
Ask shiv
Old 03-13-2016, 10:41 PM   #6
phrosty
Originally Posted by Shiv@Openflash View Post
...an NA FA20 will only need perhaps 100oct to make maximum power. Anything above that will not help. Which means that in terms of octane/knock suppression, the FA20 does not need to run E85. It could support maximum power by running something closer to E40.
And there are more threads than that mentioning MBT around E40.
In either case, I doubt it'd be unsafe to try a minimum 51% mix. Your LTFTs will just be fairly far negative. Log knock and ease it in to the higher RPMs if you're worried.
Old 03-14-2016, 08:22 AM   #7
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
Gotta love Australian minimum standards 70% minimum
COO86L is offline   Reply With Quote
Old 03-14-2016, 10:23 AM   #8
smg1138
smg1138's Avatar
Old 03-14-2016, 10:59 AM   #9
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
There's no other way around it...
In order to properly do E85, you need a flex fuel kit and tune.
And its not only for safe power, it's also for cranking fueling and proper idle and fuel trims...
Old 03-15-2016, 01:06 AM   #10
phrosty
Lets keep derailing this thread. What is "properly"? :P
Old 03-15-2016, 02:06 AM   #11
steve99
actually were even luckier than that.
we also have guaranteed 85% e85 , thats guaranteed mixed with high grade petrol (98 ron) with a resultant octance rating on 107 thats guaranteed and you can buy it at pump in many locations
Old 03-15-2016, 10:33 AM   #12
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Hopefully Shiv will comment on what he feels is okay to use with his e85 tune, but I do know he is working on flex fuel for the OFT. He currently has it working on his shop car. Last I heard he just needed to have some local testing done to make sure it is good to release. Shouldn't be too much longer.
DustinS is offline   Reply With Quote
Old 03-15-2016, 10:54 AM   #13
smg1138
smg1138's Avatar
I heard back from Shiv today. He said that the OFT E85 tune is good down to E50. That takes a load off my mind.
Old 03-15-2016, 04:44 PM   #14
cameronjones239
cameronjones239's Avatar
Drives: 2015 Subaru BRZ Series Blue
If it makes you feel any better I've been running on a min 51% station for over a year no problem
cameronjones239 is offline   Reply With Quote
Minimum HPDE Brake Pad Thickness DarkSunrise Tracking / Autocross / HPDE / Drifting 11 10-28-2014 10:26 PM
Set a minimum post count to sell in Classified? mav1178 Site Announcements / Questions / Issues 9 08-26-2013 07:25 PM
The bare minimum? Scaldy Scion FR-S / Toyota 86 GT86 General Forum 8 06-11-2012 09:58 AM
Minimum requirements... Blokatos Scion FR-S / Toyota 86 GT86 General Forum 528 11-15-2011 04:04 PM
Canadian Pricing Prediction: Scion cheaper by $4000 minimum. pastuch Scion FR-S / Toyota 86 GT86 General Forum 6 11-03-2011 08:44 PM
