BRZ Wannabee
Drives: 2013 Limited BRZ
OFT - Control Minimum RPMs?
I recently had my JDL header installed, and flashed to a stage 2 tune with OFT. On my first test drive, when I stopped at a red light the RPM's went pretty low (~400 RPM) and the engine seemed to bog down and stutter for a second (CEL briefly flashed). It got better with time though, perhaps the engine learning? Either way I figured that I would just edit the minimum idle rev tables in RomRaider. Now the car idles just a bit higher like it should, but only after it first dips down to 500 RPM when I brake to completely stop at a red light, or in the time between going from engaging the brakes at a stop to engaging the throttle. I haven't logged anything yet but that's the next step. I figured some/most of you may have already dealt with a similar situation. Thank you for the input!
TL;DR - within RomRaider can I edit table values so that the RPMs never drop below ~700 RPM? |
Drives: 10 Series FR-S #1859
Its normal for the car to have a low idle after a flash The ecu needs a few miles after every flash to recalibrate itself, the same thing happens when you unplug the battery and reconnect it. Should be normal and more fun with the stage 2 tunes very soon!
Cheers, -Greg |
| The Following User Says Thank You to Initialg86 For This Useful Post: | Teseo (07-19-2017) |
Drives: 2014 Scion FR-S Monogram
I have been having this issue come up periodically even after putting hundreds of miles on the car after the flash. I'm running a Tomei UEL header with full catless exhaust on the OFT stage 2 e85 tune. Probably every 3 days it seems my car has trouble finding its idle. While monitoring with the OFT I see that the AFR seems to hunt around going up to mid 15s then jumps down to 13s which is where the car seems to bog down and almost stall sometimes turning off the headlights. I can't seem to find any reason as to why it happens though.
Raven OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap |
| The Following User Says Thank You to Detroiter For This Useful Post: | Strife26 (01-14-2018) |
BRZ Wannabee
Huh that seems similar to what I'm seeing, although not that extreme...odd.
TRACKBREAD
I have a similar condition. When I clutch in and decelerate to a stop (AFR goes to 15 as rpms drop from ~3000) the rpms drop too much and have to bounce back up to find the idle spot. It doesn't happen all the time and I usually can tell by the excess vibration in the gear lever.
Sent from my iPhone using Tapatalk Last edited by Yoshoobaroo; 07-19-2017 at 06:56 PM. |
#6 | |
BRZ Wannabee
I just wish there was a way to program in a soft stop that says don't let the RPM's dip below some set point. Is this possible?
I don't believe so. The ecu is already told to not let the engine go below the idle point by the tune. If yours is anything like mine with the afr changing then it seems to be more of a problem with keeping a steady afr at idle and it adjusts to compensate resulting in the rpm dip.
Drives: UK GT86
This is what the idle should be like. There's nothing that can be done.... Except to improve the idle settings.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | Detroiter (07-19-2017) |
#10 |
Is this a common problem with the OFT tunes? I thought I remembered reading that the tune was supposed to help with the idle problems that existed on the stock tune.
#11 |
BRZ Wannabee
I'm pretty sure that all it does is raise the minimum RPM setpoint.
#12 | |
TRACKBREAD
My idle was a disaster on the stock tune. Idle on OFT is much better, but not quite perfect. Sent from my iPhone using Tapatalk |
#13 |
Drives: Toyota 86
Mine stalled several times before learning phase is completed.
From the next drive, everything is ok.
#14 |
BRZ Wannabee
I'm going to edit the PI/DI ratio tables under idle conditions as per this post and see if it helps: http://www.ft86club.com/forums/showp...6&postcount=21.
Curious, how long does a "learning phase" take anyways? |
| Tags |
| jdl, oft, romraider, rpms, stage 2 |
| Minimum 51% Ethanol | smg1138 | Software Tuning | 13 | 03-15-2016 05:44 PM |
| Minimum HPDE Brake Pad Thickness | DarkSunrise | Tracking / Autocross / HPDE / Drifting | 11 | 10-28-2014 11:26 PM |
| Set a minimum post count to sell in Classified? | mav1178 | Site Announcements / Questions / Issues | 9 | 08-26-2013 08:25 PM |
| The bare minimum? | Scaldy | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-11-2012 10:58 AM |
| Minimum requirements... | Blokatos | Scion FR-S / Toyota 86 GT86 General Forum | 528 | 11-15-2011 05:04 PM |
